2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Clear coat on headlights?
      01-04-2019, 11:14 AM   #1
Dcm1952
Dcm1952's Avatar
Drives: '14 535i Msport, 99 M Roadster
I've got a 2014 535i and on one of the headlights it looks like a film or clear coat of some kind is starting to flake off. I really don't want to spend the $1,000's required to replace a headlight. Can these be "repaired" by doing the multiple step sanding and polishing process?
JakOG43.50
      01-27-2019, 11:30 PM   #2
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Ask around about headlight polishing. Any experienced restorer will show past work examples, and allow you to speak with customers. JFYI, no matter how good the restorer is, the headlight will not be the same as new.
Another option is to buy a used headlight.
If you get it polished, please post pics.
      01-28-2019, 08:56 AM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I would start with a headlight restore kit and see how that works.
      01-31-2019, 06:33 AM   #4
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
It's true repaired is never like new. Since you are seeing hardcoat failure, though, you have little to lose.
They can be made quite a bit better with polishing, and there are variable quality re-coating products out there. I've had decent looking results from a kit with an aerosol top coat - don't remember the brand - used it on a friend's non-BMW car that was REALLY bad and they were just shooting for "better", not perfect.
There are other coatings out there which are pretty much "the real deal" like Opti's Opti-Lens. The catch is the smallest quantity you can get that in will do about 50 cars I think.
You'll get best results removing the light assembly from the car and working on a bench. You can ask in dedicated detailing forums too if you'd like to DIY.
      01-31-2019, 08:40 AM   #5
Dcm1952
Dcm1952's Avatar
Update
I got the coating off and used a headlight restore kit to polish. Not "like new" but acceptable. Passes the six foot test. Just can't justify the cost of replacing with new. Thanks for the input.
      04-27-2019, 10:29 AM   #6
Luky
Luky's Avatar
Drives: 2016 550i M Sport
The hard coat protects the plastic from UV degradation as well as making the plastic surface harder and more abrasion resistant. If you just polish the surface to remove the old hard coat and plastic oxidation, the plastic that remains is just going to degrade that much quicker. I would highly recommend putting a clear protective layer over the lens after polishing and something with UV protection built in... (I am a Plastics Engineer and did a lot of automotive stuff years ago.)
et70079.50
      08-10-2019, 07:30 AM   #7
Bruno112
Croatia
20
Drives: 2014 F10 530d MSport
What you recommend to me? I was in detailing center i guy told me to change the lenses,which is about 320 euros.
      08-13-2019, 01:05 PM   #8
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
2K clearcoat
      08-23-2019, 01:53 PM   #9
starlights
Drives: G05 50i
Alternatively you could just polish over the lens every time you polish your car with the same polish as used for the body (after lens restoration). Repeated, periodic polishing will help to retard uv related degradation over time.
      09-03-2019, 07:23 PM   #10
Bruno112
Croatia
20
Thx guys
