2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 343M RIMS 245/40/20 & 285/35/20 on their F10 550I XDRIVE?
      11-28-2023, 12:26 AM   #1
SocomCA
Drives: BMW M6
Hey guys,
I have a 2016 BMW 550i xdrive with 343m M5 rims currently and with a 3mm spacer (looking to eventually removing that with m5 caliper changes) and i was wondering, would it be possible to currently run 245/40/20 & 285/35/20 on my F10 550i xdrive awd without it causes an issue with rubbing?
Also, if i get dinan springs to lower the car, would that tire size be a problem with the 40 front side wall height and 35 rear side wall height?
For the awd system it's less than 1% difference between the front and rear diameter so its not a problem with that.
Currently I have a 245/35/20 & 285/30/20 for summer tires but I cant seem to find winter tires for that size and plus I would like the higher tire height to fill the tire gap better and for more comfort.
Any advice would be great!
EV8634.00
      12-12-2023, 02:43 PM   #2
9mmkungfu
Drives: 335d, 535d, 750i, X5 35d
Thinking about running 245/40/20, 275/35/20 as well. I saw that Unspec may be running this setup and reached out to confirm.
      12-13-2023, 11:55 AM   #3
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
I am running the same fronts but slightly smaller (275/35/20) rears. No rubbing, even on pretty aggressive lowering.
2015 BMW 535xi
ISTA VM Setup/Tutorial
EV8634.00
Tags
245/40/20, 285/35/20, 550i xdrive, bmw m5, m343
