2010 2011 BMW 5 Series Forum F10 Replaced Center Console Insert |
01-23-2019, 05:47 PM | #1 |
Rep 63
I didn't like the small cramped console (with the phone insert) so I replaced it with part # 51169277267. There is a lot more space in there now.
01-23-2019, 09:43 PM | #3 |
Rep 455
Good job on the install. Things disappear under the iPhone adapter, and it is a pita to find them from the driver's seat. I must look into what you did. Thanks for posting the info.
UPDATE: I looked up the part number that was supplied, it is avail for $72 from ECS. Last edited by John H.; 03-11-2019 at 11:28 AM.. Reason: Added info. |
01-23-2019, 11:48 PM | #6 |
Rep 716
01-24-2019, 07:38 AM | #8 |
Rep 14,522
Nice upgrade but I find it would give me a reason to put more crap in there lol
03-09-2019, 06:32 AM | #12 |
Rep 639
03-09-2019, 09:57 AM | #13 |
Rep 264
03-09-2019, 12:22 PM | #14 | |
Rep 455
I just pulled out the switch. There is a rectangle cutout. My approach would be to cut liner with a razor, and Dremel cut the plastic below. Last edited by John H.; 03-09-2019 at 12:24 PM.. Reason: Added info. |
03-09-2019, 09:16 PM | #15 |
Rep 228
Where is the trunk lock switch?
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
03-10-2019, 01:20 PM | #16 |
Rep 455
03-11-2019, 10:56 AM | #17 |
Rep 63
I did the same, the wire is fed underneath the rubber mat and the switch is in my console if I need to connect it to use it. Eventually I will use a dremel and mount it in the original spot.
03-11-2019, 11:38 AM | #18 | |
Rep 455
So, all that needs to be done is to mark 2 straight lines. We have our template! UPDATE - 3/11/19: Spoke with my dealership contact. The part is on backorder, 5-10 days. ... Last edited by John H.; 03-12-2019 at 12:12 AM.. Reason: Added media. |
03-22-2019, 10:28 PM | #19 |
Rep 455
UPDATE:
Yesterday, received the tray. Today, installed. Part was $62, plus tax. Out of the box. Used Dremel to make a cutout for valet switch. Spent approx. 1 hour. Use a small file to square off the corners. Take your time! Done! Last edited by John H.; 03-23-2019 at 06:58 PM.. Reason: Added media. |
SWFLf10373.50 |
03-23-2019, 05:40 PM | #21 |
Rep 639
