2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Adaptive LED Replacement TMS coding
      06-25-2022, 12:40 AM   #1
rkl
New Zealand
Drives: BMW 320 e90 BMW X1 e84
Hi team
Have had the issue with water in the passenger light (any tips on finding the ingress spot)
Have replaced the TMS after got a stack of warnings.
Now all but the low/high beam work. and have a adaptive headlight error.
TMS 41 and 42 showed on esys, but had to update my esys after the pszd files were too new.
After updating now on 42 shows, however this is the replacement I think as esys shows this as a replaced ECU.
Done the read FA, activate, read swt, detect CAF, chose the.last on the list and coded.
This coded fine, however on ISTA there is no communication from STML, and therefore I am unable to complete the run in procedure
Would love some advise.
Could it be a faulty TMS, or maybe one of the modules wasn't plugged in correctly? as I changed the housing for another used unit. (replacement now shows condensat too )
      06-29-2022, 10:09 AM   #2
Egoy936
Drives: Bmw 535
If no communication faulty TMS or bad wiring!
      06-30-2022, 05:29 AM   #3
rkl
New Zealand
As i could see two TMS initially do you think I made have made an error when coding?
I'm curious if now I have to treat as if it was a used unit?
Would this mean VO code frm?
      07-03-2022, 06:04 PM   #4
Egoy936
Drives: Bmw 535
Message me directly I will help
      05-15-2024, 06:16 AM   #5
AndOne
Drives: F10
Originally Posted by rkl View Post
Hi team
I have the same problem, need help!!!
