2010 2011 BMW 5 Series Forum F10 2013 535i upgrade screen |
01-04-2019, 03:21 PM | #1 |
Rep 5
Does the 2013 535i only have the small screen or can it be retrofitted with a larger screen. I want to replace with only OEM screen and have seen some 8.5 inch ones or something.
I am trying to find out if there are two screen sizes or just 1 and if I can buy the larger screen on Ebay or something (part number?) and replace it myself without having to obtain a new cable. Thanks for your feedback! |
01-04-2019, 05:44 PM | #2 | |
Rep 5,362
01-04-2019, 07:02 PM | #3 |
Rep 14,522
correct me if i'm wrong but doesn't this also have to be coded to work? I wanted to do mine but never did because of what the end cost was gonna be. not just a simple plug and play and call it a day. it involved coding among other things
01-05-2019, 07:19 PM | #5 |
Rep 34
Do you have CIC or NBT based headunit?
My 2013 535i came with 6.5 inch screen. The software in my headunit has the CIC user interface. The Bimmercode app says my headunit type is CHAMP2. It also identifies the headunit as HU_CICHB. Even though my headunit has CIC user interface, my 6.5 inch screen still used a NBT (6 pin) LVDS cable to connect to the headunit. I verified this by looking at both the cable and connector. Bimmercode didn't give the option to code a different resolution on my CIC based headunit unit. And Ive read that it's because only the NBT based headunits allow you to code a different resolution to be sent to the screen. Put differently, even if you have a screen that uses NBT connection to the headunit, you still need the headunit itself to be NBT in order to have access to the option to code the resolution that the headunit sends to the screen. A CIC unit apparently might not give the option to select a different resolution. This is just what I've read. I'm no expert on this. If all this stuff is true about not being able to change redolution on CIC headunits, then that could be why the 10.25 in Android replacement screens offer the split screen display option. So that the 6.5 in CIC folks who can't code their headunits to support a different resolution, don't end up with just a wider screen that tries to fill up it's available widescreen real estate by simply stretching the lower resolution that its getting from the headunit. Instead, the lower resolution can remain unstretched by occupying only part of the wider screen. While the other unoccupied part of the wider screen is filled with a widget graphic that shows some information that's placed there by the Android unit itself (fuel level and speed). Again, I'm no expert on this. But what I said about my car's particular setup is accurate because I checked it myself before ordering my Android replacement screen which now uses the 6 pin NBT cable to connect to my CIC based headunit. |
01-08-2019, 12:11 PM | #7 |
Rep 34
These pictures might help
lsturbointeg9155.50 |
01-14-2019, 10:06 PM | #9 |
Rep 5
I think I have the CIC. Would I be able to buy a NBT head unit/screen and replace my current CIC head unit/screen? My screen is the small one. https://www.ebay.com/itm/BMW-F10-F11...hwIL:rk:1:pf:0
03-21-2019, 08:03 AM | #11 |
Rep 20
As article says, 2013 F10 6.5" screen is NBT. But the unit in my car is the same as CIC (no red highligted choice like NBT). But LVDS port at the back of screen has 6 pins. Again article says that CIC has 4 pin LVDS. I'm really confused.
Maybe the article is wrong. Any comment ? |
03-21-2019, 11:22 AM | #12 | |
Rep 34
I'm in a similar situation. I have CIC menu system but my display uses the 6 pin LVDS connector which everybody says is the actual connector that NBT uses. I also connected ISTA+ to my car and it showed a chart that said my Headunit is CHAMP2. I don't know for certain if CHAMP2 can have either CIC or NBT interface. At the end of the day I did upgrade my 6.5 in screen to an Android display and I opted for the Android screen with the NBT connector and it's now installed and working great. So it seems 2013 cars might really be NBT after-all. I wish there was a more definitive way to settle this question once and for all.
04-17-2019, 03:38 PM | #13 |
Rep 20
I have HU_CHAMP2 (it is shown if I connect to car via e-sys). My 6WB can't show current fuel consumption in digital in BC (there is only average one). If I retrofit it to Android, is it possible to see current fuel cons. ?
I am sure that it can show it with NBT retrofit. Because in HU_NBT (e-sys) has a code value for this while HU_CHAMP2 does not have. |
12-30-2019, 11:30 AM | #14 | |
Rep 2
Thanks |
