2010 2011 BMW 5 Series Forum F10 343M RIMS 245/40/20 & 285/35/20 on their F10 550I XDRIVE? |
11-28-2023, 12:26 AM | #1 |
Rep 142
Hey guys,
I have a 2016 BMW 550i xdrive with 343m M5 rims currently and with a 3mm spacer (looking to eventually removing that with m5 caliper changes) and i was wondering, would it be possible to currently run 245/40/20 & 285/35/20 on my F10 550i xdrive awd without it causes an issue with rubbing? Also, if i get dinan springs to lower the car, would that tire size be a problem with the 40 front side wall height and 35 rear side wall height? For the awd system it's less than 1% difference between the front and rear diameter so its not a problem with that. Currently I have a 245/35/20 & 285/30/20 for summer tires but I cant seem to find winter tires for that size and plus I would like the higher tire height to fill the tire gap better and for more comfort. Any advice would be great! |
12-13-2023, 11:55 AM | #3 |
Rep 2,591
I am running the same fronts but slightly smaller (275/35/20) rears. No rubbing, even on pretty aggressive lowering.
2015 BMW 535xi
EV8634.00 |
Tags |
245/40/20, 285/35/20, 550i xdrive, bmw m5, m343 |
