2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW Speaker polarity
      09-11-2016, 10:01 AM   #1
gtthree
Drives: F10 530d
Guys
I could do with some help.
I am part way through my audio upgrade to an Eton DSP,8 CAN as my car was built with european base audio.
I am mounting a HK centre speaker and tweeter, however I would like to know form the picture what is the +ve and what is the -ve terminal as I need to run my own centre channel wire and terminate with a BMW speaker connector.
Is the top pin or the lower pin?
Note the picture is from a base speaker.
Thanks
      09-17-2016, 08:57 AM   #2
claykin
Drives: various BMW
Google search "how to check speaker polarity" . You'll see many results that will prove helpful.
Simple test with 9V battery and watching to see which way the speaker cone moves.
2023 840GC | 2021 740i | 2019 X3
      09-17-2016, 10:34 AM   #3
gtthree
Drives: F10 530d
Thanks claykin
I wasn't aware you could do that test.
I end up removing a rear speaker and cross checking the speaker wire colours (colors) to a wiring diagram.
For other users the pin nears the centre of the speaker is the negative.
      09-17-2016, 07:43 PM   #4
FaintReality
NoUSE4aName
18
Drives: 07 BMW 550i
I use the battery method.
      09-26-2021, 01:16 PM   #5
abbas_basil
United Arab Emirates
Drives: BMW F10 2015
I am also doing the exact same upgrade.
I am upgrading from base stereo to a JBL DSP 4086. I am creating pins for all my speakers as I want to keep all wiring as original as possible.
I did a battery test and here are the results. By having the polarity correctly connected to a 1.5V AA battery the speaker cone should extrude outward.
