2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
09-11-2018, 01:06 PM | #331 |
Rep 2
Coding Questions
I have a 2016 528 and have been successful and coding some options, but not others.
Accoustical_Lock_confirm doesn't seem to do anything. Is there a way to disable sound when locking with the remote, but leave the sound when unlocking? My car has the ability to dictate text messages, but only when parked. Dictation is actually allowed in CA while driving...is there way to remove this restriction using coding? Thank you Last edited by ZaphodB; 09-11-2018 at 01:11 PM.. |
09-16-2018, 08:55 AM | #332 |
Rep 107
Did you try with this in HU_NBT?
Disable Office Function Speed Lock-Out 3000 OFFICE_MESSAGES_SPEEDLOCK_CONDITION set to: nicht_aktiv Enable Full Text Lines in Office While Driving 3003 PIM_DRIVING_TEXT_LENGTH set to: whole text_07 |
09-17-2018, 03:33 PM | #333 |
Rep 87
hi guys
is it normal that engine management light comes on after odd flash ? reading ista d, it obviously sees faults from flashing stage but actual car is ok also i was under impression that EPS hasn't been updated because of below message but now its no longer on list of items to update. has it been flashed ok in the end ? https://ibb.co/h3WRme |
09-19-2018, 10:23 AM | #334 |
Rep 2
Thanks Bruno112.
I tried those setting, but it did not help...I couldn't actually tell if they did anything. Just to clarify, I can read and listen to message I receive, but when I try to dictate a reply, it tells me that the car needs to parked. |
09-19-2018, 11:39 AM | #335 | |
Rep 107
DVD-in-Motion activated: 3000 SPEEDLOCK_X_KMH_MAX Change werte to: FF 3000 SPEEDLOCK_X_KMH_MIN Change werte to: FF 3000 VIDEO_HANDBRAKE set to: nicht_aktiv 3000 VIDEO_FRONT_LOCKED set to: nicht_aktiv 3000 VIDEO_SPEEDLOCK_CONDITION set to: none=00 Disable Legal Disclaimers 3001LEGAL_DISCLAIMER_TIME set to: kein_ld 3001MACRO_CAM_LEGALDISCLAIMER set to: kein_ld 3001MACRO_NVICAM_LDISCLAIMER set to: kein_ld |
09-20-2018, 02:43 AM | #336 |
Rep 32
Hi,
(I am new on this forum) Just bought the cable and got the links to E-sys (E-Sys_Setup-3.27.1_RC_b44813), ESysLauncherPremiumSetup_2.7.1_Build_135 and v63.4_PSdZData_Lite but I can not get the ESys Launcher working. In the installation instructions its said - E-sys Launcher Premium to stop working after 30/12/2017. - To work around use Launcher ReArm and change the PC date back to April 2017. Followed the instructions but couldn't get it working. Am I going the right way or do I need another Launcher version? Thanks! |
09-20-2018, 06:22 AM | #337 | |
Rep 40,793
Drives: 2018 Alpina B6 650ix GC
TM built in Date Manipulation protection in newer Launcher, and that is why you have this problem. Only solution I have seen that works is a fresh install of Windows. Good luck with it.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
09-23-2018, 12:16 AM | #338 |
Rep 32
Thanks Shawn.
I gave it a try but turned out that launcher didnt install on virtualbox windows on my mac I need to find a spare laptop for fresh windows
Staying with bmw
10-03-2018, 03:46 PM | #340 |
Rep 40,793
PM sent.
10-12-2018, 03:07 PM | #341 |
Rep 42
Hello,
i have a F06 from year 2015 with a S302 Alarm System. i coded a bit arround to enable headlight and highbeam flashing if alarm is triggered, but it doesn't work. i tried to change this from nicht_aktiv to aktiv: FZD > 3002 DWA: Optische Alarmausgabe Fernlight = aktiv Optische Alarmausgabe Abblendlicht = aktiv if i trigger the alarmsystem, my flashing lights start flashing and the alarm signal chime, but no headlights or high beam... did i miss something? Any idea if i had to enable something else somewhere? At first I thought it might be because it was daytime, but i also tried it at night and the lights still have not flashed. hm :/ Last but not least: can you tell me, how i can increase the duration time of the alarm signal chime to 2 minutes or more? i think it should be done with this settings, but i am not sure about and also not which value will be the right setting for duration time. FZD > 3001: - Alarm duration time with external supply - alarm duration time in self-powering mode - alarm pause duration - duty cycle It would be very nice if you could help me |
10-14-2018, 07:23 PM | #342 | |
Rep 8,364
10-23-2018, 05:24 PM | #343 |
Rep 42
10-23-2018, 05:26 PM | #344 |
Rep 42
btw: can you help me also with that:
how can I increase the duration time of the alarm signal chime to 2 minutes? i think it should be done with this settings, but i am not sure about and also not which value will be the right setting for duration time. FZD > 3001: - Alarm duration time with external supply - alarm duration time in self-powering mode - alarm pause duration - duty cycle |
10-23-2018, 06:42 PM | #345 | |
Rep 8,364
No...I have never messed with duration, so I cannot help. |
10-26-2018, 09:03 AM | #347 | |
Rep 42
i checked my CAFD Files and can just found "FLE" but not "TMS" or "LHM". in "FLE" i found something like: PANICMODE_Idx => 02_Value RAIDALARM_Idx => F010Wert_SA552_ECE_LA_LL LWR_Offsets_B_PANICMODE => 01_Value LWR_Offsets_B_RAIDALARM => 01_Value but i have no idea, what i should change here to get my lights working if alarm is activated. |
10-28-2018, 10:08 AM | #348 |
Rep 99
Drives: 2015 550i
Last time I coded I used the cheat sheet And manually changed some codes. Has things changed recently? Also where can I get the latest files? When were they last updated?
Another issue is my with parking assist. Not sure if this is a coding issue. When I initially put the car in drive from initially starting up the car the parking Assist does not detect anything unless I put it in reverse. Not even sure if this is a thing. Any help would be nice. Thanks. |
10-31-2018, 12:15 AM | #350 |
Rep 40,793
PM sent.
10-31-2018, 10:14 PM | #351 |
Rep 418
I cannot install ESysLauncherPremiumSetup_2.8.2_Build_155.msi in the virtual machine. Can E-sys be run under the Vmware Fusion, Win 10 on a Mac? Please see attached image for the message that I get
10-31-2018, 10:25 PM | #352 |
Rep 8,364
