2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Suspension Upgrades for my new F10
      04-26-2015, 01:09 AM   #23
Boss330
Boss330's Avatar
Originally Posted by SonicEndeavor
Get high quality springs. AC Schnitzer (aka ACS) springs are amongst the best available, then drive the car for a few months. If after that initial period you feel you need sway bars, then you can consider them but creating a tighter coupling between the two sides of the car will decrease ride comfort on rough roads.
I drive a lot on rough roads here in Norway. The springs had a much bigger impact on ride quality than my M5 Competition Pack front sway bar and M550d rear sway bar. I installed the sway bars over a year after installing my Eibach springs. The springs firmed up the ride and improved it. The sway bars aren't noticeable under normal driving but shines when cornering at speed. The sway bars was a MAJOR improvement for handling, without a noticeable downside in everyday driving!
Eibach Pro Kit springs has a super ride, not bouncy and a perfect drop IMO.
      05-12-2015, 02:02 PM   #24
Ridiculous
isn't it?
Ridiculous's Avatar
Drives: tiag 2011 X6 5.0
Update: Just purchased the H&R springs. Combined with the new tires I just put on, I think I'm in for some fun.
      05-23-2015, 12:01 AM   #25
Ridiculous
isn't it?
Ridiculous's Avatar
haven't installed the suspension yet but will update once I do!
      05-24-2015, 12:46 AM   #26
mko9
mko9's Avatar
Drives: '11 535i
Another suspension upgrade to consider is wheels and tires. Ditching the runflats was good for a 7lbs weight reduction per corner. Buying some light weight wheels could push that weight savings up to nearly 15lbs. All of that weight savings makes it easier for your shocks and springs to absorb the bumps and keep your tires planted on the road.
Mike
'04 330i ZHP
'11 535i
      05-24-2015, 04:11 PM   #27
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Post some pictures when u do. A before and after!
      05-27-2015, 10:24 AM   #28
rd62
Drives: 2011 550i M Sport
What should the cost of a spring and bump stop install run? I'm thinking of getting mine done on my 550 M Sport.
      05-27-2015, 12:05 PM   #29
SonicEndeavor
Drives: 2014 535i MSport
It depends on where you live, but here in Southern California it's $350-$400 for installation. You'll need an alignment as well.
It's more uneven pavement that causes issues whenever you create a tighter coupling between both sides of the car. Any dip in the road that only impacts one side of the car causes the car to pitch more to that side rather than the suspension working independently. For some, the trade off of better cornering is worth it, but it's something to consider. If there was no penalty, the BMW would have designed the suspension with larger sways
      06-02-2015, 04:00 PM   #30
Ridiculous
isn't it?
Ridiculous's Avatar
I put on some BFG non-rfts and saw a big improvement actually
      03-29-2019, 12:41 AM   #31
BlackUnicornD
Drives: BMW F10 535d
Updates?
Looking for suspension upgrades for 2014 535d xdrive.
      03-30-2019, 12:20 PM   #32
Freak1c
Freak1c's Avatar
145
Drives: 2018 M3 ZCP MW
ACS is the way to go !
      03-30-2019, 09:40 PM   #33
windowmaker
Drives: 2013 550i M Sport 6MT
ACS is most expensive of all brands I've seen for springs alone. That and hardly anyone appears to carry them:
https://www.vividracing.com/schnitze...150778527.html
$741
compared to ~$300 ballpark for H&N or Dinan.
Does ACS really perform that much better?
      03-31-2019, 09:46 AM   #34
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
I had my ACS springs installed by what I consider a very knowledgeable independent garage that not only specializes in BMWs, but successfully races them as well. I asked him the same question, and his answer was something like this: ACS springs are specifically tuned for BMWs, not only for ride and performance, but also to work well with the existing shocks and suspension. With my experience being only on ACS, I cannot compare to H&R or others, but I do find that the ride is better than OEM - it is just as smooth, but now more defined and more precise. I can take corners quicker and the apparent weight of the car seems to be somewhat reduced. Of note is that I also have the adaptive shocks and roll bars, and the ACS springs also seem to work very well with both of those systems too.
Because I can, here's a recent pic of my 535xi on ACS springs.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      03-31-2019, 02:58 PM   #35
lsturbointeg
$741
ACS is known to be the least drop for the F10 for those who don't want to go as low as what H&R gives
      04-01-2019, 12:13 AM   #36
windowmaker
Attachment 2021912
That blue is sick.
      04-01-2019, 12:16 AM   #37
windowmaker
Might be the route for me in the future then. K&W coils and all other springs do too much of a drop for my taste since I'm concerned about going up driveways at some point :P
      04-01-2019, 03:46 PM   #38
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
That blue is sick.
I like it too. That's what's so cool about carbon black. It really is a dark blue like you see here, and seems to change colour depending on lighting conditions. That photo is completely original - no photoshop or post-production magic on it at all.
      04-01-2019, 04:32 PM   #39
lsturbointeg
I don't have problems going up driveways with my car as low as it is. it's called SKILL
      04-01-2019, 05:54 PM   #40
When I was looking for our 2014 Carbon Black/black was a requirement. I LOVE the colour. Looks black here...
cdmulders326.50
      04-10-2019, 03:45 PM   #41
Luky
Luky's Avatar
Drives: 2016 550i M Sport
I had been looking at the Bilstein coilovers (PSS10). Adjustable height with only 1/2" lower possible (it is never clear if that means 1/2" lower than stock or lower than M-sport which is already like an inch lower than stock).
I did not like the reduced H&R race spring height on my 535i as I would scrape and had to back into my drive/garage all the time. (Although it handled excellent with the M5 front sway and H&R rear sway + springs.)
