2010 2011 BMW 5 Series Forum F10 Headlights right side BMW F10 |
04-19-2022, 12:33 PM | #2 | |
Rep 179
Drives: BMW 535i F10
Open the the hood and right above the headlight there is a black triangle-ish plastic, you can open it and then you will see a headlight cap. Turn the cap to the left to remove it and leave it open for a few minutes. My driver's side headlight started to condensate after snow - water drops would appear inside the headlight after every wash. Then i opened that headlight cap and left it for like 20-30min and it solved the condensation for me. You probably would want to protect the headlight from dust - i used a cloth to cover it and give a place for air to come out from the side |
04-19-2022, 05:43 PM | #3 |
Rep 172
I'm not sure about LCI models, but early models also have a cap accessible through the wheel well. Rig some string on a couple of desiccant packs and put them in both holes. That should help with drying. A hair dryer on low setting will work. too.
04-20-2022, 05:47 PM | #4 | |
Rep 229
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
06-02-2022, 04:06 PM | #5 |
Rep 2
06-03-2022, 07:04 AM | #6 |
Rep 80
I've found that removing both caps, cleaning the existing rubber seal and then rubbing the smallest amount of vaseline and then closing them again will stop condensation.
I wouldn't be drilling a hole. Just my 2 cents... |
06-03-2022, 08:14 PM | #7 |
Rep 229
I drilled a 3/8" hole on each cap and leave them open for 6 months now. So fare so good, no more condensation.
06-19-2022, 03:28 PM | #9 | |
Rep 2
Had to replace one headlight driver module due to corrosion a couple of months ago, and was afraid it would happen again..Now, finally, I think my issues are gone. Last edited by PeterPersson; 06-19-2022 at 05:03 PM.. |
OnlyGerman363.50 |
06-19-2022, 10:32 PM | #10 | ||
Rep 1,261
The moisture has to come in from somewhere to mess with those modules, so it's just figuring out where. |
