2010 2011 BMW 5 Series Forum F10 2015 535i N55 Vacuum Pipe Connection |
05-03-2022, 01:13 PM | #1 |
Rep 86
Drives: 2023 BMW M3
Hi All,
I recently got into DIY car maintenance and noticed today that my 535i is missing what looks to be the vacuum pipe. I've been researching but can't seem to confirm where the vacuum pipe runs to and to add more confusion I've seen posts about that vacuum pipe is only needed for N55 with pneumatic wastegate and that BMW switched over to electronic wastegate in 2014. My 535i's production date is 11/2014 so I thought I was in the clear for needed it but when I went on to https://www.realoem.com and looked up my VIN the pipe shows up under the engine parts list (P/N: 11657588771). Is there a way to confirm if my specific N55 needs this vacuum pipe? And if so where does the pipe run to? |
05-03-2022, 06:36 PM | #2 | |
Rep 513
Drives: 2013 BMW F10 N55 535i XDrive
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
05-03-2022, 08:25 PM | #3 | |
Rep 86
Drives: 2023 BMW M3
12 Motor electronics 20 errors 140310: Misfire, cylinder 3: detected 140410: Misfire, cylinder 4: detected 140002: Misfiring, multiple cylinders: harmful to exhaust gas after starting 140302: Misfire, cylinder 3: harmful to exhaust gas after starting 140402: Misfiring, cylinder 4: harmful to exhaust gas after starting 231501: Error memory entry: Send buffer full 190302: Tank ventilation and purge air system, fine leak: leakage greater than 0.5 mm 140010: Misfire, multiple cylinders: detected 140410: Misfire, cylinder 4: detected 140002: Misfiring, multiple cylinders: harmful to exhaust gas after starting 140402: Misfiring, cylinder 4: harmful to exhaust gas after starting 231501: Error memory entry: Send buffer full 190302: Tank ventilation and purge air system, fine leak: leakage greater than 0.5 mm 140010: Misfire, multiple cylinders: detected 140410: Misfire, cylinder 4: detected 140002: Misfiring, multiple cylinders: harmful to exhaust gas after starting 140402: Misfiring, cylinder 4: harmful to exhaust gas after starting 231501: Error memory entry: Send buffer full 190302: Tank ventilation and purge air system, fine leak: leakage greater than 0.5 mm 21A023: Combustion engine: false start or engine stopped without driver influence I scanned using Bimmerlink via an Enet cable. Before scanning I did noticed a very rough startup (RPM would spike up and sometimes bounce a bit, but would eventually calm down) but no checking engine light and nothing on the iDrive console. You wouldn't happen to have any sort of picture or diagram showing the connection to the vacuum pump would you? I removed the completely airbox today in hope of a clearer view but still couldn't make out where the connection would go. |
05-03-2022, 09:39 PM | #4 |
Rep 513
yes you do have codes!!... wow.. yeah that's alot, to get to the vacuum pump , after taking the airbox out, that intake manifold has to come off, the pump is by the HPFP.. I'll try to find you a pic
05-04-2022, 11:01 AM | #5 |
Rep 2,637
RealOEM isn't always 100% accurate. For reference, the 2016 models in realOEM have it listed as well, and they're 100% for sure EWG cars.
I have a 9/14 car and don't have it as well. You're fine, it's meant to not be there. Clear codes and see what comes back, Bimmerlink doesn't differentiate between existing and stored codes.
2015 BMW 535xi
05-04-2022, 11:37 AM | #6 | |
Rep 86
Drives: 2023 BMW M3
05-05-2022, 10:05 AM | #7 |
Rep 2,637
Yes
2015 BMW 535xi
05-05-2022, 09:15 PM | #8 |
Rep 86
Drives: 2023 BMW M3
05-05-2022, 11:53 PM | #9 |
Rep 315
Drives: 2015 BMW 535i M Sport
I have a 2015 535i (10/14 Production Date) and don't have it as well.
I do, however, have some of the same codes as you (pulled from Bimmerlink as well) Specifically, the "misfire 3&4, multiple cylinders, harmful to exhaust" ones. I've never been able to clear these with Bimmerlink! I've installed new spark plugs & ignition coils (maintenance). I've never noticed a misfire and I've monitored the cylinders for misfire on multiple occasions (w/Bimmerlink). I'm assuming these are old stored codes in "Info Memory" (Bimmerlink terms) I've owned the car for about 10k miles and these codes have always been there. My apologies for highjacking this thread a bit, but..... Does Bimmerlink have limitations on the codes it can/can't clear? Am I missing something, like slight misfires on startup that are unnoticable? Do I need to get INPA or ISTA setup to clear these codes or at least diagnose them? I thought I read somewhere once that Bimmerlink can't clear codes if they are emmissions related but have no idea if that is true. Any input or feedback would be greatly appreciated!!! |
05-06-2022, 03:04 PM | #10 | |
Rep 86
Drives: 2023 BMW M3
Do you ever experience a rough startup? A while back I had to get new fuel injectors and a catalytic converter (the injectors failed while I was driving to work and caused a horrible misfire, and I mistakenly opted not to get a tow and slowly drove the car home which caused the catalytic converter to go with injectors). After I got new injectors, catalytic converter, and spark plugs the misfire went away but ever since then I've noticed that I would often get a pretty rough startup. As soon as I start the car the RPM would jump close to 2000 RPM and would sometimes bounce up and down, with very noticeable vibrations but after about 10 seconds or so it would calm down. I've driven close to 20K miles since replacing the injectors and catalytic converter with no errors present on iDrive and no check engine light. |
05-07-2022, 06:44 PM | #11 |
Rep 315
I experience a rough startup approximately once every 3-4 weeks (always on a cold start and my car is a daily driver). Similar to what you're describing @ noticable vibration initially, dies down in ~10 secs but I've never experienced a significan't rpm jump. Typically it stays in the 1000-1100 range.
We're you able to clear your "Misfire Cylinder 3 & 4, multiple, etc" related errors with Bimmerlink? I've been a 1st time BMW owner for about 8 months now. I purchased Bimmerlink & Bimmercode to help "get going" with DIY diagnostics. I figured those 2 apps were "Stupid Simple" enough to get me going and I wouldn't mess anything up with coding. I have to say, that for the price (~$35 each) they have more than paid for themselves already. I keep an OBDLink CX plugged in 24/7 and can use the dashboard feature on Bimmerlink to monitor readings anytime I want (like coolant temp, transmission temp, boost pressure, oil pressure, etc). BimmerCode was worth the $35 purely for the ability to kill the startup nag screen and the annoying constant seatbelt warning tone! |
05-08-2022, 11:38 AM | #12 | |
Rep 86
Drives: 2023 BMW M3
05-09-2022, 08:40 AM | #13 |
Rep 315
Plugs & Coils are definitely worth saving the money by DIY. Not too difficult but the #6 is a bit challenging to get access. The 3 torx bolts on the passenger side to break the wiring harness free are a PITA to access.
Everyone says the crankcase vent hose is the tough removal piece without breaking but I disconnected mine at the bolted side (instead of the 4 clip plastic hose side) and it came loose just fine. Good Luck and have fun! |
05-09-2022, 08:18 PM | #14 | |
Rep 86
Drives: 2023 BMW M3
Keep an eye on your fuel injectors - not sure if it's a common problem with the N55 or if mine were just a fluke. Gonna be avoiding off-brand gasoline in the future and sticking to Top Tier just to be safe (not even sure if this is a thing or just a myth tbh ). |
08-05-2022, 10:47 AM | #15 |
Rep 102
Hello OP,
have you cleared your 3&4 cylinder misfires or at least found out the culprit of it? Me and another user in the forum are having issues regarding misfires on those specific cylinders and its yet to be solved. It only occurs when the vehicle is fully warm and after shutting down the engine then start it up again. it would misfire for a while then throw a CEL with a drivetrain malfunction issue. I am looking at anything that can help us to diagnose this headache of an issue.. |
08-22-2024, 05:24 PM | #16 | |
Rep 78
08-23-2024, 05:21 AM | #17 |
Rep 102
Thanks for the reply but this was 2 years ago. indeed it was my HPFP. after replacing that all the misfires went away. moreover just for the ease of mind I also replaced all 6 coils a while after since they were a mix of original and used original which I found out by the marker that used parts shop put on their parts. Its running smooth ever since.
09-11-2024, 08:54 AM | #18 | |
Rep 78
