01-27-2022, 10:53 AM | #1 |
Rep 37
100k Miles
Finally hit it after 9 years.
I'm replacing the followings: Thrust Strut Engine Mount Rear subframe bushings Any other things I should go ahead and work on while its up on the lift? TIA! |
01-27-2022, 02:34 PM | #2 |
Rep 380
Drives: 2021 M550
StradaRedlands5953.50 rssazn1.00 |
03-04-2022, 10:41 PM | #3 |
Rep 3,581
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Water pump and 'stat are coming due. Depends on how much you like to gamble. Either way, coolant flush would be good. Brake fluid if you haven't done recently. Basically all the fluids.
OnlyGerman372.50 rssazn1.00 |
03-09-2022, 04:57 PM | #4 |
Rep 203
03-10-2022, 08:26 AM | #5 |
Rep 37
I went with these:
https://www.turnermotorsport.com/p-5...nstalled-arms/ Do it yourself, took me less than an hour... |
04-21-2022, 08:12 PM | #6 |
Rep 241
Finally joined the 100k miles club!
2011 535iX N55 own since 2015. Still running strong! Changed: Spark plug @ 86k Tranny fluid @ 86k Battery @89k (since 30k) Bleed brake fluid @ 80k Regular 10k oil change Brake pad, brake rotors, Tires Fixed: Replaced Water Pump @87k Door vapor seal leaking @80k Head Light condensation @85k Trunk door lift support @92k Installed: Backup camera, backup sensors. Apple carplay
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com Last edited by TZ; 04-21-2022 at 08:22 PM.. |
