09-10-2018, 12:38 AM | #1 |
Rep 21
Help with Error codes
Need help to solve these errors codes
I tried cleaning all but they came back I use BimmerLink app to do the diagnostic Here is what I got (F10 535i) **Info memory** 38 errors total JBBF 3 errors 002031: VSM_EVENT_VEHICLESTATE 002040: PDC: RESET DUE TO WATCHDOG TIMEOUT 002044: K-LIN_5: LIN MANAGEMENT DESYNCHRONIZATION SZL 1 error 803450: NVRAM MANAGER: WRITE FAILED ZGW 3 errors 100601: UNEXPECTED ASYNCHRONOUS STATE ON FLEXRAYBUS 100100: CONTACT TO FZM SLAVE LOST 100204: MESSAGE MONITORING: SYSTEM CONTEXT SIGNAL FAILED ASA 4 errors 16004C: DEM_EVENT_KFC_KL30_UNDERVOLTAGE 16004E: DEM_EVENT_KFC_KL15_UNDERVOLTAGE 160070: DEM_EVENT_ZFLS_UNDERVOLTAGE 160086: DEM_EVENT_KFC_INFO_FRPHYS_REINIT ICMQL 1 error 482627: CENTRAL ERROR MEMORY BLOCK ACTIVE DSC 1 error 480A18: DRIVING POWER REDUCTION - DRIVING POWER REDUCTION SWITCHED OFF BY DSC COMMAND - INFO ENTRY - HSR 9 errors 2B004C: DEM_EVENT_KFC_KL30_UNDERVOLTAGE 2B004E: DEM_EVENT_KFC_KL15_UNDERVOLTAGE 2B0076: DEM_EVENT_KFC_AGB_LIMIT 2B0118: DEM_EVENT_KFC_SKE_IS_FKT_ERR 2B0094: DEM_EVENT_KFC_INFO_ZWK_UNDERVOLTAGE 2B0095: DEM_EVENT_KFC_INFO_ZWK_PL_UNDERVOLTAGE 2B009E: DEM_EVENT_KFC_INFO_FRPHYS_REINIT 2B0105: DEM_EVENT_KFC_SLGS_STARTUP_PWM 2B010B: DEM_EVENT_KFC_SLGS_STARTUP_PWMK EPS 1 error 482344: LLP ERROR (KFC_LLP) TVM 7 errors DBC440: MONITORING CIRCUIT HAS TRIGGERED RESET 930040: SENDER NODE: ERROR IN SEGMENTATION DBC445: EHC HAS TRIGGERED A RESET IN CASE OF A FATAL ERROR FROM THE INIC 930035: TRANSMISSION ERROR IN THE HARDWARE ABSTRACTION LAYER 4B0008: TOSHIBA HW ERROR - MPEG APPL I2C 4B0048: DTC TO FAILURE MESSAGE 4B0018: TOSHIBA SW ERROR - MPEG APPL, BCAS HARDWARE KOMBI 2 errors B7F69E: COMBI: COMMUNICATION SETUP TO THE MOST NODE IN THE STATION WAGON 93003F: MOST OPERATION SENDER NODE: ERROR IN ADDRESSED FUNCTION MMI 1 error 93000F: MOST NODE: AT LEAST ONE FUNCTION BLOCK LOGGED OFF PDC 1 error 64430C: MESSAGE (328H, RELATIVE TIME): FAILURE ZBE 1 error 67000A: CSM_E_ERROR_EVENT FAS 2 errors 6D0010: NVM_E_READ_FAILED 6D0004: PIA_E_IO_ERROR CID 1 error 800313: SOFTWARE ERROR: UNEXPECTED RESET **Error memory** 5 errors ZGW 1 error 801C20: CENTRAL FAULT MEMORY FULL CAS 1 error D91410: DME CAN MESSAGE DATA DRIVELINE: MISSING OR CRC ERROR FZD 1 error 801A4A: DEACTIVATION OF IRS AND INCLINOMETER BY CUSTOMER FUNCTION FRM 2 errors 800F3A: FOG LIGHTS LEFT DEFECTIVE 800F3B: FOG LIGHT RIGHT DEFECTIVE |
10-01-2018, 10:34 PM | #2 |
Rep 418
how did you get all these errors? Try MHD app for Android (cost money), it has option to clear error codes. You'll need OBD to USB cable and OTG cable for android to connect Android device to OBD port
