2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Custom N55 air intake journey
      01-11-2020, 08:08 PM   #133
e38740imd
Drives: 2016 640i
Originally Posted by Bmw doubles View Post
That's for N55 2012 and up. Below models are the N54 Continental style.
Here's the convo I'm having about the HOD.
Anyone running the Helix HPFP Overdrive https://www.e90post.com/forums/showthread.php?t=1666144
understood. i was under the impression you had the 2012+ 535i
just tryna pass along good info.
      01-14-2020, 10:41 AM   #134
mashpotato
Drives: '11 F10 N55
Oh nice thanks. Maybe I can provide them the prototype and mass market this thing.
Definitely in on one. There is no good intake solutions if trying to install PR coils (not the BMS one). Better flow, clear the clutter on the top, easier to access stuff.
Lots of benefits
Hopefully don't have to cut up a lot near the front, and keep the chassis bar.
      01-14-2020, 10:49 AM   #135
BimmerHausPerformance
BimmerHausPerformance's Avatar
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
Lots of benefits
I have requested access to the group but they are asleep I think. Can anyone please post what info they had on this new intake? I've been super busy at work but I'm about ready to tear apart the front of my car to build one of these right.
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
      01-14-2020, 11:04 AM   #136
burro_blasta
Drives: 2013 535 M Sport
Here's the post. No other updates posted since. Richard works for Spool
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
      01-14-2020, 01:39 PM   #137
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
That definitely doesn't look like a good place to pull air from. No ducting, and kinda close to the turbo. I wouldn't be surprised if locating it there raises your IAT by a couple of degrees.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      01-14-2020, 01:50 PM   #138
513
Bah, that's what Meth is for! But I'd still rather go to the front of the rad behind the grill!
2011 F10 S55 6MT
      01-14-2020, 02:27 PM   #139
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Another idea I was considering was using a air scoop that attaches to your engine tray / cover with a hose that goes up to your BMS open air filter.
Obvi I went with the short ram.
This is what i got from Pegasus racing
https://www.pegasusautoracing.com/pr...p?Product=3629
Never did anything with it though.
IG: @bmwdoubles
      01-15-2020, 09:11 AM   #140
MaximumFreckles
Drives: 2011 BMW 535i Msport
I have been considering building a small airbox in the open space where that filter is sitting in the spool picture. Turbo pipe to box directly, then the front of the box is ducted to the front bumper opening. I might try and mock something up soon.
If you just want the filter sitting in that space, I dont think IATs will be that bad. In fact, just run some ducting from the bumper to the filter area. I have a custom open filter, and it pulls air from the stock front intake ducts. My recorded IATs have been slightly better than stock, and never worse...I cant imagine this would be much different.
      01-15-2020, 01:41 PM   #141
ziekxq
Drives: 2011 535i xDrive
"Boomin and you're Boomin and you're Boomin in your Jeep"
How did you extend the vacumm line? Can you post pictures?
      01-15-2020, 03:43 PM   #142
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
From the valve cover or the fuel breather?
IG: @bmwdoubles
      01-15-2020, 04:49 PM   #143
ziekxq
The fuel breather I believe that's the one going over the engine.
      01-15-2020, 09:15 PM   #144
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Just stretch it
IG: @bmwdoubles
      02-21-2020, 03:33 PM   #145
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Updates:
Met up with the guys from BPMSport spoke with Bruno and Mike about my custom ram intake. They mentioned that the first step was to flip the heat shield preventing too much air at low speeds. That's what caused the high voltage and the subsequent lean trigger.
So far so good. I'm still testing it and will try more extreme conditions when the situation allows for it. No errors so far. Thanks BPM!
Probably going to get a black shield for low profile.
IG: @bmwdoubles
      02-21-2020, 06:53 PM   #146
DaHeadlightGuy
Drives: 2013 DSB F10
Did you ever get a MAF/IAT code with that before the shield?
Updates:
      02-21-2020, 09:37 PM   #147
513
Have you tuned your car since the fuel upgrades and the intake?
      02-21-2020, 09:41 PM   #148
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Updates:
I was getting the too lean code with the shield behind the filter. By reversing it to face the front to block the wind at low speeds I've received no codes far. I'll try it for a while and report back.
IG: @bmwdoubles
      02-21-2020, 09:42 PM   #149
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Not yet. Soon my friend. Soon.
I'm messing around with a beta PS2 tune for e30 right now.
https://www.pureboost.de/
IG: @bmwdoubles
      02-22-2020, 09:38 AM   #150
513
Questions:
Any data on the tune as far as #'s? Boost, HP?
I'm assuming this is a new OTS map and is taking into account your upgraded HPFP, correct?
What platform are you accessing their tune from - MHD?
Can't wait to see the #'s from your dyno runs you said you were going to do...
2011 F10 S55 6MT
      02-22-2020, 10:31 AM   #151
ziekxq
I just found another tuner by the name David Stoup if people interested:
https://m.facebook.com/pages/categor...pTuning/posts/
https://www.das-autowerkz.com/produc...-custom-tuning. --- unlimited revisions.
Just throwing an option out there.
      02-23-2020, 04:27 AM   #152
mfractal
VAG Survivor
mfractal's Avatar
40
Drives: E90 335i
+1 for David. Great etuner and person.
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
      02-23-2020, 10:56 AM   #153
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Wheres David located?
IG: @bmwdoubles
      02-23-2020, 12:52 PM   #154
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
Kevin Baldi and LABWORX TUNING ftw.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
