09-14-2020, 09:44 PM | #1 |
Rep 56
Overheating issue
2011 535 xDrive
These problems have not happened before. I have owned the vehicle for 5 years. Jumped in it Saturday afternoon, two problems at the same time? AC did not work, and overheated, quickly into limp mode. Checked coolant level, it was fine. When I removed the reservoir cap, it looked like the water/coolant pump was working. There was water flow thru the reservoir and there was a stream of water near the cap, I thought, the pump must be working. The alarm said engine area very hot. The electric radiator fan runs and kicks on high, air feels cool. (definitely not hot radiator). Running the heat inside on high, the air does not get warm. Let the car sit for 3-4 hours, drove home and overheat warning and limp mode 100 yards from the house. Ran thru as much diagnostics as I could tonight. Reservoir cap off, and ignition on, something is pumping coolant. Same issue, idle for 5 min and overheat alarm comes on. View post on imgur.com My first guess is that the thermostat is stuck closed. I just can not believe that the AC and the thermostat both died at exactly the same time. Usually it is blowing cold air before I put it in reverse. I was backing out of the driveway saying, what is wrong with the AC??? Having both of these symptoms at the exact same time, makes me wonder if my problem is even more mysterious. Deeper into ISTA, I see where the Aux Coolant pump recircs the water to electronics and the coolant reservoir. So this must be the action I see when looking in the top of the reservoir. With the ISTA, I was able to cycle the coolant pump on/off and heard absolutely No noise. (I wish there was some rpm feedback), So I think the main pump is bad. Need some logic/thought process check, please let me know what you think: 1. Replace main coolant pump. (Thermostat does not seem necessary. Is it like an extra 5 minute job, or possibly another hour? What about the lower temp thermostat?) 2. Is the AC, interlocked with the coolant pump? If the coolant pump does not come on, will the AC compressor be locked out? I figured I would find out after I replace the coolant pump. Thank you for Any advice!!! |
09-14-2020, 10:25 PM | #2 |
Rep 193
I've seen multiple over heating problems on 335i, all we're fixed with water pump/thermostat change. Don't be fooled with the stream from the reservoir, as you said it would be nice if there was a rpm sensor to see if the pump is actually working. Also make sure you bleed the coolant system properly as air pockets will give you overheating problems too.
09-15-2020, 01:55 AM | #3 |
Rep 1,357
I suspect a bad thermostat. If you have to replace it, go ahead and replace the water pump. It is recommended to replace both at the same time. It’s the same amount of labor since both are in the same spot.
09-15-2020, 07:18 AM | #4 |
Rep 1,868
Within a hundred yards of starting there would be no way to know the t-stat is bad, in my opinion, except perhaps for pins shorted to +12 or ground. There's no way temperature would build so quickly.
The pump, on the other hand, could detect 0 revolutions very quickly and pop a warning. I used INPA on my E90 to test the water pump, fan and all kinds of stuff just for kicks. It is annoying that ISTA doesn't give pump rev feedback. I haven't tried to run INPA on the F10. If it works, it might be a better tool for this purpose. With INPA you could request a target water pump % and read back the resulting RPM if my memory is correct. ALSO: for the pump you could try activation the bleed function. Turn on ignition, don't start engine, throttle pedal to the floor for 10s, if I remember correctly. You should hear it then, although if you are not accustomed to exactly how it sounds when everything is working properly it might not be a perfect tool. |
09-15-2020, 10:07 AM | #5 |
Rep 56
Thanks. With ISTA, there is a section in the DME to activate the water/coolant pump for 20S, I could not see (In reservoir) or hear any difference. I could turn all kinds of other things on and off, fans, relays, etc etc. I could hear them all but not the water pump.
I am ordering Pump & Tstat, plan to change them both, Ugh. Does anyone know if the AC will be disabled if the water pump failed? |
09-16-2020, 08:11 AM | #6 |
Rep 452
I just replaced my thermostat and water pump this summer. Only as preventative maintenance. Diy cost was $3-400. Kit from fcp euro. Not easy. But not hard. As I have active sway bar and awd. Coming from a e39 m54. Cooling system was Achilles heel for that car. So wasn't sure if it would also be for f10. I'm at 130k. So just peace of mind for me. But best to just do yours if you have high mileage/age. Only thing that doesn't make sense is how quick you said it overheated.
09-16-2020, 08:46 AM | #7 | |
Rep 912
Instgram @burninja
09-16-2020, 03:23 PM | #8 | |
Rep 56
Is that different than toggling the cooling pump on for 20 seconds in the ISTA ECU? Thanks! Anyone have a guess about the A/C being disabled with cooling pump not working? |
09-16-2020, 04:24 PM | #9 | |
Rep 247
Like I said however - that's nothing more than a guess. |
09-16-2020, 04:40 PM | #10 | ||
Rep 912
Instgram @burninja
09-17-2020, 09:10 AM | #11 | |
Rep 1,868
Or, using ISTA select that fault and calculate a test plan and do whatever it says. |
09-17-2020, 10:21 PM | #12 |
Rep 56
Started the repair tonight, the first of many questions:
1. Any good suggestions how to best separate the tstat housing and the hose from radiator? 2. The bolt that secures the tstat housing, (below the tstat housing). How do you get that bugger back in during install? |
09-19-2020, 11:39 PM | #14 |
Rep 639
Just did my thermostat and water pump on my 535 RWD. I ended up removing the radiator fan for more room, and didn't need to remove or lower the sway bar. And I found using a bit of butter made the hoses slide right on. I was really impressed with how much easier it made reassembly.
09-20-2020, 05:27 PM | #15 | |
Rep 56
09-21-2020, 01:13 PM | #16 | ||
Rep 639
10-19-2020, 11:20 PM | #17 |
Rep 56
This was a two week job, once I had all the parts, (pump and Tstat) Planning on burning up the entire Saturday. Well, the pump off and some BMW Engineer made a whoopsie on his calculation and there was this offset bracket to make sure the water pump would line up with the hoses about 1.5 shift in the bolts. It was just a flat plate with the bolt holes moved. Anyhow, this bracket was cracked, took me a week to get the bracket welded back up.
View post on imgur.com |
07-13-2023, 05:07 AM | #18 |
Rep 1
Check the radiators too; mine was completely blocked with dirt
StradaRedlands4775.50 |
07-13-2023, 03:48 PM | #19 |
Rep 2,878
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
