2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Bimmercode & Enhanced Bluetooth
      03-22-2018, 11:05 AM   #1
JLR1969
Drives: Kubota GR1600
Looked everywhere and cant find out how to code EBT via Bimmercode Expert Mode....
Has anyone managed this?
Thanks
      03-24-2018, 08:32 AM   #2
Apples12
Drives: 520D LCI auto
6ns via vo coding?..
      03-24-2018, 09:45 AM   #3
JLR1969
What does that mean?
      03-24-2018, 09:58 AM   #4
Apples12
So with the f10 you can code enhanced Bluetooth (6ns) by adding it to the vo and coding it to the car, I've done this to mine and it works beautifully
      03-24-2018, 12:19 PM   #5
JLR1969
Do you have a step by step guide at all?
      11-26-2018, 04:09 PM   #6
ColiFeCape
Drives: 2017 435dx F32 M Sport
Hi,
apples12, what year is your car. Mine is an f10 lci 04/14 and still a bit wary of trying VO to 6NS.
I have the software,but this laptop aint reliable enough
I`m going to try bimmercode expert working through the list, but does it still give the same result in the end?
Or does it need some bespoke tweaking?
Cheers for anyones thoughts
Coli
      11-30-2018, 05:22 PM   #7
ColiFeCape
Enhanced bluetooth through BimmerCode
Coded this today with bimmercode expert mode and it all works great with a few changes to the original list.
I left one microphone active, svs , system tts and CE device recognition as they were to avoid losing the voice control.
Still don't have album art or sms though.
The highlighted lines are the ones I had to change for my car which I believe has the combox built into NBT headunit.
Ive attached my list, mebbe helps somebody
Coli
      12-02-2018, 10:53 AM   #8
aplinhares
Drives: F10
Doesn't need to code NBT?
      01-17-2019, 08:43 PM   #9
neverdone
Drives: X5, 335, Ford Lightning, 63 me
Coli
Well I've found out that I have NBT combox finally, so I'm going to try this, unless you have changed anything recently, is it still working well?
      01-19-2019, 04:15 PM   #10
neverdone
Coli
Well I coded it the same as you and got the same results but haven't tested much yet. Much better than the aux cable still, at least I can change songs through the car.
      01-23-2019, 06:43 PM   #11
ColiFeCape
Tiny update.
One sms message came through in office.
in weeks.
Why so spurious?
      09-03-2019, 01:15 PM   #12
Gjohnson7
Gjohnson7's Avatar
255
Drives: 11' BMW 535i, 12' Lexus RX350,
2011 535i  [0.00]
Can someone advise if this is possible with Bimmercode?
I have a 2011 535i and I am trying to activate Enhanced Bluetooth, but no luck yet. I do have the Comm box in my trunk and I can connect via Bluetooth for calls, but no media.
I have tried the process attached above, but don't have some of the modules listed.
Any help would be greatly appreciated.
      09-03-2019, 04:59 PM   #13
Go into BimmerCode expert mode and then follow the instructions above. The regular coding section seems to be set up for basic coding. I had to go into expert mode to code in the compass and variable light distribution.
      09-07-2019, 09:47 PM   #14
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
I've tried coding this via BimmerCode in Expert mode, but it seems I still don't have all of the modules referenced.
If I attempt to VO code this with Esys, can someone please advise what's best process. From the DIY instructions on coding I am assuming I would add the 6NS however the instructions mention deleting some other code. What would I need to delete in this scenario?
Also, is there a list of others beneficial VO codes to add while I am knocking this out?
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771
MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster.
      09-09-2019, 08:26 AM   #15
Unspec
Unspec's Avatar
1295
Drives: 2015 BMW 535xi
I don't know what codes to replace with 6NS, since my car came with enhanced BT, but as for good VO codes:
Remove:
8S4 (variable light distribution). Your headlights change their patterns a bit depending on speed.
Add:
2TB if you don't have Sport Automatic Transmission). Unless you FDL code to disable paddles, it'll throw a missing paddles error. Up to you if you care about this or not.
If this is your first time VO coding, track what FDL codes you have, and VO code all modules besides DME with engine running.
      09-09-2019, 01:32 PM   #16
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
Ok, well this is my first time coding via ESys. I also have Bimmercode, so I've coded the power folding mirrors, sports display and removed the legal notices.
Sorry, I'm still learning they system. Are you saying I can VO code these features as well or will I just need to recode them with Bimmercode.
      09-10-2019, 07:01 PM   #17
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
Can anyone shed some light on this for me. I just did my first ESys coding session and I activated and added the 6NS to my CIC, however I don't seem to have bluetooth. I went through the remove and pair process and it's still not there. Furthermore, the instructions I went through said to code the "HU_CIC" and then code the "CMB_MEDIA" ECU if present. I cannot find this ECU in my SVT list, however I have a silver computer box mounted to above my rear driverside wheel. If this isn't the Comm Box then what is it?
FYI my car is 2011 535I with a build date of 6/10. Below is what I got from a BMW VIN Decoder for options.
Vehicle options
S1CAA  Selection of COP relevant vehicles
S1CDA  Brake Energy Regeneration
S205A  Automatic transmission
S212A  ABS discontinued
S258A  Tire with run-flat functionality
S2HMA  BMW LA wheel, Radial Spoke 237
S2VBA  Tire pressure display
S302A  Alarm system
S319A  Integrated universal remote control
S322A  Comfort access
S3AGA  Reversing camera
S403A  Glass roof, electrical
S415A  Sun-blind, rear
S416A  Roller sun vizor, rear lateral
S423A  Floor mats, velours
S430A  Interior/outside mirror with auto dip
S431A  Interior mirror with automatic-dip
S459A  Seat adjuster, electric, with memory
S488A  Lumbar support, driver and passenger
S494A  Seat heating driver/passenger
S4CEA  Fine woodgrain vers., Fineline anthrac.
S4URA  Ambient interior lighting
S508A  Park Distance Control (PDC)
S522A  Xenon Light
S524A  Headlight control
S534A  Automatic air conditioning
S5DSA  Emergency release, luggage compartment
S609A  Navigation system Professional
S615A  Expanded BMW Online Information
S620A  Voice control
S639A  Preparation f mobile phone cpl. USA/CDN
S645A  BMW US Radio
S655A  Satellite tuner
S677A  HiFi System Professional DSP
S697A  Area-Code 1 for DVD
S6AAA  BMW TeleServices
S6ABA  Control for Teleservices
S6FLA  USB/Audio interface
S6NFA  Music interface for Smartphone
S6UHA  Traffic Information
S823A  Hot-climate version
S845A  Acoustic belt warning
S850A  Dummy-SALAPA
S853A  Language version English
S876A  Radio frequency 315 MHz
S880A  On-board vehicle literature English
S8KCA  Dummy-SALAPA
S8S4A  Decoding variable light distribution
S8SCA  Telematics access request,country-spec.
S8SMA  Car ident. number visible from outside
S925A  Dummy-SALAPA
      10-03-2019, 03:07 PM   #18
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
BMW is stupid for making the enhanced BT a option for some years then standard for some. Very confusing. Bluetooth should just work. Good think we can code it given it is not before 9/10 prod.
      11-15-2019, 11:33 AM   #19
neverdone
Tiny update.
in weeks.
Why so spurious?
I'll add to this. So, I've never gotten a message since I've coded this. BUT, I just got a Samsung S10, went through all the settings on Bixby routines and setup a driving routine. This in turn reads out sms messages aloud, but without a reply option.
Its something lol
      11-21-2019, 11:13 AM   #20
marmit2017
marmit2017's Avatar
Drives: 11 535i 13 328i xDrive
What is enhanced Bluetooth? I believe my car has it but not exactly sure what it is
      11-22-2019, 09:51 AM   #21
Unspec
Unspec's Avatar
1295
https://www.bimmer-tech.net/blog/ite...nced-bluetooth
Main things: Library browsing via BT, can connect 2 phones at once, an additional mic above the passenger, and a few other things like Office.
A good way to check for it is to see if you have the second mic above the passenger.
      07-17-2020, 08:56 AM   #22
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
Can someone please help me with a quick question. I currently have the TCU and MULF. I just purchased a Combox #84109257153 for retrofit as well as a TCU & MULF adapter harness off ebay. Can someone tell me if I will need the MOST termination loop and bluetooth cable as well? Sorry, this starts to get confusing after hours of searching.
