2010 2011 BMW 5 Series Forum F10 PYSpeed.com | Avant Garde BMW Type M355 F10 M5 Style - Bimmerpost Special! |
02-12-2013, 03:03 PM | #1 |
Rep 3,478
PYSpeed.com | Avant Garde BMW Type M355 Style 19/20 inch Wheel Set
These Avant Garde BMW Type M355 F10 M5 Style 19 inch Wheel Set are guaranteed flawless straight from the factory! With perfect fitment and evenly coated finish. They are low pressure cast, increasing the quality and decreasing the weight when compared to gravity cast wheels. The Avant Garde M359 Wheels are also stronger with a higher load rating than most other low pressure cast wheels on the market today. Bolt Pattern: 5x120mm Center Bore: 72.56mm PYSpeed Recommended Size: E9X (non M) - 19"x9.0" ET35mm Front 235/35/19 - 19"x10.0" ET38mm Rear 265/30/19 E9x M3 - 19"x9.0" ET18mm Front 245/35/19 - 19"x10.0" ET25mm Rear 275/30/19 E60 5 Series - 19"x9.0" ET18mm Front 245/35/19 - 19"x10.0" ET25mm Rear 275/30/19 F10 5 Series - 19"x9.0" ET35mm Front 235/35/19 - 19"x10.0" ET38mm Rear 265/30/19 E9X (non M) - 20"x9.0" ET30mm Front - 20"x10.5" ET38mm Rear E9X M3 - 20"x9.0" ET20mm Front - 20"x10.5" ET25mm Rear E60 - 20"x9.0" ET20mm Front - 20"x10.5" ET25mm Rear F10 (non M) - 20"x9.0" ET30mm Front - 20"x10.5" ET38mm Rear F10 (M5) - 20"x9.0" ET20mm Front - 20"x10.5" ET25mm Rear |
02-22-2013, 02:48 AM | #13 |
Rep 3,478
Hi, you need to have at least 5 posts to use PM. Please send me an Email to ivan@pyspeed.com
Thanks!! |
