2010 2011 BMW 5 Series Forum F10 F10 SE RWD Wheel Alignment - Aligned Out of Spec |
08-20-2023, 02:48 AM | #1 |
Rep 1
Got the attached alignment done on an F10 Standard Edition (SE) with stock everything / no modifications. Only found this in the car after the alignment was done. Curious about their specs for the rear camber and why they appear to have left it out of spec and in the red on their own print off.
I came across the below post where someone listed the specs for the F10 RWD. It looks like it's saying the camber on the rears should be -1° 50' ± 5'. My understanding is this translates to minus 1 degree 50 minutes (plus/minus 5 minutes). Which I think translates to 1.83 degrees (+/- .08 degrees). This would indicate that the machine used has the correct spec but they didn't align it properly. I had uneven wear on the front tyres, but not on the rears. Fair to say it looks like they didn't align the wheels properly? https://f10.5post.com/forums/showthread.php?t=1370169 |
