2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media lsturbointeg's "Black Candy" build thread! (with daily/weekly updates!)
      03-12-2020, 10:25 PM   #287
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by top ramen View Post
Any updates on the install?
Not yet. Buddy and I got the oil change, oil filter housing gasket and oil cooler gasket replaced. Will finish on the 17th. Will let you know how it goes
      03-14-2020, 07:56 AM   #288
lsturbointeg
Currently changing the oil using LIQUI MOLY MFC, oil filter housing gasket, oil cooler gasket and belt all installed courtesy of Burrninja himself! everything ordered from ECS Tuning. comes to find out it looks like my Indy mechanic never actually changed out my oil filter housing gasket 2 years ago by looking at the gasket as it was pretty hard and not soft? we're suspecting he changed the oil cooler gasket instead as it still looked new. pretty ridiculous if you ask me! anyways, gonna use some simple green to scrub out all the oil cake build up on the motor where all the pulleys are with a wire brush. also gonna remove the cover underneath that protects the engine since it's been drenched in oil!
also my 4" tips came in! can't wait to get these on
      03-14-2020, 11:36 AM   #289
Use the purple stuff. The green will eat aluminum!
      03-14-2020, 12:21 PM   #290
lsturbointeg
ah damn no kidding?! i'll have to pick up some Purple power than. thanks for the heads up brother
      03-14-2020, 12:45 PM   #291
Simple Green makes a purple colored solution that's aluminum safe. Don't ask how I know about the green stuff...
      03-14-2020, 04:17 PM   #292
it3_Magic
it3_Magic's Avatar
113
Drives: 2014 520D M-sport
2017 BMW G30  [0.00]
Thats why i do all servicing myself. I use Liquimoly 4200 on my diesel. Highly Recommend ceratech from them also.
Loving the tips btw
      03-14-2020, 06:53 PM   #293
lsturbointeg
I use the Simple Green to clean my stove. That's about it. I thought I could use it on the car but i guess not lol.
      03-15-2020, 01:10 PM   #294
zcali925
zcali925's Avatar
Drives: '15 BMW 535i M Sport
Wow I did not know this. What about wd-40 degreaser.
Sup
      03-15-2020, 02:06 PM   #295
lsturbointeg
huh, didn't know wd40 had a degreaser?
      03-15-2020, 06:05 PM   #296
zcali925
zcali925's Avatar
Just saw it amazon.
Sup
      03-17-2020, 07:09 AM   #297
lsturbointeg
been busy that last couple of days just cleaning up all the oil sludge that was left on the motor when i had the oil filter gasket housing replaced. as most of you know when it leaks it drips onto the belt which than flings all over everything. Much cleaner now!
      03-17-2020, 07:23 AM   #298
lsturbointeg
what a PITA LOL! so because the gyms are now closed in Ohio i decided to put my energy into installing the VRSF catless dp. so there were quite a few issues i ran into. the 2nd nut bracket was really hard to get off because of how much room there was to work with. i eventually got it off but it did take some time. the 2nd was no matter what i do there just wasn't enough room to get the dp off with the exhaust still on. so that was the 3rd issue was removing the whole exhaust system including removing the lower brace bracket. once the exhaust was dropped it was just a matter of wiggling off the dp.
here she is flying high!
exhaust is down
and here's the OEM dp!
will post more progress pictures when i start reinstalling everything
      03-18-2020, 07:36 AM   #299
lsturbointeg
alright, got the Vibrant defouler installed along with all the OEM o2 sensors. per discussion in the Vibrant defouler thread i used the middle size restrictor and i have it facing upward as recommended. hope this helps other people interested in doing this as i couldn't find any info on which defouler to use which restrictor to use and the fact it needs to face up!
so after everything was installed i'm happy to report there's no CEL!!!!!!
      03-24-2020, 10:27 AM   #300
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
How does the car sound now?
      03-24-2020, 02:40 PM   #301
lsturbointeg
Currently working on getting the tips done. will keep you posted
      03-25-2020, 06:15 PM   #302
lsturbointeg
just ordered the TurboSmart Dual Port VR9 BOV! heard great reviews from Kies Motorsports as well as a pretty cool install and sound video by ThicGarage
      03-27-2020, 03:24 PM   #303
lsturbointeg
off to the muffler shop!
gonna have my guy cutoff the existing 3.5" exhaust tips and weld a new 2.5" piping off the muffler to extend out more past the diffuser. reason being is currently the tips are hidden underneath the diffuser like so
here's what the exhaust looks like for those wondering
so sitting with him we had to discuss how it's going to be done because the spacing from the two 3.5" pipes will be an issue when going to the larger 4" pipes. the exhaust tip on the outer side will remain the same since i have about a .25" gap between the diffuser and the tip. the inner exhaust pipe is what will be a task for him. he decided to cut the pipe about .75" from the muffler and than add the new pipe but he will have to have a slight bend that way the tips will lineup without rubbing. he said it's doable. also, i am eliminating the EVC since i always leave it open so there's really no point in keeping it
so it's currently at the shop now and i should have it back tomorrow. i'll post some pictures when i do
      03-28-2020, 03:01 PM   #304
lsturbointeg
Update! picked the Meisterschaft's up this morning from the muffler shop! here's whats left of the old tips and EVC
okay, from the top view you can see what my guy had to do. he cutoff and welded new 2.5" pipe which extends further than what i had before. he also had to on the inner exhaust pipe bend out a bit to accommodate the larger tips from 3.5" to 4.0" tips.
everything still looks centered
still plenty of room due to how large the opening is on the carbon fiber diffuser
so tomorrow i will continue working on installing the tips however i need to turn the VRSP as it's sitting low and if you turn it counter clockwise it should be running flush with the bottom of the car. than i'll re attach the exhaust mounts and everything else. will post some pictures when i'm done!
      04-01-2020, 11:15 PM   #305
lsturbointeg
after a year of almost smashing my back window i finally ordered and received the new trunk tension springs. so the first picture is why the trunk flies open. the middle plastic broke off on the end there.
and here's both sides completed and i'm happy to report no more smashing windows!
      04-01-2020, 11:21 PM   #306
lsturbointeg
finally got the exhaust tips done! here i am before clamping things down is to check and make sure the tips sit exactly where i want them.
after than i went ahead and put the cf diffuser tray back on
i'm very happy with the way these turned out! it's what i imagined what they would be. now it just makes my backend that more aggressive!
      04-03-2020, 11:22 PM   #307
lsturbointeg
VRSF charge pipe came in!
Ickdeep5720.50
      04-03-2020, 11:27 PM   #308
lsturbointeg
so getting some custom rotors made by cquencebrakes. i really like this design from a fellow Instagramer so i asked cquencebrakes if they can make the same design and they said yes!
and here's what they came up with
Ickdeep5720.50
