2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Anyone using solid rear subframe bushes/mounts or inserts?
      04-01-2023, 11:49 PM   #1
simt
Australia
Drives: F22 m235i, F10 m535i
Hi all,
I'm looking for sollid rear subframe bushes/mounts for the F10 535i.
I've got solid aluminum ones on my m235i. -It made such a good difference to how that car handled. I consider it mandatory now for any new car I get.
However I can't find solid rear subframe bushes for the F10 5 series. -There's no M5 part to use, subframe is just bolted directly. Anyone know if solid mounts are avaialble for our series?
I've found inserts. If someone here has those, can they comment on how they've found them?
-Sim
      04-07-2023, 07:01 PM   #2
simt
Australia
To anser my own question:
I looked more into the inserts. Looking at various writeups of them on other cars. They'll be good. The inserts, especially the metal ones, will eliminate the side ways flex that can make the rear end feel so vague and unconnected during cornering.
-Simt
      04-18-2023, 10:06 PM   #3
cb2004mj
Drives: 2014 535d
Got any links to the inserts you've found?
      04-21-2023, 11:03 AM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
are you guys referring to the diff insert?
      04-21-2023, 08:34 PM   #5
SWFLf10
SWFLf10's Avatar
I believe they are talking about the subframe bushings. As mentioned above, the M5 doesn’t have these, as it’s directly bolted with no bushing at all, so no retrofit easily possible for this.
Some cars they made inserts for look similar to the diff inserts, just for the subframe bushings. Also similar to the engine mount inserts.
      04-23-2023, 11:03 AM   #6
Double Nickel
Double Nickel's Avatar
Drives: BMW F10
2015 BMW F10  [10.00]
You tried these?
      04-23-2023, 11:08 PM   #7
lsturbointeg
Originally Posted by Double Nickel View Post
You tried these?
i will be installing them shortly
      04-24-2023, 09:40 AM   #8
95blkmax
Drives: '11 535 M-Sport
You will love it Gene. I just installed it yesterday and what I thought was just "harsh shifting" in Sport+... turned out to be the rear diff flopping about. So now even in S+ shifting the car is dead solid. Just clean pull through the shifts. No bucking about going on and off throttle either.
2011 F10 Shuenk N55+ Turbo'd is SOLD. Building a 2018 Golf R!
Unspec1380.00
      04-24-2023, 02:01 PM   #9
Unspec
Unspec's Avatar
1380
Drives: 2015 BMW 535xi
I wanted one but the $120 price is...tough.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-24-2023, 02:55 PM   #10
95blkmax
Agreed. But the alternative is OE or Urethane mount (~$75 shipped), then the special tool that you'll only use one time ($200???), and ability/ time to lower the diff so you can get the tool in place to press out the old/ press new one in.
In comparison, this took me about 15mins. All I did was backed up on to ramps, knocked loose the bolt and nut (both 21 or 22mm, forgot now), pushed in the insert, and put new bolt and nut in. Rolled off the ramps and all done!
      04-24-2023, 04:12 PM   #11
Double Nickel
Drives: BMW F10
Who 's the seller of these again?
      04-24-2023, 06:09 PM   #12
lsturbointeg
that's good to hear! i got a pretty good deal on it because i'll be making an install video! I also ordered BimmerHaus's intake system. should be arriving soon. Glad to hear from you guys again. i've been busy lol
      04-25-2023, 12:14 AM   #13
Unspec
Unspec's Avatar
1380
Bimmerhaus, aka BrowBMW on the forums
2015 BMW 535xi
      04-25-2023, 06:11 AM   #14
95blkmax
Bimmerhaus Performance. He's here on the forums as BroBMW
      04-26-2023, 08:58 PM   #15
Unspec
Unspec's Avatar
1380
After getting tired of the thumping around in hard shifts from the rear end, decided to pull the trigger.
Hopefully some grease will help with the install a little.
2015 BMW 535xi
      04-27-2023, 07:22 AM   #16
95blkmax
Awesome dude! Check out my YouTube channel linked in my signature. I released an install and review vid last night. Hope it helps ya!
      05-11-2023, 09:29 PM   #17
Unspec
Unspec's Avatar
1380
Installed. Inserting the insert was really easy. Slipped right in, didn't need to force it at all. Getting the actual two bolt holes lined up was a different story. I guess my car was too light or something, but even with the diff jacked all the way up I had to add extra weight to my car. Threw tons of random heavy shit into my car to weigh it down lol. Tried to tighten it down by the nut side but there was no space, so I did the bolt side. Nut torque is 175nm, so bolt you add 10%, so in this case 192.5nm.
My diff bushing was actually still fine, so hopefully this helps still.
2015 BMW 535xi
      05-11-2023, 09:37 PM   #18
BimmerHausPerformance
BimmerHausPerformance's Avatar
522
Drives: F10 S55, E93 M3, E89 N54
2008 BMW e93 M3  [0.00]
2012 BMW Z4  [0.00]
2011 BMW 535i  [10.00]
Nice! Let us know how it feels!
2011 F10 S55 6MT
Website Instagram YouTube
      05-12-2023, 04:16 AM   #19
Double Nickel
Drives: BMW F10
Thanks for the heads up on install, ordered mine the other day.
      05-13-2023, 02:48 PM   #20
95blkmax
Awesome Unspec! I've been enjoying mine ever since. All the slop that I had with my split bushing is gone
      05-14-2023, 09:08 PM   #21
Unspec
Unspec's Avatar
1380
Drove from South NJ to NYC, so still a first impression. However, it definitely has made the shifts in sport+ "snappier". There's still obviously some lurching since power is being cut and shifts are never literally instant, but it has turned the large lurching into more of a snap. It feels more like a giant rubber band snap rather than being shoved. 1st to 2nd is still more violent than the other gears, but I think it's to be expected as that gear shift seems to be universally agreed to be the harshest one.
Overall, pretty happy with the insert. Only bit of feedback would be to maybe make it idiot proof and just have the bottom prong of the insert also be mirrored at the top, so that there's no true top/bottom. Or print a small arrow on the round part holding all the inserts that points up, giving a visual indicator that you inserted it correctly.
Yea, the adding weight thing was the hardest part. Add weight, check alignment, add weight, check alignment. Rather annoying. My suggestion is to make sure you have a full tank of gas, and then remove just the nut first. After that, start adding weight to the car until you can remove the bolt with just moderate force. That way, you know that when you remove the bolt, the two holes are already lined up and it'll be easier to install.
2015 BMW 535xi
      05-14-2023, 09:10 PM   #22
522
2012 BMW Z4  [0.00]
Arrow is a good idea! Ty.
2011 F10 S55 6MT
