2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Passing Emissions with Catless DP and BM3
      04-10-2019, 10:12 AM   #1
pf10
pf10's Avatar
Drives: F10 550i 535xi
I have to get GA emissions done in a few weeks and I have bootmod3 and catless dp. Some people tell me I'll be good because bm3 blocks all the codes while others tell me I need to remove the dp and flash back to stock. Anyone here have any experience with bm3 and emissions inspection?
      04-10-2019, 03:29 PM   #2
Luky
Luky's Avatar
Drives: 2016 550i M Sport
Do they actually measure gasses from your tailpipe? If so you will probably need cats to pass. If only read OBD2 I dont know. You can always try and post it on here. Be interesting to find out. What happens if you fail? You just have to go back to stock and get a retest...
      04-10-2019, 04:12 PM   #3
johnhva
johnhva's Avatar
Drives: 2014 535ix
14 BMW 535ix  [0.00]
04 BMW 325cic 5MT  [0.00]
16 BMW R1200RT  [0.00]
http://www.cleanairforce.com/motoris...ked-questions/
What tests will be performed?
All subject vehicles will receive a three-part inspection:
An OBD test to check the vehicle’s emissions control performance history.
A fuel cap inspection to check for adequate seal.
A visual inspection of the catalytic converter to check for tampering or removal.
2014 535i XDrive Alpine/Mocha Nappa Contour
pf1020.00
      04-10-2019, 09:32 PM   #4
pf10
pf10's Avatar
An OBD test to check the vehicle's emissions control performance history.
I'm really worried about the obd test if anything is going to come up
      04-14-2019, 07:16 AM   #5
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
A lot of those tuners just block the check engine light from coming on due to the missing cats, faults may still be there. Personally I would say flash it back and install factory components that you removed.
pf1020.00
      04-14-2019, 02:19 PM   #6
pf10
pf10's Avatar
Thanks... I was able to check the cars readiness and it was not ready. My tuner was able to create a separate bm3 map to use to force ready. So I'm good.
      02-26-2020, 05:54 PM   #7
ActionGoat
Drives: 2014 435i
You say your tuner wrote you a separate tune that put your car in readiness for catless dp on bootmod3? Please share this tune with me! Or give me the name of your tuner. Thanks
