2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media What did you do to your 5 series today?
      05-18-2022, 11:43 PM   #2619
ctcarbonari
ctcarbonari's Avatar
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
Originally Posted by SummerallGuard04 View Post
When you mention "battery charger", what exactly are you referring to?
This was the one that I opted for:
(Was getting Increased Battery Drain While Stopped Code when I would leave my car parked for 2+ days during heavy rain - ended up being CA short)
https://smartercharger.com/products/ctek-mxs-5-0
      05-21-2022, 11:57 AM   #2620
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
Installed blacked out rear reflectors. VERY happy with them. They are actually LED lights that can be wired into the brake lights, but that's probably not going to happen. Need to do something about that shiny license plate frame.
      05-22-2022, 12:55 PM   #2621
zener
BMW enthusiast since 2004
Finland
29
Drives: E65 730d, E53 X5, F10 520d
Washed it and steering wheel heating retrofitted.
      05-28-2022, 03:11 PM   #2622
zener
Finland
29
xhp stage3 installed, transformation is amazing. I'll just hope soon I have time to do the timing chain and after that ecu tuning and more out of the N47.
      05-29-2022, 01:09 PM   #2623
marek555
marek555's Avatar
Estonia
35
Drives: BMW F10 535d, BMW E46 328i
Installed new rear wheel steering HSR actuator:
      05-30-2022, 11:43 AM   #2624
zener
Finland
29
Installed sport shifter. Just needed new connector and repin it.
      05-30-2022, 12:11 PM   #2625
Hmmm... Mine was plug-and-play.
Nice work!
      05-30-2022, 12:15 PM   #2626
zener
Finland
29
Connector changes to 10pin in 03/12. Mine is 05/11.
      05-30-2022, 01:52 PM   #2627
My 2012 was an 11/11 build...
      05-30-2022, 01:54 PM   #2628
zener
Finland
29
You had 8pin connector and shifter was also before 3/12?
My shifter was from lci.
      05-30-2022, 03:13 PM   #2629
That is probably it. Mine was from a pre-LCI.
      06-02-2022, 01:49 PM   #2630
AZ535i
AZ535i's Avatar
122
Drives: F10 535i
2013 BMW 535i  [0.00]
Cross drilled rotors and EBC Redstuff pads installed all around.
      06-05-2022, 11:09 AM   #2631
GrabacrOne
GrabacrOne's Avatar
Drives: F10 535i
Which rotors are these? They look like they have an aluminum hat?
F10 535i M-Sport /// Alpine White & Black Dakota
Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i
      06-05-2022, 11:27 AM   #2632
AZ535i
AZ535i's Avatar
122
Drives: F10 535i
Cquence is the company who makes them. From this angle, it does look like an aluminum hat on it but it's just a normal looking rotor.
      06-06-2022, 12:05 PM   #2633
xxpanipuri
Drives: 550i
Finally gave her a proper spring cleaning/scrub down.
2014 550i
Dinan Stage 3
Dinan Shockware
Meisterschaft Mufflers/m5 comp package xpipe
ACS Springs
OEM 343m (m5) wheels 285/255 (trying to get 295's in the back still)
      06-06-2022, 01:46 PM   #2634
zener
Finland
29
Test fitted winter wheel. I guess style 302's will work fine for winter, now gotta figure what tire to put. Thank god winter isn't even close yet.
I will lift it 1-2cm for winter also.
      06-06-2022, 03:35 PM   #2635
Sophistograu
Georgia
Drives: Bmw f10 535i
N55 engine bay
      06-06-2022, 07:35 PM   #2636
Hoa
New pad and rotor due to uneven wear and started to squeak slightly. Somehow outer side have about 25% while inner side have about 50% on the same corner.
      06-06-2022, 11:56 PM   #2637
StradaRedlands
Sticky pistons?
      06-07-2022, 06:57 AM   #2638
Hoa
Sticky pistons?
I don't think so. I was able to retract and push it out easily by spinning it from the back. Guide pins moves freely as well. We will see what happens in the future. Hopefully it's nothing
      06-11-2022, 12:06 PM   #2639
zener
Finland
29
New transmission mount. Cortego looked like OEM.
      06-18-2022, 03:40 AM   #2640
bustfriend
Drives: BMW 520d (F11)
cruise control switch was worn. Support wants 200 for the 10 part.
Well, that's what I did:
Copyright ©2000 - 2022, vBulletin Solutions Inc.
