2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
10-29-2021, 10:32 PM | #309 | |
Rep 1,037
Agreed, looks great! |
10-30-2021, 02:59 PM | #310 |
Rep 2,591
Machine at your own risk, but I feel like it should be safe to machine.
2015 BMW 535xi
Blue Angel997.50 |
11-01-2021, 12:12 AM | #311 |
Rep 1,037
Thanks for that! Reason I ask is not that I've got 343m wheels to worry about, but I do have a set of 408m that I use for winter. That's the M5 factory winter package wheel and I assume the spoke profile is very similar.
Agreed, there's likely several mm worth of material there that could be cautiously removed without significantly impacting the strength of the caliper. |
11-08-2021, 09:29 AM | #313 |
Rep 2,591
Thanks!
I wanted a more bronze-gold orange, but I'm pretty happy with this color as well
2015 BMW 535xi
11-14-2021, 11:03 PM | #314 | |
Rep 2,591
Wow, totally missed these. Apologies.
The additional effort was really a result of my own mistakes. I didn't account for the 5mm washers when I first fit everything up, so I had to wait for a few weeks for spacers/hub extenders + my own schedule to free up. The X5M calipers were significantly more expensive, around a grand for a pair (when I was shopping) versus 450 for the G generation calipers, so I went with the cheaper option.
2015 BMW 535xi
11-23-2021, 10:28 AM | #315 |
Rep 951
Btw, since we are on the topic of other brakes, I have a feeling that those of us who did the x5m front caliper upgrade, needed to order the Rolls Royce Ghost rotors in order to fit properly without the need for the extra 4mm caliper bolt spacers. Part number for the rotors can be found in the link below. Reason I say this is because the rotors have a different part number from x5m rotors but have the same diameter. The other reason I believe this is because the hub part number is the same between f10 and RR Ghost which uses these same calipers. The only issue is of course the RR rotors are much harder to find and are more expensive..
https://www.realoem.com/bmw/enUS/sho...diagId=34_1777 |
11-23-2021, 10:48 AM | #316 | |
Rep 2,591
2015 BMW 535xi
11-23-2021, 11:47 PM | #317 | ||
Rep 951
11-24-2021, 10:06 AM | #318 |
Rep 2,591
Possible, but also possible that there's just a difference in metallurgy to deal with the weight of the car and better heat dissipation. Heck, BMW has different part numbers just for painted vs unpainted calipers, even though the underlying part is the same.
2015 BMW 535xi
11-24-2021, 04:01 PM | #319 | |
Rep 951
I'm any case this is a bit of a moot point I feel as for less than the price of the RR rotors, you can actually get X5M F85 drilled rotors which look superb.. so the 4mm spacers seem negligible in that equation. |
12-23-2021, 04:20 AM | #320 | |
Rep 94
I'm upgrading from 330mm to 374mm (F10 528 LCI) using parts above. Gonna import those things all the way from US (528 was F10's non M top trim in here, so no other source other than importing from far far away) Things like calipers and carrier I found these online on ebay, used condition (80k miles). Would that be okay if I buy used calipers and carrier? Edit: Turn out it's hard to source a complete caliper set. There's a company called Elstock which sells brand new front left & right calipers and quite cheap I think. However I think it's only come with the caliper and nothing else. So to completely build the caliper, I need to buy the highlighted items, am I right? Other than above which is number 3,8,9, and 13 I can re-use these from the current caliper setup right? Last edited by Johnkwick; 12-23-2021 at 12:24 PM.. |
12-23-2021, 12:29 PM | #321 | |
Rep 2,591
https://www.ebay.com/itm/143922155875 https://www.ebay.com/itm/143917531380 Unsure why you're resorting to sourcing each part individually. I would rebuild them with new 4,5,6, and 10 parts, but everything else is perfectly fine. The actual lines are the same throughout all the models.
2015 BMW 535xi
12-23-2021, 12:59 PM | #322 |
Rep 110
It also surprises me that you're needing to source all this stuff from the US, but I've personally never bought these things from within Indonesia, so I couldn't tell you. The pads and rotors are common maintenance parts, so I would certainly hope you could get these locally. The calipers and carriers you may need to find outside Indonesia, though, but ebay is where I would begin that search.
If you find a used set, I would persoanlly rebuild them. All you need is a caliper rebuild kit that will come with seals and a piston. It's pretty simple (and cheap) and you can find tutorials on YouTube. The other option is to buy remanufactured calipers from an auto parts store (likely the same place you'll find the rotors). These are used calipers, but they've been sandblasted and fully rebuilt, so they come out of the box ready to bolt on (or paint). The carrier is usually not included with them, though. I persoanlly bought my rear calipers and carriers used and rebuilt them, so this is a fine option. This advice only goes for the rears. If you're upgrading to the X5M front calipers, you will not typically find these available to buy remanufactured. These will need to be bought used and then rebuilt yourself. |
12-23-2021, 07:52 PM | #323 | ||
Rep 94
The reason I tried to source each part individually because initially I'm planning to buy brand new caliper housing (Elstock 82-2342 and 83-2342). I'm sorry this is my first time fiddle with brake system, so judging from the appearance, how do I know if a caliper also come with the caliper carrier? Found these: https://www.ebay.com/itm/313791691192 https://www.ebay.com/itm/403353484503 caliper carrier 34216786829, is it interchangeable with part number 34116786829? Quote:
the only remanufacturing listing I saw was the Elstock 82-2342 and 83-2342, but unsure whether it has all the highlighted parts in my previous post. if brake calipers are meant to last forever, I think I shouldn't be worried about 10 year old parts I saw a great deal for 2x zimmermann 374mm rotor + 2x bosch quietpad on ebay. I can source 34216786829 from local indy as it's also compatible with F01 base model (730/740) which quite popular car in here. |
12-23-2021, 09:41 PM | #324 | |
Rep 110
Regarding carrier interchangeability, I don't have a reference to 34216786829 in my spreadsheet, so I'm not sure what car this is from. I tried to pull this up on RealOEM, and a couple other sites, and it would appear at first glance that this part may be discontinued. Hopefully someone else can chime in and confirm. I've typically found that there are very few interchangeable parts when you start doing brake mods, so I would personally stick with known part numbers that people have used before. In this case, if you're doing front calipers, the only carrier p/n I would use is 34116786829. The metal housing of a brake caliper will last forever, as long as it's not overly rusted or corroded, but the rubber seals will not last forever. Brakes are the most important safety component on your car. If I were putting used brakes on my car- even if they were only a few years old- I would replace all the seals and the piston. If the calipers were 10 years old, then it isn't even a question. It's cheap and easy, and then you know for certain the caliper will not fail, so if you're going through all the trouble to upgrade the braking system, why would you not slap a rebuild kit in your caliper? |
12-25-2021, 07:42 PM | #325 | |
Rep 2,591
Calipers are meant to last forever, however the seals in them are not. The seals will need replacing once in a while, along with the dust boots. If you don't know how to rebuild calipers, just get the remans. For the remans, you'll only need numbers 2, 6, 7, 11, and 12.
2015 BMW 535xi
01-04-2022, 04:31 PM | #326 |
Rep 423
Unspec,
Thanks for posting this info on your install. I decided to go ahead and mount the G30 calipers I purchased. I just found a set of cross drilled/slotted rotors that I think will work. Can you give me a little input on how much you had to trim off the pad? I was watching a video regarding this swap and they stated it was necessary with the 374mm setup. Thanks
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
01-05-2022, 11:02 AM | #327 | |
Rep 2,591
2015 BMW 535xi
01-05-2022, 02:08 PM | #328 |
Rep 423
Ok, thanks for the info. That's good to know!
01-06-2022, 05:25 AM | #329 | |
Rep 7
I am doing X5M front upgrade on my F06 650i xDrive. I am all clear on this, but I noticed that you have retroffited also M5 brakes on rear. Can you share some more details? M5 brackets and calipers are from F10 I assume. I already have 345x24 rear rotors. These are the same used in some F01/F07 applications 34216775289. 34216775291 is the 370x24 which is used also on Alpina B6 (F06). Now looking at the rear caliper, the M5 (F10) seems visually the same as the 50i one. The part numbers differ, I assume because the M5s are painted blue. Do you have insights on this? I could potentially just swap the 345s for 370s. https://www.realoem.com/bmw/enUS/sho...diagId=34_1825 https://www.realoem.com/bmw/enUS/sho...diagId=34_1825 |
01-07-2022, 01:39 AM | #330 |
Rep 951
M5 Caliper Carrier (Bracket) is physically different from 550i Caliper Carrier (Bracket) and not just a paint difference.
Take a look at this M5 Caliper (Carrier with screw holes exposed) : https://www.ebay.com/itm/14409984599...MAAOSwMUBg4IYb vs These 550i/650i calipers: https://www.ebay.com/itm/22439635050...temCondition=4 You can get the M5 brackets and fit your 550i calipers on them and run 370x24 rotors. So basically, the M5 rear calipers and carriers can be bolted straight on to non-M F10s/F06 hubs and run 370x24 rotors. Hope this helps |
Bulwa1.50 |
