2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Carbon black.....
      07-06-2017, 04:26 PM   #1
Mogwai888
Mogwai888's Avatar
64
Drives: iX3
Carbon black.....
......paint looks lovely when clean, but I can see it requiring regular attention.
Do any of you, especially carbon black owners, have any tips to maintain the car looking 'clean' between washes?
I've read detailing sprays can be quite good....any recommendations?
Thanks
      07-06-2017, 04:40 PM   #2
MrPogle
MrPogle's Avatar
Drives: F10 550i M-Sport LCI
Get a detailer to polish out all the fine scratches and apply a ceramic-type coating. Wash the car before it gets horribly filthy using as little physical rubbing as possible. After each wash apply something to give a strong hydrophobic finish. I use Sonax BSD which I find works very well on Azurite Black which is similar to Carbon Black.
www.detailingworld.co.uk might be a place to check out but it's a bit like going to a beer-festival when you want a pint.
      07-06-2017, 05:09 PM   #3
Mogwai888
Mogwai888's Avatar
64
Drives: iX3
Thanks for the link MrPogle
Have been contemplating a detailer, but call me weird but there's some satisfaction and pride in keeping your own car clean. That's if I can find the time.
Will check out the Sonax product. Cheers.
Oh - nice motor BTW
      07-07-2017, 02:06 AM   #4
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
Agree with Mr Pogle, get a two stage correction done by a reputable detailer and have a ceramic coating plus a glossifier applied. I had this done to mine and the coating reduces the amount of dirt and grime that sticks to the car, the dirt also comes away easier when you jet the car. This will get your paintwork back to or better than the original factory finish and remove all blemishes.
Then you can maintain it yourself, always use the two bucket method when washing and use a snow foam to lift dirt beforehand if you can. My E70 was carbon black and this colour is stunning when polished up and in the sunlight
      07-07-2017, 02:53 AM   #5
MrPogle
MrPogle's Avatar
You can't go wrong with the 2 bucket system but you may want to try the following which I find easier and works well.
1. Use 1 large bucket filled with clean water but must contain a grit-guard.
2. Put the correct amount of car-shampoo for a bucket-full into your snow-foam lance with 1 litre of water.
3. Use a proper wash-mitt not a sponge.
Then, spray on the soap a couple of panels at a time and wash down with the clean water and mitt. The soap won't be as foamy as snow-foam but it is very easy to see if you have missed any bits with the mitt as it tends to visually "cling" to the dirt.
The grit guard should ensure you have no serious contamination to the rinse water and you aren't rubbing the panels quite as much as when you use 2 buckets.
Below is my shiny car.
en1gma200.00
      07-16-2017, 01:58 PM   #6
shiner
Drives: 535D MSport Touring
My last car before my current one was a Carbon Black 530D. I struggled to keep it clean. It shows up the slightest dirt.
2015 F11 535D M Sport Touring, Space Grey, VDC, HUD, Comfort Seats, Sport Auto, Pro Media. GONE
2013 Z4 35is + tons of options. CURRENT
