2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BimmerCode and Sport+
      02-28-2019, 01:50 AM   #23
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Interesting, I recently saw the Sport+ option in BC. I will have to to get back in there.
      04-14-2019, 07:04 PM   #24
ColiFeCape
Drives: 2017 435dx F32 M Sport
Sport+ in Bimmercode wasn't available for mine so started using E-sys now for coding VO and found it fairly easy with a bit of reading.
Changed my 2TE to 2TB, coded in ECU's kombi and icm.
Reset clock and all works flawlessly Sport+ now available as a fourth option and shows up in Idrive graphic as well.
      06-22-2019, 06:11 PM   #25
expl0de
Drives: BMW f30 320d and e92 320i
Kombi and ICM is for visual stuff, but you also have to code transmission ECU for the faster shifts.
On a bmw f10 lci with EDC to add sport transmission I just went to EGS and set sport transmission to active. This also added sport+ with visualisation in KOMBI and instead DS shows gear number.
On the other hand on my f30 pre lci I have sport auto from factory and coded it to regular the same way. This only made shifting in sport a bit less agressive(without kick in the back) and when I accelerate and release the gas pedal the car shifts to higher gear and doesn't hold 3500-4000 rpm like before. When using kickdown it still holds gear longer.
The other stuff like sport+ and shift paddles is working like before. So it depends on the year and model, I guess, how the modules are coded from factory and what have to be done.
Bimmercode was used.
      06-23-2019, 09:43 PM   #26
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I don't find this true on the F10, nor have I ever interacted with anyone who has. On other chassis series, VO coding 2TB can affect shifting. On my chassis it made absolutely no difference. I should also point out that I have no DEC switch, and maybe this is part of it.
What made a HUGE difference was XHP transmission flash.
      05-23-2021, 08:02 AM   #27
1Quick545
Drives: BMW 535 and X5
Is there a walk through to activate Sport + with BimmerCode? It would be appreciated!! Thanks.
      05-23-2021, 10:16 AM   #28
Hoa
For F10, you can't do it on BimmerCode. You will have to use E-Sys and VO code the vehicle. You must delete 205 and add 2TB in order to get sport+.
https://f10.5post.com/forums/attachm...8;d=1421684088
      05-23-2021, 01:19 PM   #29
gdotgreen
Drives: 2013 BMW 528i
Must've been an update because I was able to add Sports+ to my 2013 528i after random IG looking through the app. It almost shocked me because I had given up on the idea. But it was definitely there and now definitely on my car now. So you guys may want to double check again.
      05-23-2021, 05:39 PM   #30
1Quick545
Okay cool. Can I use Vgate with esys? Or only enet connection?
      06-11-2021, 11:08 AM   #31
Ccs1979
Drives: Bmw f10 523i
Hi guys, newbie here... I just get my f10 523i 2 day ago, I hope to get the sport plus mode and ambient light change, I only have normal drive, no other mode to select. Pls guide me, as my friend tell me bimmercode can get it, is that true?
      07-15-2021, 12:50 PM   #32
gdotgreen
Yes you can. Here is a screenshot.
      09-10-2021, 12:13 AM   #33
Jer_i_miah
Jer_i_miah's Avatar
Drives: BMW 535i
Originally Posted by _GW_ View Post
My 2013 535i M-Sport originally came with:
-SPORT
-COMFORT
-ECO PRO
I had someone code it for SPORT+ and now I see:
-SPORT+
-SPORT
-COMFORT
-ECO PRO
Later on I discovered the BIMMERCODE app and used to aktiv(ate) SPORT AUTOMATIC TRANSMISSION (SAT).
Before coding SAT, my cluster would show DS when the car was in either SPORT or SPORT+ mode. After coding SAT, my cluster shows S1, S2, all the way up to S7. It never shows S8 even though I have ZF 8-speed transmission.
Now I wonder if I had discovered BIMMERCODE earlier and used it to enable SAT, then would that have caused SPORT+ mode to also appear without having to do any separate coding. Funny thing is that I don't even use SPORT+ anymore because I can't tell the difference between that and the regular SPORT mode.
Mine doesn't have Eco Pro mode. That's weird. I have sport +, sport, normal, comfort. 2011 535i.
      09-21-2021, 03:58 PM   #34
lokis123
Drives: F!0 525i
What i must change in r-sys to activate sport + ? or i must use difertent software ?
      09-27-2021, 06:45 PM   #35
Hasibjan
Drives: F10 530d M-sport
-SPORT
-COMFORT
-ECO PRO
-SPORT+
-SPORT
-COMFORT
-ECO PRO
Hi everyone, sorry new here. Is this possibnle on different engine variants? I've got a 530d and also currently have the above 3 options but would like sport+ is that is possible?
Thanks
