2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes What brakes, pads and rotors to use for daily driver 535i xdrive
      10-13-2018, 05:46 PM   #1
neverdone
Drives: X1 35i
Like the title, I was looking at rock auto, unsure of what to get, first time changing brakes on this car. Should I do any sort of upgraded brakes without going big brake conversion...
      10-13-2018, 06:05 PM   #2
ey2001
ey2001's Avatar
115
Drives: F10 535i 6spd
Stick with oem.... I tried hawk and akebono.. the initial bite is not the same as oem
      10-13-2018, 06:15 PM   #3
neverdone
Drives: X1 35i
What about rotors? Why would I want drilled/slotted?
      10-13-2018, 07:08 PM   #4
Drives: 2014 535i M Sport
Looks...
      10-13-2018, 07:36 PM   #5
neverdone
Drives: X1 35i
Lame. Well where do you guys get your parts from?
      10-13-2018, 08:31 PM   #6
socale39
Drives: 04 545i SMG
Donít buy drilled or slotted rotors. They are noisier and eat pads faster. Still with Zimmerman rotors and either Pagid or Textar pads.
      10-14-2018, 06:05 PM   #7
anthonygan
Drives: 2015 BMW 535i XDrive
I would get EBC pads and rotors!! They are great and have lots of stopping power!
      10-14-2018, 07:51 PM   #8
Pito11213
Drives: 2013 alpine white 528 xdrive
I just installed OEM rotors and pads. New brakes feel awesome. I'd say stay OEM.
      10-16-2018, 11:28 PM   #9
07e92
Drives: 07 335i
akebono for less noise, long lasting life, and super low brake dust
      11-02-2018, 04:13 PM   #10
rkarl535
rkarl535's Avatar
Drives: 535i M Sport
I did mine for the first time a couple weeks ago and bought from FCP Euro. I have had the brakes and rotors replaced 2 x's prior with all BMW parts. I never liked the riveted center hub on BMW rotors and they seemed to have issues like many others with warping. As BMW states it, I am a spirited driver.
I changed and went with Zimmermann rotors(Plain NOT slotted/drilled) and Akebono ceramic pads. It has been 3 weeks and I am VERY pleased with the performance thus far. The stopping power is just as good if not better and the rotors are a bit heavier. Her his the kit part # for reference:
Brake Kit - 34116775277KTF1
Rotors, Pads, Sensor, brake grease
The drilled and slotted have mixed reviews but overall for a daily driver standard rotors are good. The drilled/slotted do look nice, however, they wear pads faster and don't offer much benefit.
There is no need to stay with the OEM for these parts and you will find it very easy to change. Good luck!
      11-04-2018, 12:20 PM   #11
sesh1957
Drives: 2009 X6 35i, 2012 535i xdrive
Send a message via Skype™ to sesh1957
FPC Euro has the Zimmermann/Akebono stock kits, front and rear for about $500, the oem mfg, or the Powerstop kit is a little less, drilled/slotted/ceramic, K6023 on Amazon for $431. I have used the powerstop on a gs lexus, loved them and have the kit in the garage for my 535xi when I have time. Got BMW blue caliper paint as well. Can't wait to get it done. Maybe get some black wheels as well.
      11-12-2018, 11:51 AM   #12
neverdone
Drives: X1 35i
Well I guess I didnt update the thread. There was actually a story to go along with changing the brakes...
I was driving one day and there was a bad squealing when I was stopping coming from the passenger side. I'd just changed to winters so I thought, maybe it was the dust shield.
Pulled over and checked, pushed back the DS and checked again, no luck. When i got home, i took the wheels off, DS was fine, looked in the caliper window and the pads were crumbling apart, like wtf.
I only bought the car 4 months prior to the post from BMW and I could have sworn that the check they did stated I had lots of life left, so I looked at it and sure enough, it said they had 8mm left, not the case.
I came in here asking about brakes and ended up ordering them...then, afterthought. Called BMW told them what I found and brought it in to see what they would say...next thing I know, I get a call from BMW " we are replacing all front rotors, pads and sensors free of charge" . Obviously without admitting it, admitted wrong by doing this....super happy with that, however, I'm now out $200 because I jumped the gun on buying brake parts.
TL;DR
BMW replaced my brakes for free lol on my 2014 535.
      01-02-2019, 08:04 PM   #13
sesh1957
I put the power stops from Amazon, $485 on mine this weekend. I have now had these on a Lexus GS and Passat TDI, they have been smoother and had better-stopping power in all three cars, wet braking improves as well. My wife noticed the difference in the GS! Could not resist the caliper paint from Walmart, one can made it, $5 or so.
      01-04-2019, 05:24 AM   #14
wcr3d
Drives: 2013 535i XDrive M Sport
Stick with OE parts.
If you purchased CPO then yes they check and probably why they replaced them.
Also they just measure, 8mm thickness can crumble under the right circumstances.
Glad they took care of you.
      01-04-2019, 05:14 PM   #15
sesh1957
You can pay for OE, I would buy the OEM who sells to BMW if I were to go stock, check out FPC Euro for both. These are the same dimensions as the OE I took off. What 8mm dimension circumstances are you referring to?
      01-17-2019, 11:13 AM   #16
lap100
Drives: 2016 BMW 535xi
Hey everyone. First time poster, long time admirer. I'm due for full brake replacement on my 2016 535xi with 70K KM . I'm getting strong vibration now when pushing the brakes which means my rotors are warped.
Spent a longtime trying to research what's the best combination. I'm pretty much set my mind now on Zimmerman rotors, but now am not quite set on which Pads?
Researching made me conclude that Pagid and/or Textar are closest things to OEM for bite force & quality. Is that true? And is there something as good as OEM pads bite force which result in less dust?
2016 535xi Mkit, carbon black MPPK & BMS+
      01-17-2019, 02:56 PM   #17
TEF
Drives: 16 X3 28d/16 535d xdrive
It's unclear why one supplier's cast iron disk would be any better (or worse) than what is marketed by BMW as OE rotors. Assuming reasonable quality assurance, why would a Centric brand rotor be inferior to, say, a Zimmerman? Pads can differ greatly depending on friction material used, but most will not just fall apart in use. Currently, my '16 X3 with only 30K miles has a warped rotor(s) and those as directly from BMW since I bought the car new. How would another brand of rotor perform any worse?
Relative to rotors sold by Rock Auto, it's hard to understand why some are sold as "daily drivers" and others in the performance section. When looking at the photos the only distinction might be an anti-rust coating that doubles or triples the price. If one intends to do their own work, I would go with a middle-priced pads and rotors and take a chance.
      01-17-2019, 03:32 PM   #18
I've replaced many, many a brake/rotor over the years. I've spent more money on aftermarket brake parts than I can count. In my experience the best (for dust and performance) aftermarket pads were Raybestos QuietStop. I had Porterfield's once but they dusted just looking at them and they needed quite a bit of heat work. Initial bite was severely lacking, but when they did grab it felt like I would be thrown through the windshield!
For the rotors I would stick with OEM.
From my experience, OEM is the way to go. It's not like the "old days" when the aftermarket produced much better parts that the OEM. Now days I would trust the OEM shocks before a Monroe shock.
      01-18-2019, 04:36 PM   #19
sesh1957
I agree with TEF, as my car has warped OE rotor twice. Aftermarket needs to match dimensionally with the calipers. I have put Powerstop on my Lexus GS, VW Passat, and 535xi, they feel better on all vehicles and have no issues and reduced brake dust. This issue with rotating part weight is insignificant, don't know why BWM did an AL/cast iron disc?
      01-21-2019, 11:15 AM   #20
lap100
Thanks for the tips. Seems like a objective opinion about this based on a persons personal taste in brake feel. Is there any real world benfit with weekend spirited driving - to go for Sllotted/Drilled rotors? Stay Powerstop or Stoptech?
      01-21-2019, 02:55 PM   #21
sesh1957
FPC Euro, BMW Brake kit is $893, Zimmermann/Akebono $511, PowerStop $485 (Amazon Prime) 449 Rockauto, Stoptech $800?
The stoptech did not seem to have the hardware, I picked the Powerstop as the best value.
My other upgrades are similar, Burger stage one and an Airaid 700-469 Universal Clamp-On Air Filter, fits easily with a 3" 30 degree AL tube. Next is muffler replacement with glass packs. I guess I am on the cheap side.
      01-23-2019, 10:16 AM   #22
lap100
done.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
