12-19-2018, 10:45 AM | #1 |
Rep 13
Update : Fixed
The car has been pulling to the right for the past 6 months. Around that time I also noticed that the right rear tire looked bent with the whole right side not looking straight. So i went to the dealership this past week and they told me I had cracks on my thrust rod bushes and wishbone lower control arms. So they changed them both and did the alingment. Now the pull is gone but the rear wheel still looks bent from the back.
Ps I didnt get into major accidents so I dont think its my frame. Atleast I hope so. Update FIXED : May 2019, after putting the car on a frame machine. It turned out that the subframe shifted a bit to the back. Then they had to put it back in place. As of now the car has NO pull. It doesnt look bent when looking from the back. If anyone gets into alot of alignment issues. And regular tire shops or dealerships that cant pinpoint the problem. Go to a certified bmw body shop and they will align ur car like its new. |
12-21-2018, 01:30 PM | #2 | |
Rep 915
Instgram @burninja
12-22-2018, 07:16 AM | #4 | |
Rep 14,522
also, according to the spec sheet the camber looks within specs
12-22-2018, 01:50 PM | #5 |
Rep 915
From the picture thats what I see, its hard to tell without physically being there. Try measuring the tire to fender length on both sides and check the difference, also you can use a string from the front to rear on both sides make it square though and measure. Set up 4 cones or whatever to hold the string and see if it is unaligned.
Instgram @burninja
12-22-2018, 07:10 PM | #6 |
Rep 116
Drives: 2021 G05, 2014 F10, 2009 E90
Passenger side, rear wheel looks like it's toed in (angled towards the centerline of the car facing the front).
Even if the car is running straight, you'll want to get that fixed if possible. It'll wear quicker than your other three tires. |
12-24-2018, 08:44 AM | #7 | |
Rep 1,873
It is still true that this specification wears rear tires faster, but that doesn't mean something is broken. |
12-25-2018, 07:24 AM | #8 | |
Rep 14,522
I have a slight and I mean slight camber but I requested to have the wheel as flat as possible when I had my alignment done just to improve the longevity of the tire and not having that inner camber wear
01-09-2019, 03:15 PM | #9 |
Rep 161
Drives: 2015 535i
BMWs are known to have negative camber coming from the factory. Most find themselves replacing tires when they look good from the outside but when you take the wheel off and look on the inside of the tire you have excessive where compared to the rest of the tire. When you get the car aligned ask them to try to get your camber as close to zero as possible.
2015 F10 535i
FBO BM3 Pure Stage 2 Dorch Stage 2 HPFP E50 tune by Cary Jordan EOS EkP Module Walbro 525 LPFP Variant Argon 20? Wheels E60 M550i Sold “Im a crazy car guy” If it has a motor, it has my attention |
