2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Tyre pressure sensors
      10-14-2018, 10:03 AM   #1
trebor4444
Drives: BMW 520d Luxury 2013 LCI
Ok, I have a set of winter tyres that were on a 2013 f10. They worked and the idrive system knew when I swapped between summer and winter sets in relation to the tyre pressure monitor system (I didn’t have the pressures shown)
However I have just taken a 2016 which now also has the pressure reading on the idrive so will I need to do anything to the existing wheels. As far as I know they don’t have any sensors in them?
Any help or advice appreciated
Thanks
      10-14-2018, 12:03 PM   #2
Johnny Grabble
Drives: 530d
If you didn't have the pressures shown on the iDrive, this was the tyre pressure warning system, TPWS, which operated off the ABS system, detecting changes in wheel rotation related to loss of pressure. No special valves required, standard rubber-stem. Tyre pressure measuring system (TPMS) on LCi (post late-2013) models requires special valves which link wirelessly to the iDrive to show the pressures. Put your VIN into realoem.com then browse parts and select wheels and the valve part numbers will appear. The TPMS valves are not rubber but usually silver coloured.
      10-16-2018, 05:05 PM   #3
robbiep
Drives: VW e-Golf !
In other words : Yes, you will need to get new sensor-equipped valves on your winter wheel set, which can detect and transmit the tyre pressures to the car systems.
      10-17-2018, 06:04 AM   #4
xenon
xenon's Avatar
England
1394
Drives: 2021 G21 330i M-Sport
Or just drive with the warning on. You can also code the TPMS off and TPWS on.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      10-17-2018, 01:06 PM   #5
trebor4444
Thanks Xenon, would that affect anything, cut the power/put into limp mode? Make the vehicle illegal?, appreciate I would need to manually check the wheel pressure, but I do that every couple of weeks anyway. (Sorry if the questions sound stupid)
      10-18-2018, 01:38 AM   #6
xenon
xenon's Avatar
England
1394
No the car does not go into limp mode and it's not illegal either. I drove a winter like that and just kept an eye on pressures like we did in the good old days.
Ian
      10-18-2018, 02:56 AM   #7
trebor4444
How difficult is it to code? I have BimmerCode app and haven’t dabbled with esys is. Also read you need to pull a fuse out too is that right ?
      10-18-2018, 03:53 AM   #8
xenon
xenon's Avatar
England
1394
I didn't pull any fuses out. I don't know if Bimmercode will do it but ESys will. I have the settings somewhere.
Ian
      10-19-2018, 11:21 AM   #9
trebor4444
If you could find the settings that would be greatly appreciated!
      01-22-2019, 08:01 PM   #10
neverdone
Drives: X5, 335, Ford Lightning, 63 me
