2010 2011 BMW 5 Series Forum F10 N20 seized engine - Oil pressure error threw. Car shut down 1 minute later |
02-11-2019, 03:24 PM | #23 | |
Rep 34
02-11-2019, 04:27 PM | #25 |
Rep 34
11K
02-11-2019, 07:15 PM | #26 |
Rep 4,047
02-12-2019, 07:02 AM | #27 | ||
Rep 1,873
Never ignore an oil pressure warning. I'm not sure why you kept driving, and your later comments say you didn't do scheduled oil changes either (and the factory schedule is already very long). If you had shut down the car like it told you to, you may have only needed a new oil pump, then had some SIB work performed, and been back on the road. You may, truly, have had an oil pump failure (for whatever reason) and it had nothing to do with the other common problems with your engine model. Things fail - and, if memory serves correct, a lot of these engines have electric oil pumps, so it becomes even more likely that the oil pump could fail all on its own. PSA - ALWAYS heed oil pressure warnings. You can save yourself a lot of grief and prevent things from getting really bad. Unfortunately - failing to react to a clear warnings of loss of oil pressure and instructions to stop the car is 100% the responsibility of the driver. It would be an uphill battle to shift the responsibility for that to anyone else... You may be able to work some deals to reduce the cost, or look at alternative engines and mechanics. There have been a couple of threads around from 550 owners who have replaced engines. Last edited by Surly73; 02-12-2019 at 07:13 AM.. |
02-12-2019, 07:55 AM | #28 | |||
Rep 34
02-12-2019, 07:36 PM | #29 | |
Rep 34
02-13-2019, 10:07 AM | #30 |
Rep 4,047
02-13-2019, 10:08 AM | #31 |
Rep 34
Dealer is saying 11K engine replacement. BMW NA is collection information on the case to SEE if they can assist in any way.
02-13-2019, 10:16 AM | #32 |
Rep 4,047
02-13-2019, 02:12 PM | #33 |
Rep 34
Let's hope. They know I know the SIB ( SIB 11 03 17 ). They know I know N20 engines have had known issues.
They know I know they redesigned the timing chain in later models BECAUSE OF THIS. I'm not going to let them screw me here. |
02-19-2019, 10:47 AM | #34 |
Rep 4,047
02-19-2019, 10:49 AM | #35 | |
Rep 34
02-20-2019, 05:26 PM | #36 |
Rep 553
keep us updated
crossing my fingers for you On a side note it seems no matter what BMW you buy its a ticking time bomb. N20/N55/N63/S63/S65/N54 the list goes on and on. I know BMW has extended warranties and done recalls, they've been doing that since the N54 days, N63 now N20. Why can't they just engineer something that will last and not require wasted time/money/recalls/etc? Really a big shame. I used to be a die hard BMW fan and fanatic. Once I woke up from this "abusive" relationship I realized the amount of TIME let alone money that I spend on these cars is ridiculous. I am paying over 100k for some of these cars only to be driving around with coolant bottles and oil bottles in my trunk ?? Car reeking of oil and coolant in 2-3 years. What kind of bullshit is that? They extended the warranties, they did recalls, sure thats cool and all but I am done with that. You barely see this type of catastrophic failures with other brands. I have other brand luxury cars and the biggest headache brand has been BMW. My addiction and love to them blinded me to the truth but its there right in front of us. Food for thought |
nos4seasons23.50 |
02-21-2019, 12:03 PM | #37 |
Rep 34
Final Outcome - Engine Seizure - Bmw Stepping Up
Ok - so to bring a few folks up to speed that don't know the situation:
So I come HERE first. Post this thread. Get you folks involved. And even though none of you know me, or have any affinity for me, you all stepped up. Gave me the SIB for the N20 engine timing chain guide failure. Educated me on the known problem. Gave me a negotiating point. I get BMW NA involved. Give them the SIB, let them know I'm aware of it. They tell me: good luck kid. You're at 73K miles, and this extended warranty for this issue ended at 70K miles. Take care now. Obviously I'm pissed, but nowhere near submitting and giving up. I mean after all: if I serviced the vehicle correctly, got oil changes within the intervals, and treated the car right, this should not happen. Sure - I'm out of warranty, and in brass tac terms, I'm fucked. I get it. But I knew, that since there was a known issue w/ this engine, that was causing seizures, I had somewhat of a case. But here's the thing (and perhaps the important lesson): at the dealership, I had no advocate. The initial service guy who contacted me with the quote, probably thought: who is this kid. Business guy. Drives a BMW. Wants a freebie. I have no affinity to him. And I recognized that. So here's what then happened:
About 5 days goes by (now this is important I think - because I've seen this same scenario takes months, attorney letters, and pushing, until BMW corporate either gives in, or in a few cases, buys the car back (writes you a check for something), and I finally get a call back from my advocate at the dealership (service manager). He says: Ok - This is what's going to happen:
So here we sit. They gave me a new X3 to drive around until this engine replacement is complete. BMW NA is paying for the engine, AND a considerable amount of the labor to install it. They will likely give me a warranty on the motor extended out past 150K. We'll see still in the air. So even though they didn't goodwill EVERYTHING, they goodwilled MOST of it. I can handle a few thousand dollars. But I wasn't paying 11 when the car was at 73K miles. No one should have to, regardless of service records. As long as you got oil changes on time, no one should have to do that. BMW NA stepped up, and did what was right here, but not because they wanted to. It was because I calmly, but persistently made my case. Gave them the SIB. Emailed them THIS THREAD, and others like it (like this one: https://f30.bimmerpost.com/forums/sh....php?t=1089085). Had the support of all you folks, and then importantly, created an advocate at the dealership. I can't stress how much significance this holds. It's CRITICAL you have someone at your dealership on your side, that has your back. My advice to myself from here forth, that could be used by anyone else in this same situation: maintain a good relationship with dealership, and particularly, the service tech and managers. Get service done there. Know your research. Fight for what's right. Rely on the community here to guide you, calmly, but unyieldingly, push for corporate to step up. Have your records. Have a case. And, in a non threatening manner, convey that you're willing to get legal involved if they don't do what's right. I'm going to post this same reply on the N20 engine seized at 72K miles thread, because the point of this post, besides thanking all of you for your critical help, is to arm other folks with the outline of how to get corporate to step up on these engine failures. Thank you all for everything. Whatever I can contribute to this forum in the future, I will. My name is Ryan. |
02-21-2019, 12:58 PM | #40 |
Rep 4,047
Ryan (now that we know your name) - Well done, and glad this worked out for you. I knew this would be the outcome for you because of the issue I told you about. As in my case (not as bad as yours), you have to give credit for BMW for stepping up. But on the other hand, shame on them for a shitty product that is likely going into 40% of their cars.
Btw, you handled the situation very well. And the outcome is the result. Here to many more miles |
nos4seasons23.50 |
02-21-2019, 06:38 PM | #41 |
Rep 161
Drives: 2014 535ix
Ryan you rock making the best of a bad situation. Good job on not taking the hit lying down and using some quiet reason and evidence to make a case to BMW for some relief and getting it -- when a ranting jerk might not have gotten any. And good job convincing the SM to go to bat for you.
2014 535i XDrive Alpine/Mocha Nappa Contour
02-22-2019, 08:45 AM | #42 | |
Rep 34
02-23-2019, 11:30 PM | #43 |
Rep 1,925
Glad to hear this worked out.
Good reminder to keep service up to date, and keep records.
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
02-24-2019, 09:36 AM | #44 |
Rep 1,214
N20's are garbage engines, yours did what N20's do. I beg and plead with my N20 clients to come in every 7500mi for an oil service, so many of them drink the 10, 12, 15k BMW oil service koolaid and I've seen 3 total engine failures in the last 2 years. The N20 also uses a ridiculously obscure 0w20 LLFE14++ oil that chain oil change places don't have, don't care to have, and aren't putting in the engine.
I must admit I'm always amused when someone asks why there isn't an emergency shutdown feature on these cars incase there is a major failure. That feature is positioned behind the wheel :-) It is normal for the transmission to not go into neutral when the engine isn't running. The 8HP automatics have a pressure reservoir that must be primed to allow gear selection. This reservoir is what allows auto start stop to function, but you only get one hit out of it. When the engine stops while road speed is detected it dumps its charge as a parting gift so you can hopefully coast to a place you can secure the vehicle. It sounds like your situation turned out as well as it could all things considered. |
