2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Lets talk about garage lifts!
      02-16-2019, 08:24 PM   #1
roastbeef
roastbeef's Avatar
Drives: E92 M3
I'm interested in hearing about lifts you guys have... pros and cons. i'm not opposed to any single design, but budget is going to be reasonable- no in-ground hydraulics. ideally, i would be able to use the lift for doing my own work, but i would like to also be able to store one car over another.
pictures are appreciated!
Instagram; @roastbeefmike
      02-16-2019, 09:28 PM   #2
chief1richard
Life is on the Track, the rest is just waiting.
chief1richard's Avatar
Drives: At the point of 7,000 RPM's
2018 M2  [0.00]
Thought about this for years, but I do not have the height in my 2 car under for a lift. Have been working on my own cars for many years and it is so much easier with a post lift. If I did not live in the Northeast with winter weather I would put one in my driveway. If I bought another home, top priority would be 2 car detached garage with high ceilings. Next best is a Quick Lift, which is what I use now. BTW, what does track is srs mean on your screen name?
      02-16-2019, 09:53 PM   #3
roastbeef
roastbeef's Avatar
Drives: E92 M3
well, mrs beef and i found a place that suits all of our needs, but doesn't have a three car garage we wanted. however, it has side parking, which is more valuable than a three car garage for us. the garage height isn't super high... i might have to modify the garage door rails to get it up against the ceiling when its open, but if i can park two cars, i'd be happy. i don't need it 10' up in the air. i'll have to measure, but i think its doable.
      02-16-2019, 09:56 PM   #4
TheeGovernor
Life is better with burnouts
TheeGovernor's Avatar
97
Maxjax is a great lift for lower ceilings.
lakefront560.50
roastbeef11586.00
      02-16-2019, 10:54 PM   #5
roastbeef
roastbeef's Avatar
Drives: E92 M3
i think i want something semi-permanent. i'll also have to check and see if the property is on a post tension or a regular slab if bolts are needed.
      02-17-2019, 03:00 AM   #6
roastbeef
roastbeef's Avatar
Drives: E92 M3
check out this lift. one of the things i dig about it is optional rolling hydraulic jacks that fit between the ramps. i'll have to check and see if they extend as far out as i would need for the m3's jacking points.
      02-17-2019, 04:34 AM   #7
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
There are a lot of threads on this subject. Here's the short of it. The most economical and best suited for real mechanical work is an above ground 2-post lift. They basically come in two versions, with the cables and hydraulics either running over the top of the columns, or on the floor between the columns under a guard plate. Most need a 12' ceiling height. Bend pack makes one for a 9' ceiling. These lifts need a minimum of 4" slab and 3,000 psi concrete. They use 240VAC power, but Rotary does now have a 12V DC (car battery) powered system. Depending on what manufacturer you go with, $4,500 installed is a good ball park top number.
The MaxJack, and QuickJacks are nice, but are compromises. A real full size lift let's you stand on your feet comfortably for hours at a time and gives you access to all parts of the chassis. Once you experience working on a car standing comfortably on your feet, you will not go back to kneeling during brake work, or on your back dropping a transmission.
If you want storage capability over mechanical accessibility then a 4-post is a better choice.
I have a Rotary SPOA 10. It's a 10,000 pound, asymeterical two-post. I've had it for 14 years and it's saved me over $20K in shop labor.
      02-17-2019, 06:21 AM   #8
roastbeef
roastbeef's Avatar
Drives: E92 M3
thanks, i think i'm set on the four post design... definitely not going with a quick jack, i want to be able to park a car under it.
the reason i want to go with a four post is i have a very oddly balanced solid axle 4x4 that i'll work on occasionally. i don't know what it weighs, but its heavily front biased.
although the truck won't be stored under/over it, i think i can still get two cars stored without a high clearance garage (i'm not sure what the height is, i'll have to check).
      02-17-2019, 08:15 AM   #9
Efthreeoh
Unless the truck is heavily modified, like something Jay Leno would build, a 2-post lift would have no problem lifting it.
      02-17-2019, 08:28 AM   #10
3798j
3798j's Avatar
11409
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
I chose the Direct Lift Pro 9000 with two rolling hydraulic jacks. I too have a difficult vehicle to get positioned on a two post, plus I also park a vehicle underneath a vehicle. It does everything I could want regarding doing general maintenance and modifications and it's definitely one of those "I should have done it sooner" (purchasing the lift).
      02-17-2019, 09:08 AM   #11
Efthreeoh
So let me throw an idea at you. Some people are uncomfortable with leaving a car on a 2 post lift because the suspension hangs unsupported. While I've left my car for weeks at a time on my lift when working on it only on the weekends and never had an issue with the suspension (I'm still on most all the original bushings), I know BMW owners are BOCD (Beyond OCD), so I 'll not argue the point. In weather emergencies I store two of my BMWs in the garage bay with the lift, one on top of the other, so I do occasionally use my lift for 2-car storage.
But if I were afflicted with BOCD, and had a two post lift and wanted to store two cars, I'd just use four (4) under-hoist jack stands, one under each wheel and lightly set the car down to put some load on the suspension. Using these:
      02-17-2019, 09:20 AM   #12
Alpine_F82
Just Building My M4 Track Car
Alpine_F82's Avatar
Drives: 15’ M4 Alpine
2015 BMW M4  [0.00]
I use the bend pack post lift good up to 10k pounds works like a charm one of the bests lifts out there
      02-17-2019, 09:56 AM   #13
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
I bought an amazing house .. but didn't consider garage ceiling height at the time. I'm pissed. I spent yesterday laying on the cold concrete bleeding the clutch. I hate being under there, I get disoriented after a while and am in fear of an instantaneous crushing death every second.
The quick jack etc doesn't really seem worth it. Yeah it's faster and less of a hassle than the floor jack and stands, but you're on your knees or hunched over. I would rather rent a garage with a proper two post.
      02-17-2019, 07:18 PM   #14
roastbeef
roastbeef's Avatar
Drives: E92 M3
Nice. That looks great!
      02-17-2019, 07:33 PM   #15
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
I'm also OCD on the being afraid of being crushed. I bought 2 more jack stands to put on the subframe nearby where I work just in case in addition to the 4 jack points resting on jack stands plus I keep my jack slightly under the jack point as another measure.
But yeah... a lift would be really nice.
      03-18-2019, 02:47 AM   #16
mrgreystone
mrgreystone's Avatar
Drives: Audi A6
Depends if you want to store a car or work on one.
2 Post is better if you want to work on a car. It will require a higher quality floor with very little slope (< 3 degrees I think)
4 Post is better for storage and does not require your floor to be as good or as flat
You can get add ons to your 4 post to so you can work on your car but that is an additional expense.
Some 2 posts you can unbolt when you do not need.
Signature
      04-27-2019, 09:32 AM   #17
stephanporsche
Drives: 2011 BMW 328i
I have 10'6" ceilings and installed a Dannmar D7, with my Porsche and BMW the lift goes all the way up and I am easily able to work under the vehicles.
Instagram@stephanporsche
Porsche 996 Turbo
Porsche 997 Carrera S
BMW E90 328i LCI
      04-27-2019, 01:04 PM   #18
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
Help me understand this theory. How is this worse for the bushings than having the weight of the car on them?
      04-27-2019, 01:13 PM   #19
SnailBums
Drives: e60
There is nothing to understand. 50% of people say suspension shouldn't stay extended, 50% of people say it shouldn't stay loaded. there is no right or wrong answer from my POV. People claim dry rotting seals ect but it happens either way.
Mike
Efthreeoh17309.00
      04-27-2019, 01:16 PM   #20
2014 335i  [9.74]
Mike
Thanks Mike. To me it seems better to have the suspension (and tires) unloaded. I find it difficult to even contemplate why keeping the suspension and tires under load is preferable.
      04-27-2019, 01:47 PM   #21
quick
Drives: '12 X5M, '01 E55, '91 964 Trbo
Have two, a 2 and a 4 post...Two post is much preferable to work on the car or to wash the underneath
roastbeef11586.00
Efthreeoh17309.00
Nkc1600.50
      04-27-2019, 01:48 PM   #22
roastbeef
roastbeef's Avatar
Drives: E92 M3
Best of both worlds!
