2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Charge pipe issues
      12-14-2018, 10:52 PM   #23
jonobro
Drives: bmw f10 535i
Originally Posted by burro_blasta View Post
Originally Posted by jonobro View Post
How do you think it looks now ?
Sorry for the delay...looks normal from here. Are you still getting the problems?
I don't think so but car has been shutting off and putting itself into neutral. I feel like throttle response should be better maybe a ECU tune would help
      12-14-2018, 11:08 PM   #24
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
You’ve definitely got a massive air leak. When engine stalls the transmission automatically goes to neutral.
      12-14-2018, 11:57 PM   #25
jonobro
Due to cp correct ?
      12-15-2018, 08:36 AM   #26
NinetyEight740
2010 E91  [0.00]
Well if it all started after installing charge pipe, I’d say most likely. I would either reinstall factory charge pipe or smoke test the intake system. Smoke testing would show you where the air leak is for sure.
      12-15-2018, 10:37 AM   #27
jonobro
Well if it all started after installing charge pipe, I'd say most likely. I would either reinstall factory charge pipe or smoke test the intake system. Smoke testing would show you where the air leak is for sure.
How do I smoke test ?
      12-15-2018, 10:49 AM   #28
NinetyEight740
2010 E91  [0.00]
With a smoke test machine. Pay diagnosis time to a shop to do it if you do not have one.
      12-15-2018, 12:44 PM   #29
burro_blasta
Drives: 2013 535 M Sport
It's most likely bc of the CP since it all started after the install.
For air leaks, they could possibly be from that rubber sleeve on the bottom (which now looks OK), or those holes (which you said are closed), or where it connects up top to the throttle body (but that looks OK in the pics).
The last thing related to the CP I could think of is the sensor itself. If the sensor is effed up then it's going to tell the engine the CP is wrong even if it's right. Did you double check to make sure the sensor on the CP is back on right? Maybe the other sensor up by the air intake you might of had to remove for the install? Offhand I forget which is named what (MAF etc...shows you how well I know these engines so far...). When I installed mine I obvi had to remove the sensor plugged into the CP but also that one connected to the air filter intake tube, worth checking...
      12-15-2018, 03:29 PM   #30
jonobro
How much does one cost ? A shop would try to screw me over
      12-15-2018, 06:10 PM   #31
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
The shop I work at charges 1 hours labor to thoroughly pressure test a charge air system with high volume smoke. Smoke machines and master tech labor isn't cheap, but you'll get your answer. It is usually something dumb, a simple oversight, rolled/missing oring etc and that is usually correctable and retested within that time allocation.
I can't tell you how many N5x cars have come in completely missing the oring at the throttle body because the aftermarket charge pipes don't usually come with it and they don't change it over from the stock pipe. #2 source is the intercooler pipes not properly seated and securely clamped into place.
If resolving your issue quickly and accurately is screwing you over by all means keep doing what you're doing.
cdmulders326.50
      12-15-2018, 06:14 PM   #32
burro_blasta
Did you double check the sensors?
      12-15-2018, 09:32 PM   #33
jonobro
The car is randomly shutting off and putting itself into neutral.. not sure why the instal seems perfect to me and now my car is making a random noise..
      12-16-2018, 07:10 PM   #34
NinetyEight740
2010 E91  [0.00]
Where are you located? It may appear perfect to you, but the faults your car has are indicating that you’ve got a n air leak. Sounds like you’ve gotten in over your head, time to take to someone who knows what they are doing. Also, no shop is going to rip you off if they are a reputable company.
      12-16-2018, 07:15 PM   #35
jonobro
True man, what should I tell them is wrong I have INSTA that shows what's all wrong so I can see shouldn't I tell them instead of having to pay to diagnose ?
      12-16-2018, 07:23 PM   #36
NinetyEight740
2010 E91  [0.00]
You are paying for their knowledge. You are paying for their equipment. You are paying for their time. Do you want your car fixed or not?
      12-16-2018, 08:14 PM   #37
top ramen
Drives: Schwarz II 535i
Trying going back to stock and see if the symptom is still occurring.
      01-07-2019, 04:44 PM   #38
anthonygan
Drives: 2015 BMW 535i XDrive
I just finished installing my charge pipe today! Everything went smoothly, putting the new charge pipe in a a tad difficult. But either then that easy! I went for a test drive and everything works fine, no check engine light , car pulls hard, is great!
      01-17-2019, 06:42 PM   #39
Freak1c
Freak1c's Avatar
145
Drives: 2018 M3 ZCP MW
BTW, not that this is the cause of your issues, from your pic did you know your missing the chargepipe mount in the middle top of your chargepipe.
