2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media What did you do to your 5 series today?
      01-21-2019, 07:48 PM   #1079
bigscore
Drives: 2018 BMW G30 540i M Sport
Originally Posted by xxpanipuri View Post
Installed new plugs (ngk) with .020 gap, so that I can now install my Mission Performance Stage 1 engine and trans tune...
Is that a requirement ?
The .020 gap ?
      01-21-2019, 07:52 PM   #1080
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by sesh1957 View Post
Great black Beamers, I am down to my wheels and reflectors, Isturbointeg, what did you use on the relectors?
Gold wheels looks good with the caliper match, I going black wheels with blue calipers.
I used the leftover shadowline trim kit i used on the windows frames for the reflectors.
      01-22-2019, 10:45 AM   #1081
xxpanipuri
Drives: 550i
The .020 gap ?
yes as per Alex@ mission performance....because they are advancing the timing as well as modifying other parameters...
      01-23-2019, 08:13 AM   #1082
fletchf
Drives: 2012 550i
New to me 2012 550i
Picked up a 2012 550i with 65k miles and an extended warranty. So far I have coded some things (Fog lights on at welcome, turn signals on HUD, music on HUD, tire pressure and temp, DVD in motion), also have a BMS Stage 1 to install and I am currently updating the maps on GPS. I need to do a paint correction once the weather clears up a little bit.
      01-24-2019, 10:03 PM   #1083
EinMeister
Drives: 2015 535i M-Sport
Originally Posted by F10ARNOLD View Post
Added black eyelids..
Still debating if I should keep it.. not really feeling it..
What you guys think?
Not diggin it at all
      01-25-2019, 07:45 PM   #1084
Agreed.
      01-27-2019, 11:31 AM   #1085
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Front brakes and painting....
Rotors - StopTech
Pads - OEM BMW
Sensor - OEM BMW
Dust Shield - VHT Primer, VHT Satin Black
Calipers - VHT Primer, VHT Titanium Silver Blue, VHT Clear
Rotor Set Screw - ECS Stainless
Lotsa hours prepping for paint. Tedious work. Very content with results. Will do rears in near future.
I was inspired by Member Tallest to paint in a light blue. Not an exact match to his; however, satisfied with subtle look.
Ickdeep5727.00
      01-27-2019, 03:05 PM   #1086
lsturbointeg
That turned out pretty SWEET! I'd like to upgrade my rotors to slot/drilled too!
      01-29-2019, 03:09 PM   #1087
lsturbointeg
Damn! need to get a trickle charger or something since my car is hibernating. went to start it and it barely cranked but it fired up. got a message about some electrical components will be turned off. anyone have recommendations for a charger since it's going to sit for another 2 months?
      01-29-2019, 06:42 PM   #1088
I got the BMW branded 4amp charger for something like $75 from the dealer. Just make sure you get an AGM compatible charger/maintainer. I've used a Deltran Battery Tender, but at 3amps it takes quite a while to recharge the battery. It's not that much less expensive than the BMW branded tender which is why I went BMW.
      01-29-2019, 07:26 PM   #1089
fletchf
Drives: 2012 550i
15 degrees outside so I washed it inside the garage, also installed the front plate without drilling holes in the bumper.
Ickdeep5727.00
      01-29-2019, 07:36 PM   #1090
lsturbointeg
so bro, do you just plug it in and forget about it? and i'm assuming I can plug it in the hood area or would I need to plug it from the trunk?
Must be nice! too cold here to wash cars!
      01-29-2019, 07:41 PM   #1091
svt1998gt
Drives: 2008 e90 335i, 2012 X5 M spor
Put the forgestars on the ride
I got my forgestars installed.
Ickdeep5727.00
Jason4916.50
ey2001310.00
Ulisse37.00
r2dmax58.00
      01-29-2019, 07:54 PM   #1092
lsturbointeg
very NICE! always like ForgeStars on the F10
      01-29-2019, 10:15 PM   #1093
so bro, do you just plug it in and forget about it? and i'm assuming I can plug it in the hood area or would I need to plug it from the trunk?...
Yup. I attached the pig-tails to the under-hood battery connections. I can then hook the car up any time I choose and leave it that way. Our trip last September I left my wife's car plugged-in for over 2 weeks. The beauty of the tender is you can leave it plugged-in indefinitely as it will charge the battery and then float the charge as needed.
      01-30-2019, 09:18 AM   #1094
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
What's the offset and size?? Any rubbing issues?
      01-30-2019, 09:23 AM   #1095
fletchf
Drives: 2012 550i
I used a rechargeable camp shower/hose in a 5 gallon bucket, it kept the water from going anywhere but on the car and to the garage floor.
That looks sick! Perfect stance!
      01-30-2019, 01:48 PM   #1096
svt1998gt
There is slight rubbing but i am running kwv3 at a pretty aggressive stance.
I have f14 dc and sdc 20". Hope that helps
      01-30-2019, 02:14 PM   #1097
OrcaPod
Drives: 2011 BMW F10 528i N52 engine
I got this one - CTEK 40-206 MXS 5.0-12 Volt Battery Charger . Used it few times on my car ( AGM 92ah battery )
      01-30-2019, 05:35 PM   #1098
I used a rechargeable camp shower/hose in a 5 gallon bucket, it kept the water from going anywhere but on the car and to the garage floor....
Shoot..... Just attach a hose to the water heater!!
      01-30-2019, 10:45 PM   #1099
jayster0966
jayster0966's Avatar
Drives: 2011 535i
Installed my Wagner FMIC in preparation for installing Pure S2 Turbo next week.
ey2001310.00
      01-30-2019, 11:20 PM   #1100
ey2001
ey2001's Avatar
310
Nice!!
