2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Activating the exhaust valves on F10 535i, coding, need help!
      04-25-2019, 02:00 AM   #1
ssneck
Drives: BMW F10 535i
Hi everybody!
I have the car BMW 535i N55 with installed exhaust from the M5. On the new M5 mufflers there are vacuum valves. Stock 535i does not have vacuum control for exhaust but I really want the flaps to work as intended by BMW!
How flaps work on the M5:
- vacuum through the tube comes from the engine in the trunk and there it is connected to the solenoid valve, this solenoid is controlling the vacuum valves on the silencers;
- the solenoid valve is controlled by the DME engine module, it gives a signal to open the flaps, depending on the gear, rpm and engine load.
After studying how it works on other BMWs with the same N55 engine and the same DME engine module, I found it is the same! And not only with the N55, with other engines, where there are vacuum (not electric) valves, the principle of operation is the same everywhere! For example, in the X3 F25 with the N55 engine and the same DME there is a mufflers with a vacuum valves and its algorithm and the electrical valve connection circuit in the trunk to the DME under the hood, exactly the same as the M5.
I have connected the solenoid valve according to the circuit diagram from Rheingold: one pin to the power supply through a fuse, and the other pin to the signal from DME (pin #3 in the connector A211*1B), see photo below.
Name:  viber image 2019-04-18 , 16.47.41.jpg
Name:  viber image 2019-04-18 , 16.47.44.jpg
Solenoid valve in the trunk:
Name:  viber image 2019-04-18 , 16.47.48.jpg
How flaps are opened/closed depending on the gear and engine speed (always the same for all F-series BMWs with a vacuum valves):
Name:  viber image 2019-04-18 , 16.47.49.jpg
Conclusion: my DME F10 n55 module will can give a signal to open the flaps for sure! But it needed only to CODE it correctly!
Then, in order to understand how to send a signal from DME to the solenoid valve, I started looking at E-sys, and in the DME settings I found 3 settings that, in their name, are related to the exhaust valves:
DME->AGK-Config (AGK-config)
Comment: Abgasklappe - (AGK) Konfiguration
Wert_00 (value 00) = 00 - (default for F10 N55)
Wert_01 (value 01) = 01
Wert_02 (value 02) = 02
Wert_03 (value 03) = 03
DME->Konfiguration Abgasklappensteuerung (Exhaust valve control configuration)
Comment = Abgasklappenregelung - (AKR) Variante
initwert = 00
Wert_25 (Value of 25) = 25 - (default for F10 N55)
DME->AKR-Variante
0x00 - Variante 0 aktiviert - (default for F10 N55)
0x01 - Variante 1 aktiviert
0x02 - Variante 2 aktiviert
0x03 - Variante 3 aktiviert
Then I connected the valve in the trunk as per the circuit diagram, placed it in the cabin, connected a voltmeter to it and played with different variations of these settings for several days, but I could not get the long-awaited signal from DME . Most likely I need something else to code! And I don’t know what... Please help me with ideas on what to code, so that DME will give a signal to open the flaps!
Also I'm ready to provide access remotely by teamviewer and pay for the works!
Also, if someone can drop me the CAF file from DME (from F-series car with vacuum exhaust valves) to compare settings, I would be very grateful!
To those who read it - thanks!
SWFLf10379.00
_des_20.50
      04-25-2019, 02:37 PM   #2
ssneck
Solution was found!
You have to flash DME with MHD Flasher and select checkbox: Exhaust burble. Then configure sliders as you need.
Also select "exhaust flaps always open in Sport mode", if need it.
Name:  Screen Shot 2019-04-25 at 10.26.47 PM.png
This is perfect solution if you installing M5/M6 to F10 535i mufflers or others with vacuum valves. Just connect vacuum line from the engine bay to vacuum solenoid. And connect vacuum solenoid to DME. Now at low RPM no any drone and at high RPM I can hear awesome sound of my exhaust with opened flaps. MHD Flasher made all the work and flaps will work correct with your BMW!
      04-28-2019, 08:19 AM   #3
lzap
Drives: 2013 BMW 535i 6MT
Thank you for this, this is great info I was looking for. Was the wiring in the trunk there for the solenoid valve? Or did you have to run the wiring?
      04-30-2019, 05:30 AM   #4
ssneck
There is no wiring for the valve in the trunk. I have connected vacuum line and wire connected to DME (pin #3 in the connector A211*1B), then vacuum and valve signal wire was layed to the trunk. Then vacuum line from vacuum valve was connected to the muffler.
      04-30-2019, 05:35 AM   #5
ssneck
Also later I can make a photo where the vacuum line is connected under the hood.
      04-30-2019, 01:16 PM   #6
HizEternal
Drives: Jet Black F10 535XI
Thank you for your efforts. Pictures would be greatly appreciated.
      05-01-2019, 02:57 AM   #7
ssneck
To connect wire to DME you have to find right pin, I do not know original part number, I just found it in my garage and it fits to this connector. Also be careful with DME connector it is easy to damage it. To open this connector you have take off the lock.
Еxample how to disassemble the DME connector how looks needed pin:
Also to lay vacuum line inside cabin i drilled the hole in the rubber bushing (see on the picture). You have to drill from the cabin, BMW located the dot to make sure you will not drill the wiring. You can see this dot from cabin.
Last edited by ssneck; 05-01-2019 at 06:30 AM.. Reason: added photo for DME connector
      05-02-2019, 06:57 AM   #8
lzap
Thank you for the detailed pics, your car looks great!
      03-31-2020, 10:06 PM   #9
superskaterxes
Drives: 2013 F10 M sport
Originally Posted by ssneck View Post
Solution was found!
Attachment 2039558
Once you figured out that you had to check the boxes in mhd, did you still have to do the coding in esys?
Whats the part number of the solenoid valve?
      04-01-2020, 02:51 PM   #10
ChampagneQrtzPapi
Drives: BMW 535i
Coming from an M235i, I've recently wondered if this feature was available on the f10 chassis. Awesome info!
      04-04-2020, 09:35 AM   #11
mfractal
VAG Survivor
mfractal's Avatar
40
Drives: E90 335i
I know it's been years but for whoever's instersted, solenoid's part number is 11747810831
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
      04-20-2020, 12:12 AM   #12
Bmwdoubles_
Bmwdoubles_'s Avatar
Drives: BMW F10 535
  [0.00]
Attachment 2043897
Attachment 2043920
Nice work!
Once you have the clip off the harness, what's the safest way to remove the pin from the harness? Do you depress down or push out with pin removal tools?
From the image It looks like you depress from the top of the pin and not from within the center of the pin.
This might not be the right pin picture, but it looks like the center?
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg
      04-23-2020, 10:27 AM   #13
naCAnItihS
Drives: 2011 BMW 535i MSport
Originally Posted by Bmwdoubles_ View Post
Nice work!
From what I understand from this thread you are not removing a pin but adding one to the connector. You shouldn't have to remove any. However there is a special insertion/extraction tool (they are cheap) to remove those pins. You stick it in from the mating end.
I do wish we knew the correct p/n for these pins so I could buy them as I will be doing this sometime in the next few months. Also size and length of vacuum line would be helpful to know how much to buy. Also is this like 18/16 gauge wire?
Anyone have this info?
MODs: "FBO" VRSF Downpipe, VRSF Chargepipe, BMS CAI, GPlus FMIC, GFB DV+, Walbro 450 LPFP, MHD Stage 2+, 20" HRE FF01, KGSplitters 5-Piece Kit
      04-23-2020, 03:48 PM   #14
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
awesome but damn, you need to clean your engine bay! that's alot of dirt!!
      05-06-2020, 02:11 PM   #15
naCAnItihS
Ok I think I figured out all the information I was looking for before.
I bought the solenoid (BMW 11747810831) on Ebay with the mating connector and a few inches of wire lead for $9.99 shipped.
Looks like the wires on the solenoid harness are: Signal to the DME is 22 AWG aka 0.5 MM2 (Brown w/ Gray stripe) and the Power wire is 16 AWG aka 1.3 MM2 (Red w/ 2x White stripes).
According to Real OEM the pin we need for the DME is a Terminal Socket MCON 1.2, 0,5-0,75 MM²/AG. Which is 22-20 AWG wire (0.52 MM2).
TE 1534594-1 for 22 AWG $0.27 each
https://www.digikey.com/product-deta...8CT-ND/9606865
And the vac line seems like it is 4mm ID which is 5/32"
So I would suggest buying a few pins and approx 25-30 ft of wire and that size vac line and Y or T junction and we should be good to go.
      08-05-2020, 10:38 PM   #16
Brant
Taiwan
Drives: BMW F31 320i
Hi naCAnItihS,
Would you please share more detail or photo for how to plug/wiring the both signal to DME and the power ? Currently doing research for 320i (N20) but no any clue is available, not to mention the wiring from DME to rear trunk, would be very appreciated if you could provide some help, thanks in advance.
320i N20 8AT | Öhlins DFV Suspension | RAYS 19" ZE40 w/ PS4s | BM3 Stage2 91 | MP Brake Kit | WT Competition FMIC EVO 1 | HJS Euro 6 200Cells Catalytic DP | ARQRAY Performance Exhaust | GFB DV+ Blow off Valve
      05-17-2021, 11:55 PM   #17
slw535
Drives: 15 535i xdrive
Thank you for this how-to!
What is everyone tapping into for power wire to solenoid ?
      07-19-2021, 11:04 AM   #18
bigshout
Drives: F10 535i
naCAnItihS were you successful with this installation? Any additional photos you can share, like pipe route through cabin, access points in the trunk to get the exhaust valves
      08-22-2021, 04:50 AM   #19
Kannon25
Drives: BMW 5 Series
Has anyone managed to find the route from the engine to the trunk (I am more interested in the cabin route)? And also, do I have to drill some holes from the trunk to the exhaust valves?
      08-23-2021, 07:19 PM   #20
M@rkus
Drives: BMW F11 535i
At least in F11 there was a plugged hole readily available in the left back corner of the trunk (on side of the trunk) for the vacuum line to mufflers. I just took off the original plug and put in the correct part number cable grommet for the vacuum line.
I routed the vacuum line and wire from ECU through the upper left corner area of the firewall, close to the brake booster. Someone else had already made a hole there in the wiring grommet for routing JB4 wiring.
      08-24-2021, 05:42 AM   #21
Kannon25
Originally Posted by M@rkus View Post
At least in F11 there was a plugged hole readily available in the left back corner of the trunk for the vacuum line to mufflers. I just took off the original plug and put in the correct part number rubber boot for the vacuum line.
I routed the vacuum line and wire from ECU through the upper left corner area of the firewall, close to the brake booster. Someone else had already made a hole there in the wiring rubber boot for routing JB4 wiring.
That sounds great! And to lay it in the cabin (I imagine you don't see the wire and the vacuum line) is it straight forward? Like that is the default route and I will find my way to the trunk easy? If you could provide a little more info on the cabin routing would be amazing!
Also if you have the part number for the rubber part would be amazing.
      08-24-2021, 12:49 PM   #22
M@rkus
Sure you don't see the vacuum line and ECU wire when everything is assembled.
I removed the plastic covers inside the car from bottom of A-pillar, door sills and the bottom part of B-pillar and in addition the bottom part of the rear seat and the leftmost part of the backrest of the rear seat. Then I placed the vacuum line to go the same route with cars wiring harness that goes from front to back on that side of the car in the door sill area. So it's gonna take some time if done properly.
You can see all the parts from the M5 part list (see the link below). It's the part #4 in the picture. Also buy the T-connector #5. I also bought the #2 so the solenoid valve sits in correct place with full OEM mounting. There was a slot for that mount too readily existing. So these would be needed,
18307551543
61131361918
11721439973
M5 Parts list
It also makes sense to buy one straight vacuum line connector in case you need to make a joint at some location:
11657803012
The smaller one of the connector pin part numbers below is suitable to fit the fuse box (don't remember anymore which one of those was the smaller one), so you can add the solenoid operating voltage connection to the correct slot in the original fuse box on the right hand side of the trunk. In F11 the correct fuse location is #36 (5A). It's important that the operating voltage feed is behind the ignition key (15) and not in continuous power (30). In my case temporary connection directly from battery + (with a fuse) emptied the battery partly over night (ECU pin seems to be grounded when ECU is without power).
61130007437
61130007440
And finally the correct ECU pin is:
12527581158
And this is how it looks finally from outside (all done with OEM M5 parts):
