2010 2011 BMW 5 Series Forum F10 N63TU Intake MAF Pipes! Build your own intake! |
11-14-2020, 01:54 PM | #1 |
Rep 5
Hey guys, I went through the whole process of making an intake for my 750Li a while back and as everyone knows the biggest hurdle is the MAF sensor housing to allow you to build any style of intake. I was able to tackle that and now have the ability to provide the MAF pipes to anyone who wants to build their own intake! - Includes PAIR of MAF Pipes - 3" Aluminum construction - Direct fit for Stock MAF sensor - Will fit into stock turbo inlet pipes - Use silicone piping to make custom intake! Shipping these out of Atlanta (free shipping in most cases) so you can have them in a couple of days. I have 2 sets left and can order more production if there is any interest! Lastly, here's a quick tip to building a front facing intake for our cars: -Buy the "turbo inlet pipes" from the X5M (these mount right up to our turbos and have the flange for the PCV/breather and they route the intake towards the front of the car. - Connect these MAF Pipes I have to the X5M turbo inlet pipes - Install factory MAF sensor into he pipes - Use silicone or aluminum intake piping to rout the filters to behind the grills or anywhere you want! DONE! |
11-17-2020, 11:47 AM | #2 |
Rep 262
Not to rain on your parade but I bought this same set off eBay for like $70 and they worked okay. I didn't like that there was no seal from the MAF sensor to the pipe/housing so I ended up buying another full set from another Manufacturer. Sorry but you should lower your price or include the entire intake setup for $200. I spent about that building my own intake originally and it takes the filters to the inside of the kidney grills like others have done.
https://www.ebay.com/itm/70mm-76mm-M...Cclp%3A2334524
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
12-02-2020, 11:17 PM | #3 |
Rep 74
Drives: BMW 550i GT Xdrive
I did the samething as well, got them from if you can believe Walmart, they sell them for $31 each. https://www.walmart.com/ip/YLSHRF-Ai...ount/821878289
No taking our BMW owners to the cleaners....... This is a real COLD air intake I have an extra set of MAF sensor holders if anyone wants them $50 for set. Last edited by wmg/bmw; 12-02-2020 at 11:22 PM.. Reason: left out some message |
12-03-2020, 09:02 PM | #4 | |
Cole
320
Rep 498
Tags |
cold air intake, maf adapter, maf pipe, n63 intake, n63tu intake |
