2010 2011 BMW 5 Series Forum F10 Valve stem seals or turbo seals? |
02-18-2019, 05:17 PM | #1 |
Rep 16
My 2013 550 (60k miles) is at the dealer for smoke and oil consumption. I assumed it's the valve stem seals and if so gets replaced under the recall. But after a little research it seems like turbo seal failure is likely too. I saw somebody say in one post that the warranty on turbos was extended to 70k miles. Never heard anything else saying that though. Does anyone if that's true? Are turbos possibly included in the n63 engine recall/class action suite?
02-18-2019, 08:57 PM | #2 | |
Rep 215
F10n632.00 |
02-18-2019, 09:02 PM | #3 | ||
Rep 16
So technically they should replace anything that's causing oil consumption? |
02-18-2019, 09:15 PM | #4 |
Rep 215
If you read the section in the class action suit on the steps that should be taken it reads that they can have If I recall correctly three attempts to solve the problem(s) that cause consumption before electing to exchange an engine or they can choose to swap an engine at their discretion at anytime.
02-18-2019, 09:18 PM | #5 | |
Rep 16
02-18-2019, 09:25 PM | #6 | ||
Rep 215
02-20-2019, 01:09 PM | #7 |
Rep 553
They do a timing chain test and a compression/leak down test to see what the outcome will be.
If those tests pass the repair process will get started and it wont cost you anything. If one of those tests fail a new engine will be ordered and the pay by percentage bracket based on mileage kicks in. |
02-20-2019, 01:19 PM | #8 | |
Rep 16
02-20-2019, 01:23 PM | #9 | ||
Rep 553
My oil light would come on every 150-200 miles and the car would blow smokescreen style blue/black smoke. They didn't even need to do any other tests once I pulled into the service bay they already knew. |
02-20-2019, 03:53 PM | #10 |
Rep 215
The car shouldn't burn a quart within 4k that is signs of early valve guide wear. I will change my oil every 4k-5k from now on because these cars run hot. Why wait the prescribed 10k? Thats insane to me to wait that long.
02-20-2019, 04:09 PM | #11 |
Rep 16
02-20-2019, 04:18 PM | #12 |
Rep 553
I think it's normal for these cars to burn a quart at 4-5k miles. I know for more high performance cars it's absolutely normal especially turbocharged cars.
My Current M5 burns a quart every 2500-3500 miles. My old M5 burned a quart every 900 miles. My old C63 burned a quart every 1500 miles. My old M3 burned a quart every 1200-1500. Even my N54 powered 335i burned a quart by 3500 miles. When it's burning every couple hundred and seeing blue smoke after idle time that is classic valve stem. |
02-20-2019, 04:25 PM | #13 | |
Rep 16
02-20-2019, 04:30 PM | #14 | ||
Rep 553
These cars make condensation smoke like crazy. My M5 smokes like crazy it's all condensation. With my N63 car the smoke looked similar but it was thick and blue and stunk. The condensation smoke is water. You can put your hand over the exhaust tip see if it gets wet and moist it's all condensation. This is normal As far as the action guidelines. It all depends on your SA and the tech advocating your case. I've seen people get denied that should have been approved, people accepted that should have been denied...etc. Tipping the SA (even $50) goes a long way in getting the results you want. I learned that years ago with from the n54 days hahaha |
02-20-2019, 04:52 PM | #15 | |||
Rep 16
02-22-2019, 09:12 AM | #16 |
Rep 247
It's not just the Germans. Car & Driver recently wrapped up their long term test of a Mustang V8 and that thing burned a quart every 700 miles or so, which Ford said was normal. I think some of these high performance V8s are just expected to consume oil. 1 quart every 3k-4k on an N63 probably puts you at the lower end of the range of oil consumption in these engines. The owners manual recommends checking oil level every time you refuel :-0
02-22-2019, 09:47 AM | #17 | |
Rep 16
02-22-2019, 10:09 AM | #18 | |
Rep 247
02-22-2019, 10:34 AM | #19 | ||
Rep 16
I'm just hoping that the 750 to a 1000 miles that I have to put on the car before it goes back for the oil consumption test is enough to actually show the consumption. It sucks that I have deal with this at 60k miles on the most expensive and supposedly high quality car I've ever owned. And after looking into it, it seems like bmw has a habit of calling serious problems normal on multiple cars. The whole reason I got this car was that I was impressed by power gains from tuning. Now I'm afraid to tune because I'm worried that if something goes wrong they going detect the tuning to point the finger at the tuning and not the actual issue. |
02-22-2019, 10:46 AM | #20 |
Rep 247
I understand the concern. I don't think the oil consumption necessarily signifies the occurrence of one of the major issues covered in the lawsuit, but it's possible. 1,000 miles should be enough to detect excessive oil consumption, but the question will be what the threshold for "excessive" is. I don't recall what cutoff they're using, but I suspect your consumption is not sufficiently severe to be in that range.
Either way, appreciate you sharing and look forward to any updates you're willing to provide on the outcome. Hopefully all is well and you can just get back to enjoying the car. |
02-22-2019, 11:02 AM | #21 | |
Rep 16
Anyways, thank you for your input. I will definitely update as I go though the process. |
02-24-2019, 12:50 AM | #22 |
Rep 553
Just an update I would be careful when taking these cars in with high mileage. I'm seeing more stories of dealers saying car needs fuel pump, coils, plugs, etc while doing recall work after putting the engine back together.
I paid them to replace all my coolant hoses, water pump, thermostat, lower temp sensor, etc. My car was road tested hard apparently by 5 people. I got my car and smelled coolant burning they said it's residual, low coolant light came on that night. They tell me they'll cover it....take it in. I thought it's the sensor as I'd top it off I'd still see the light. Today I get a bill for almost $1k. They say the coolant expansion tank leaking and it's aftermarket. How come this wasn't caught by the 5 people that drove it? And I already knew that I thought they'd take care of it or at the least just charge part cost since it should have been caught. 😒 |
