04-13-2019, 11:41 AM | #3 |
Rep 7,452
For every BMW I've owned that had this feature...it would run for up to 30 minutes then shut down. If your battery's power reserve starts dropping low (used to be 11.5 volts)...then it will shut off earlier.
The first two pics below are from the e38/e39/e53 era...and since BMW design architecture usually doen't change that much in regards to operational functionality...I doubt the time limit has changed...and would only be less, as mentioned, if the battery's voltage started to drop too low : {see parked car ventilation}
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-13-2019 at 12:01 PM.. |
