2010 2011 BMW 5 Series Forum F10 Just ran a 12.32 after new plugs and some adjustments! |
09-05-2019, 12:28 PM | #1 |
Rep 1,442
Drives: 2011 535i 6MT
I just got some nice new plugs and regapped them to .020 after getting some rich to lean errors. Old plugs were white and powdery (which means hot and lean) and they had a .032 gap. I have an 02 simulator (due to catless dp) which allows me to control how lean or rich I am so I set the voltage down to .75 which per the simulator is the richest acceptable value before throwing CEL for OBDII.
It ran a 12.32 which I was really happy with. Not sure if anyone else has any 1/4 mile times... seems like a lot more people in the 3 series are modding the n55's. Here is what I have: AFE chip Catless DP Armytrix exhaust CDV delete (6sp MT) BMS Intake Wagner knock off FMIC O2 simulator 93 oct |
09-05-2019, 01:39 PM | #2 |
Rep 742
Drives: '13 F13 M6, '94 JDM Supra 5MT
Incredible! 0-60 in 4.5 and its a RWD car? Wow!
09-05-2019, 01:50 PM | #3 |
Rep 1,442
Could the OBD Fusion program itself be off? Or are these #'s reasonable? I have no idea... it is reading right from my ECU and uses GPS I believe...
09-06-2019, 12:56 PM | #5 |
Rep 1,442
It's an electronic slip so it's not messed up. I did some research and it's completely possible to have that ET with those trap speeds.
I was more curious if anyone else with similar mods has any 1/4 times they could share. |
09-06-2019, 01:02 PM | #6 |
Rep 1,299
Stock 2011 535i does 1/4 in 14 seconds. There is no way that car can do 12.3 with just those mods and AFE chip. If it were true I should be doing 10 seconds with my pure stage 2 lol which I highly doubt that I am even near that.
09-06-2019, 03:18 PM | #7 |
Rep 1,442
I figured as much, that's why I posted this. I don't think that OBDII reader is accurate though, in theory, it should be. Have you not dyno'd your car or ran a 1/4 mile? What mods do you have?
09-06-2019, 04:15 PM | #8 |
Rep 1,299
12.32 would mean you are almost as fast as stock GTR that comes with 595hp and does 1/4 mile in 12.1 seconds with curve weight of 3800~.
Pure Stage 2 VRSF FMIC Catless DP MP Exhaust Chargepipe Custom turbo inlet K&N Aircharger Intake xHP Trans tune MHD with custom tune LPFP Stage 2 93 octane Next on list is probably: Custom intake Precision racewerk coils Helix HPFP Overdrive Unit TMap N20 sensor Last edited by ziekxq; 09-06-2019 at 04:34 PM.. |
09-07-2019, 05:53 PM | #10 | |
Rep 1,299
His F10 with AFE is probably making 310whp + 4200 pound vs m235i close to or at 400whp with 3500 pound. Last edited by ziekxq; 09-07-2019 at 06:02 PM.. |
09-08-2019, 11:25 AM | #11 |
Dream crusher
984
Rep 2,421
Also depending on which year N55 you have, the outlet on the DP is either 3.5" or newer ones 4". Plus N55's ECUs are not the same across the board. Meaning what is programmable and what is not (missing tables).
IG: @bmwdoubles |
09-10-2019, 04:13 AM | #12 |
Rep 49
No Disrespect, I would take those times with a pinch of salt. For the mods you have I would estimate low 13s to high 12s
I suggest you try simulating that time using a Dragy or Vbox. |
09-12-2019, 04:24 PM | #13 |
Rep 292
Is there difference between 3.5" and 4" in power gain.
09-12-2019, 04:31 PM | #14 | |
Rep 292
I see you have XHP trans, it it any good. My friend has it in his 340i and made the car slower, because less boost !! less traction.
09-12-2019, 05:08 PM | #15 | |
Rep 1,299
To me xHP is awesome... Fast shifts, consistent boost in all gears, and I have AWD so no traction issues. Only time I had traction issue is when I changed launch control power by 35 percent over stock. Dropped it down to 25 percent over stock on launch control and no traction issues. He can setup torque values by gear to get better traction. |
09-13-2019, 03:52 PM | #16 |
Rep 1,442
What is the deal on the n20 TMAP sensor, what is the benefit there?
09-13-2019, 04:07 PM | #17 |
Rep 332
If you are exceeding 21PSI, the stock 2.5 bar sensor can't read it, so you go to the 3.5 bar that is standard on the N20 platform. It isn't needed on stock turbo, but for aftermarket that goes higher boost you need it.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD! 1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped |
09-14-2019, 01:33 AM | #18 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
09-19-2019, 09:33 AM | #19 | |
Rep 116
So I'm interested in the 02 simulator. Did you do this to the primary, pre-cat wideband 02 sensor, or the one after the cat? IIRC the N55 F10 has just two 02 sensors, the primary wideband and the one after the cat.
I didn't think the one after the cat did much other than to check the catalyst efficiency. Did the 02 simulator change the driving response when you changed the voltage offset to make it richer? My N55 seems to naturally run lean and it hesitates and is not responsive. I don't think BMW ever gave it enough tip-in fuel (acceleration fuel). I'm wondering if this 02 simulator can get it a little richer, and therefore more responsive. Quote:
09-21-2019, 10:22 AM | #20 |
Rep 1,442
The simulator was post-cat since I have a decatted downpipe. I wrote up a tutorial on it if you want to read it. But after doing my research I would not recommend the 02 simulator I did, there are simply better options out there. It cost me about 200 bucks total and I'm going to ditch what I did and do an MDH flash. That's a lot better way to go and should only cost about 500 total. The problem with the o2 simulator as well is the fact that it's static. It doesn't ever change the signal to the ECU. You set the voltage, and that's what it is, period. So it doesn't adjust fuel flow and I have been getting lean errors periodically when I'm at higher RPMs. An MHD tune should adjust the fuel based on the tune I load and also remove the CEL for the O2 since I don't' have a cat. I hope this helps. Thanks.
09-21-2019, 11:13 AM | #21 |
Rep 1,299
You want to do o2 simulator after the cat. I would recommend you take it off asap before you damage the engine or something. The order it should be in is: Turbo > (Catless dp > first o2 snesor > no cat since it is Catless > similulator) > exhaust piping.
I put brackets because that is all on downpipe. The first o2 sensor help ECU decide the AFR and second one after the cat just monitors if there is a cat and it is doing its job. So placing the simulator there tricks the second sensor. I have o2 bung installed there. |
09-22-2019, 11:42 AM | #22 |
Rep 1,442
The O2 simulator is after the cat in my case. That's the one that causes a CEL since there is no cat.
