11-11-2018, 03:23 PM | #1 |
Rep 14
Stupid Rock Chip
Hey all,
Got sniped by a rock/pebble in the front, is this easily fixable? Don't mind taking into a shop but wanted to get the community's thoughts first. Thanks in advance... |
11-11-2018, 07:43 PM | #3 |
Rep 14
11-11-2018, 09:50 PM | #4 |
Rep 5,362
A body shop will definitely want to respray. Check out some YouTubes on scratch repair. There are some good ones and then you can decide on which course you want to take.
11-12-2018, 01:52 AM | #5 | |
Rep 659
Done right, yes they will want to feather it out so the new paint blends into the old. It can run several grand easy. As suggested above, have a look at youtube and decide what is best for you. |
11-16-2018, 11:02 PM | #6 |
Rep 14,522
way too deep! you'll have to have a body shop smooth that down back to the base. so you're pretty much respraying the whole front
11-17-2018, 10:12 AM | #7 |
Rep 697
Drives: 2013 535xi
I have a product called Langka paint chip repair as part of my car care arsenal and it works exactly as advertised. It can repair your paint chip to near perfect condition using BMW touch-up paint. If you want to try something at home that does not require re-painting anything, I'd recommend starting there. The technique you use to smooth out the repair takes a bit of practice and patience, but it does work well.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
11-17-2018, 01:04 PM | #8 | |
Rep 5,362
11-17-2018, 04:34 PM | #9 |
Rep 14
Thanks all. Went and got a couple estimates today which ranged from $1-3k. Once I get some time, I may try some of those products mentioned. In the case where I completely make it worse, no harm since the fix would be respraying the front end.
Thanks again for the recommendations, appreciate the advice... |
11-17-2018, 05:29 PM | #10 |
Rep 697
Drives: 2013 535xi
I've used Dr. Colorchip too. It works reasonably well for repairing the paint on a front bumper that has seen many small rock chips and gouges, but it only provides a very thin coating so the chips are still noticeable up close, but at least the color matches so the chips seem to disappear from a distance. The Langka product actually allows you to fill a deeper or larger chip / scratch with OEM touch-up paint so that it forms a bubble or blob that is raised with respect to the surrounding area. Once the touch-up paint is mostly but not fully cured, you then use their 'blob eliminator' product to smooth out the bump so that the touch-up paint blends right into the surrounding area with no visible chip or gouge.
11-17-2018, 06:43 PM | #11 | |
Rep 5,362
