2010 2011 BMW 5 Series Forum F10 HELP 2011 535i transmission issue |
08-28-2020, 09:01 AM | #1 |
Rep 38
I was driving home on the highway at about 75. The gear icon and transmission malfunction popped up on the i drive briefly and went away.When i got off the highway the car down shifted normally. Then when i went to accelerate again trans popped straight into 6th with the warning light on. The car is FBO and running xhp. I used xhp to pull the code and its showing as 0x420022 EDS B short circuit to positive. Any one ever have a similar issue. Also to note i never had any issues prior trans shifted fine and smooth. Thanks any input is definitely appreciated.
08-28-2020, 11:00 PM | #2 |
Rep 915
If you remove xhp flash does it occur?
Instgram @burninja
08-29-2020, 08:15 AM | #3 |
Rep 38
Tevzadze2.047.00 |
08-30-2020, 10:51 AM | #4 | |
Rep 418
08-31-2020, 06:29 AM | #6 |
Rep 38
Yea its the zf 8 speed. Its just crossed over 100k the previous owner listed it as 1 of the things he did right before selling it. Of course there is no way for me to actually verify if he did or not.
08-31-2020, 07:39 AM | #7 |
Rep 210
It appears that "EDS B short circuit to positive" is a solenoid code from the mechatronic (valve body) unit. It could be a faulty or dirty solenoid. You could try removing the mechatronic and carefully clean it, especially the solenoids. If I were bothering to remove the mechatronic unit I would also install this: https://www.sonnax.com/parts/4590-zip-kit
BMW535iva280.00 jayster0966209.00 |
08-31-2020, 12:04 PM | #8 |
Rep 68
Drives: 2011 535ix M-sport
Or to verify that the previous owner used the correct fluid. Incorrect fluid could affect solenoid function. A good affordable first step would be to do a filter and fluid change with the correct ZF8 fluid to see if it improves the condition. If it doesn't, then you have a better understanding that the valve body may need to be dropped.
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
08-31-2020, 09:36 PM | #11 | |
Rep 375
09-01-2020, 01:24 AM | #12 |
Rep 915
Mine took a few more, just have to make sure car is running and went through gears and top off till it starts dripping then plug it. I used the liqimoly kit no issues.
Instgram @burninja
09-01-2020, 09:41 AM | #13 |
Rep 1,306
check out the thread it may help you.
https://f10.5post.com/forums/showthread.php?t=1652022 |
tet0010.00 |
09-01-2020, 11:33 AM | #14 |
Rep 915
MAKE SURE TO LOOSEN FILL BOLT BEFORE ANYTHING. When i loosened mine that bad boy was still torqued on since car was new it was tough.
Instgram @burninja
09-01-2020, 12:30 PM | #15 |
Rep 38
09-01-2020, 12:36 PM | #16 | |
Rep 38
1 question though maybe some one can help with. In all the videos it says to shift through the gears. My problem is that my trans will only allow 6th. I can delete the code through xhp and MHD. But it pops back up. |
09-01-2020, 12:36 PM | #17 |
Rep 375
I had a 2006 BMW 550i and the whole engine was rebuilt at 120k and then the tranny finally failed at 140k
09-01-2020, 01:48 PM | #18 | ||
Rep 915
Instgram @burninja
09-02-2020, 09:43 AM | #19 | |
Rep 38
Start engine Put foot on brake Shift transmission into "R" and "D" continuously Shift transmission in manual mode from 1st to 3rd and hold gear for 3 seconds Shift transmission in manual mode from 1st to 4th and hold gear for 10 seconds Select all gears in manual mode from 1st to 8th and hold gear for 10 seconds Keep engine speed at 2000 RPM's to ensure torque converter fills with fluid Check temperature and verify that fluid temp is between 30°C and 40°C |
09-02-2020, 11:58 AM | #20 | |
Rep 1,873
You can only do what you can - make sure you get the R and D part. FYI - the "foot on brake" part seems to be in question. Some of the instructions from ZF seem to have the wheels needing to spin. For what it's worth, a ZF8 that's stationary will only allow you to select R, 1 and 2 so without releasing the brake there will be nothing above 2 for 10 seconds. FWIW - ISTA+ has a full procedure telling you what to do and keeping the temperature reading on the screen at the same time. Just keep clicking NEXT and it lays it all out. If you're in full limp mode, stuck in 6th, personally I don't have a high degree of confidence that a fluid drain/replace is going to solve the issue without at least taking something apart in the mechatronic and cleaning it. I'll be tuning in for your updates though. |
09-02-2020, 05:26 PM | #21 | |
Rep 38
