2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications G Plus F10 Intercooler
      03-10-2019, 02:54 PM   #23
Mtre1
Drives: Bmw 2014 535ix m sport
Did you remover front bumper?
      03-10-2019, 02:57 PM   #24
mrderekmeier
mrderekmeier's Avatar
14
Drives: 2012 535i 6spd
No just the panel underneath, the intercooler drops straight down.
      03-10-2019, 03:15 PM   #25
Mtre1
      03-10-2019, 04:30 PM   #26
jonobro
Drives: bmw f10 535i
Originally Posted by mrderekmeier View Post
Originally Posted by rencxgreg View Post
Received mine today, it looks quality but seller on the eBay did not send me the mounting bracket and screws. I already sent a message to the seller and did not receive any reply yet.
I just got mine today and installed it tonight. I didn’t get any hardware either, I just made 2 brackets from strapping I had in the garage. Did a couple preliminary pulls and with it heat soaked from idling IAT was dropping in a 2-3 gear pull. I’ll upload some logs tomorrow once I can get on the highway and go through 4th gear.
EDIT .... Did some pulls with the engine heat-soaked starting at 110 degress IAT in 3rd gear and it only rose to 114 through 5th gear (6spd MT).
Great bank for the buck!
https://datazap.me/u/mrderekmeier/g-spec-intercooler-3rd-5th-gear-6spd-n55-heatsoaked-start?log=1&data=1-4-6&mark=3-79&hg=4-1-6-11-18
Link to EbAy purchase ?!
      03-10-2019, 10:05 PM   #27
mrderekmeier
14
https://www.ebay.com/itm/New-Front-M...9/143037499299
      03-11-2019, 09:05 AM   #28
jonobro
Is this a REP or ?
      03-11-2019, 06:14 PM   #29
mrderekmeier
14
Is this a REP or ?
Seems to be exact rep of Wagner.
I just did a pull today from 3rd to the top of 5th gear and IAT only rose from 71 degrees to 94. 23degree increase not too bad! Ambient temp was about 64.
Mind you this is stock N55 turbo, a PS2 would be much more efficient with higher boost and should yield lower IAT #s. My PS2 will be ordered this week, I cannot wait.
2012 F10 535i 6MT: PS2 Turbo, Phoenix Racing Intake Manifold, PI 550cc injectors - BMS Controller, FTP turbo Inlet & IC Piping, CP, VRSF D*P, M5 Mufflers, MHD JB4 BEF, E40 fuel.
      03-11-2019, 07:21 PM   #30
jonobro
Is this a REP or ?
A Wagner rep and works good geez I have to give it a shot the item location isn't even in China it's in CA that's odd I thought reps came from the guys in China hahah
      03-11-2019, 07:25 PM   #31
paul223
paul223's Avatar
Drives: F10
Mounting Hardware
If you don't get mounting hardware, you can make clamps. It is easy. I bought my Wagner Intercooler on eBay. It did not come with mounting hardware. I called Wagner USA, they were asking $99 shipped to me. LOL
John H.230.00
      03-12-2019, 12:37 AM   #32
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Originally Posted by Kwood-F10-535i View Post
Actually it is Tube and Fin! What is the weight of the Wagner? I will weigh this one.
I looked up the weight of the Wagner, it is 8.4kg or 18.5lbs.
https://www.schmiedmann.com/en/produ...duct=200001069
Did you get a chance to weigh your G-Plus?
      03-12-2019, 04:45 AM   #33
Kwood-F10-535i
Drives: 2016 535I
I weighed it at 18.2 lbs on my bathroom scale.
John H.230.00
      03-12-2019, 09:24 AM   #34
John H.
John H.'s Avatar
Thanks for weighing your IC. Wow! I'm impressed with the G-Plus. I think it is a great value. On my mod list.
      03-12-2019, 09:44 AM   #35
Kwood-F10-535i
Drives: 2016 535I
Great Value!! Bitch to get in!! The procedure is straightforward but it is certainly a tight squeeze! I Had to fab brackets as well. bolts are 4x M6-1.0 12mm-15mm long depending on thickness of the stock you make the brackets from. I used some 316 stainless piano hinge from my job and cut it down to the right shape. I have similar temp reduction from my logs. I am now on MHD Stg2 tune and love the power!
      03-12-2019, 12:00 PM   #36
burro_blasta
Drives: 2013 535 M Sport
Thanks for all this info dudes...after the unfair VRSF IC d*ckdance so many went through I swore off of getting a VRSF IC, out of principal if nothing else, and thought I was stuck paying up for Wagner. It'll be a couple months before I go for it, will be watching for additional feedback on G Plus until then
      03-12-2019, 03:20 PM   #37
trialmountain
Drives: F10 N55 - EWG
Would you mind posting logs? Before and after would be awesome if available.
      03-12-2019, 08:15 PM   #38
top ramen
Drives: Schwarz II 535i
Ebay has 15% off purchases today only. Could get it at $200 or less. I think this is just a replica of Wagner.
John H.230.00
      03-19-2019, 09:39 PM   #39
mrderekmeier
14
FYI I emailed the eBay seller yellowspeed and they sent me the brackets.
      03-21-2019, 06:40 PM   #40
InHousePerformance
InHousePerformance's Avatar
Drives: 2015 535i
2018 Ford F150  [0.00]
2015 535i  [0.00]
Ordered my G Plus last week and it got here Tuesday and Ill be installing it tomorrow! Stay tuned!!
2015 F10 535i
FBO BM3
Pure Stage 2
Dorch Stage 2 HPFP
E50 tune by Cary Jordan
EOS EkP Module
Walbro 525 LPFP
Variant Argon 20? Wheels
E60 M550i Sold
“Im a crazy car guy”
If it has a motor, it has my attention
John H.230.00
      03-21-2019, 09:36 PM   #41
top ramen
Nice. Post lots of picturea, logs, and a DIY if you can. Did yours come with brackets?
      03-21-2019, 09:39 PM   #42
InHousePerformance
Drives: 2015 535i
2015 535i  [0.00]
Will try to do all!! Havent opened the box yet so dont know. If not Ill make brackets.
2015 F10 535i
FBO BM3
Pure Stage 2
Dorch Stage 2 HPFP
EOS EkP Module
Walbro 525 LPFP
E60 M550i Sold
      03-22-2019, 01:17 AM   #43
trialmountain
When you take some pictures, can you measure the amount of fins per inch? (Hold a ruler up to the fins) Post some logs too!
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
      03-22-2019, 09:49 PM   #44
InHousePerformance
Drives: 2015 535i
2015 535i  [0.00]
DIY Posted!!
2015 F10 535i
FBO BM3
Pure Stage 2
Dorch Stage 2 HPFP
EOS EkP Module
Walbro 525 LPFP
E60 M550i Sold
