2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes xDrive and ACS lowering
      10-31-2011, 11:23 AM   #1
BMWMB
BMWMB's Avatar
Belgium
36
Drives: Mercedes C450 AMG Sport
My 530d xDrive is lowered with ACS lowering springs.
My car has adaptive drive.
I drove about 500km's so the springs are settled.
In the front the car dropped 20mm and in the rear 30mm.
Here are some pictures i took with my oldtimer Blackberry.
2018 991.2 GT3 MT Clubsport - 2016 Mercedes C450 AMG Sport break - 2015 Range Rover Sport SDV6 HSE Dynamic - 1993 BMW E36 M3 tracktoy - 1990 Porsche 964 Carrera 4 convertible
      10-31-2011, 01:33 PM   #2
grimlock
Drives: F10 N52B30@255PS
Love the anti-rake (front bit higher than back)
Gives a more dignified yet lowered look.
I believe it eliminates the problem of speed bumps, and the angle lifts the front even more than the stated drop.
      10-31-2011, 02:47 PM   #3
tp550i
tp550i's Avatar
Drives: 2011 550i Sport
Looks great
those 356's looks awesome!!
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
      11-15-2011, 08:47 PM   #4
ObiWanSpain
ObiWanSpain's Avatar
Spain
Drives: F10 530xd
Fantastic! So beautiful and so low!
      04-08-2012, 07:49 PM   #5
Russkey
Russkey's Avatar
Drives: '12 BMW AW 550xi
2012 550xi  [10.00]
Great pictures! Perfect drop imo. My set is going to arrive next week...
'15 Porsche Macan S / Black & Garnet Red / 20" RS Spyder Wheels / CF trim / Red Calipers / Black Rear Badge.
'12 AW 550xi / Dinan S2 / Arkym CF Spoiler / 3D Design Style Splitter / Eisenmann Race Exhaust / 20' HRE FF01 / ACS Springs / CF Grill / CF 3D Design Diffuser / Blue Calipers...
      04-09-2012, 08:03 AM   #6
cmhsam
Drives: 2018 F90 M5
Where did you end up purchasing the ACS springs?
      04-09-2012, 03:21 PM   #7
Russkey
Russkey's Avatar
2012 550xi  [10.00]
Ask Calvin @ sonicms.net
      04-10-2012, 01:19 AM   #8
BMV8
BMV8's Avatar
Drives: 2012 AW M3
looks nice!
      08-07-2018, 04:12 AM   #9
The Dane
Denmark
112
Drives: 2015 m5 cp
Hi
Do you have the exact part nr for the ACS springs fitted to this car ?
ACS states that the spring set for my car have the number 3130210760
I also have a 530d m-sport drive, (however a 2014, with the stock none m-sport suspension), but yours seem to sit much higher the other f10`s fitted with acs springs.
I am trying to decide if I should go with the ACS springs
Thanks
      08-07-2018, 10:14 AM   #10
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
Originally Posted by The Dane View Post
Hi
Thanks
I have also noticed that some older ACS springs did not lower the car as much as newer ones, and that perhaps a design change was implemented. My ACS springs, purchased in 2016, lowered my xDrive about 1.5" in the front, and 1.2" in the rear.
You can find the current part numbers for ACS springs here.
Here is a gratuitous picture of my F10 xDrive on ACS springs.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      08-07-2018, 10:46 AM   #11
The Dane
Denmark
112
Drives: 2015 m5 cp
[QUOTE=cdmulders;23558737]I have also noticed that some older ACS springs did not lower the car as much as newer ones, and that perhaps a design change was implemented. My ACS springs, purchased in 2016, lowered my xDrive about 1.5" in the front, and 1.2" in the rear.
Thanks for your replay
I think you are right, somethings is right
Your car looks perfect with the ACS springs I must say.
What is the ride kvality like ?
Thanks
      08-22-2019, 10:13 PM   #12
TheWknd
Drives: Bmw 535xi
[QUOTE=The Dane;23558906]
Thanks
Are you using the 310 part number all around?
      08-23-2019, 10:47 AM   #13
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
I'm using the listed springs for front and rear, and the fronts are definitely different from the rear. The ride is as good as OEM, but it is a bit different. You do feel road imperfections a bit more, particularly in the back seat. The handling is more responsive but the ride is still smooth and relatively comfortable. I think the springs use a progressive rate, because when I load up the car with people and stuff, it does not sink as much as it did with the original springs, so I don't worry too much about road roughness (within limits, of course) when I'm loaded.
      08-23-2019, 11:05 AM   #14
TheWknd
Drives: Bmw 535xi
Thanks for your response. I'm having trouble identifying listed springs. Some say 310 and some say 410 for rears. Some say 110 for xdrive for front. Any help on this would be much appreciated.
Do you have a 335 xdrive?
Listed on your link says:
3133210110 front
3353210310 rear
      08-23-2019, 06:00 PM   #15
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
3133210110 front
3353210310 rear
I have a 535xi, and you indeed have listed the springs that I think I have, and that are listed on the ACS website under the 535xi model. I cannot seem to locate my initial paperwork, and because an indy shop purchased and installed the springs, I don't have the invoice from ACS to double confirm the exact springs I ordered. Nevertheless, I did have the indy shop verify the spring part numbers (after the springs were installed) to ensure that the part numbers were the same as the ACS website in 2016. The 410 part number to which you refer is for the 550i according to the ACS website.
      08-23-2019, 06:17 PM   #16
TheWknd
Drives: Bmw 535xi
3133210110 front
3353210310 rear
Exactly what I researched too. Thanks so much for checking on it. Glad to see your pic of acs Installed on my car model. Btw, your car drop looks spot on!
