2010 2011 BMW 5 Series Forum F10 Premium bavsound audio upgrade |
03-19-2019, 01:40 AM | #1 |
Rep 808
I'm going to make this short and simple. I have an f10 with the premium sound system which is essentially the Harmon Kardon speakers and amp. This differs highly from the top hifi sound system as it has a bigger and more powerful amp and a few extra speakers than the top hifi. I bought the subs and stage one speakers from bavsound- they don't sell a more powerful amp for this level of speaker system and I honestly wasn't impressed and definitely not worth the $1400. The subs sound just a little better, nothing noticeable, and I honestly think the stock speakers sound better. If you have the top hifi the upgrade may be worth it, but if you have the premium sound system I'd save your money for something else
03-19-2019, 06:09 AM | #2 |
Rep 500
I'm not sure how good the bavsound ghost sub but Alpha One sub is a noticeable upgrade from Top Hifi sub. I also swap out Top Hifi speakers with FaitalPro 4FE32 and Eminence SD28 with 2nd order crossover. The speakers sound more airy and able to turn up the volume close to 75% without distortion. Check this out:
https://f10.5post.com/forums/showthread.php?t=1010869 |
03-19-2019, 11:16 AM | #3 |
Rep 965
I got the MB Quartz, sound was only incrementally better (must be at louder volumes) as well. Luckily, got it at a deep discount otherwise would've been sad. If we could upgrade the amp, I think we could get some noticeable gains.
03-19-2019, 08:45 PM | #4 |
Rep 500
If your system come with Top Hifi running on Optical signal, the upgrade path would be more troublesome as you need to use mObridge DA3 and external amp (Total 9 channels). Or the cheaper option would be to tap the wire for front 3 channels and underseat sub, redirect to AudioControl D-6.1200 (which can take in high level input + DSP) for tuning and able to drive 125W@4ohms or 200W@2ohms.
03-20-2019, 07:35 AM | #5 | |
Rep 1,873
marmit2017106.00 |
03-20-2019, 08:29 AM | #6 | ||
Rep 808
03-20-2019, 07:44 PM | #7 |
Rep 500
There's some confusion here. 676A is HIFI option. 677 is Top HIFI or HK Premium HIFI. HIFI come with 285w amp and run on analog which can be replace directly with Audio Fischer UP 7BMW or Bavsound Revenant (rebrand of 7BMW). Top Hifi run on MOST amp and digital signal from HU.
https://www.bimmer-tech.net/blog/ite...-audio-for-bmw |
Surly73533.50 |
