06-26-2020, 08:56 PM | #45 |
Rep 277
Sorry what I meant was: Do you need to access/change/take off the OFHG to fix an oil cooler or rocker cover leak? Ie. Would you need to prime the system as suggested after a rocker cover or oil cooler leak?
06-26-2020, 09:31 PM | #46 |
Rep 915
I did not prime system after replacing valve cover, also no, ofhg is not required to take off for valve cover replacement. I would prime system for oil cooler though to get the oil back into the system where needed.
Instgram @burninja
Shrimpy22.50 |
06-28-2020, 09:35 PM | #48 |
Rep 1,442
Drives: 2011 535i 6MT
Ok check this out! These guys explain how the N55 sucks air and causes this issue!! At about the 6 min mark.
Themarkymark97.50 ezaircon4jc4477.50 |
06-28-2020, 10:35 PM | #49 | |
Rep 96
Even so, I looked in the recent past for an oil pan baffle for our chassis to no avail, not sure if the weld-in F series baffle plates I found would fit.
2014 535i xDrive | MHD Stage 2+ | ER Catless DP | ER Charge Pipe | G-Plus Intercooler | Walbro 450 LPFP | Staggered 20” Avant Garde M359 |
06-29-2020, 01:42 PM | #50 |
Rep 2,590
I wonder if priming can be skipped by just idling the engine afterwards for 5-10 minutes. In theory, the oil should get to the proper places in a few seconds, and even if it causes wear I can't imagine it being extreme enough to destroy the engine. I wonder how many of the seized engines got the OFHG job, and then the owner immediately went to go drive it instead of just idling it for a bit. I did the job yesterday (damn is it messy) and couldn't find any info on what fuses to pull to prevent engine start, so I just left it idling for a bit.
2015 BMW 535xi
06-29-2020, 01:44 PM | #51 | |
Rep 96
06-29-2020, 01:55 PM | #52 | |
Rep 2,590
2015 BMW 535xi
06-29-2020, 02:51 PM | #53 | |
Rep 1,873
I had the same rationale months ago and was presented this information. Idling to prime is not enough. On the other hand, we have developed no pattern of just what circumstances lead to priming being critical but missing from the factory instructions in TIS. The strongest theory I've heard is external air/oil cooler loops but with no strong correlation. Another theory is "2011s are bad", but to my knowledge the post-OFHG bearing failures are not limited to 2011s. I've said before, I can't believe that ISTA+ doesn't just have an oil prime function that can disable fuel injection and ensure pump volume is at max instead of making the official procedure be to pull fuses and disconnect injectors and stuff. |
06-29-2020, 06:31 PM | #54 | |
Rep 2,590
2015 BMW 535xi
09-24-2020, 10:15 PM | #55 |
Rep 274
Did you figure out which fuses to pull? Would rather do this than disconnect the fuel injectors.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i |
09-25-2020, 06:55 AM | #56 |
Rep 1,442
You could also disconnect the plug at the back of your fuel rail, I would imagine that would accomplish the same thing.
09-25-2020, 07:10 PM | #57 |
Rep 2,590
Nope. I'd just pop out the injector and spark wires. It plugs into the DME right under the intake box, and is pretty accessible.
2015 BMW 535xi
09-26-2020, 08:23 AM | #58 |
Rep 14,522
i forgot what fuses we pulled without looking back again
09-29-2020, 08:20 PM | #59 |
Rep 915
Fuse 139 and Fuse 184 in the trunk are what to take out for fuel system to shut off. Fuse 135 is empty.
09-30-2020, 01:08 AM | #60 |
Rep 274
Great! Thanks for the detailed pictures. I saw the same on my fuse diagram but wanted to make this shut off the fuel system for others. Should I wait about a day after pulling the fuses to lose pressure in the system? The fuel pump usually primes when I unlock the car.
BurrNinja430.50 |
09-30-2020, 01:21 AM | #61 | |
Rep 915
Instgram @burninja
GrabacrOne177.50 |
11-08-2020, 08:36 PM | #62 | |
Rep 78
Drives: 2014 535i xDrive
When you do that, you will see your check engine light start and engine drivetrain malfunction light turn on, which is normal. Just remove the engine code after reconnecting the full pump battery terminal or disconnect the negative terminal and put it back to erase the code. Last edited by T-Bone18; 11-09-2020 at 11:57 AM.. |
lsturbointeg9155.50 |
11-09-2020, 04:28 PM | #63 |
Rep 1,442
Guys, the fuse for the fuel pump is in the trunk, takes 2 seconds to pull out so:
1. pull it 2. run the car BEFORE the oil change to get the fuel out of the lines 3. then do the oil change 4. crank the car a few times to build oil pressure 5. insert fuse, start car. Done. It's easier than even accessing your battery. Super simple. |
11-17-2020, 04:37 PM | #64 |
Rep 103
Drives: 535i F11
Hello.
I''ve just read this post and I'm freaking out. Do I have to worry about this issue after a routine oil and filter change? What is exactly OFHG? Is a part or a procedure? Thank you guys! |
11-17-2020, 06:10 PM | #65 |
Rep 5,357
11-18-2020, 08:17 AM | #66 |
Rep 2,590
Think he's talking about the priming specifically
Generally, no you don't need to prime if you're just doing an oil change, but it wouldn't hurt either.
2015 BMW 535xi
