2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
08-09-2021, 08:32 PM | #2399 |
Rep 7
The noise is the most blaringly obvious difference, however mine was really plugged up with dead leaves and pine needles, so the amount of air that comes out is nearly double, and the smell is SO much better.
08-10-2021, 04:38 PM | #2400 |
Rep 2,590
Finally got around to finishing the last of the comfort seat retrofit. Ran wire inside the door and spliced into the can lines for the side view mirror, since there is no other can line in the door if your car never came with memory passenger seats. The hole for the switch panel is actually punched out after manufacturing the door panel, so you normally need a special tool, but I traced out the driver side and free handed it. Not the prettiest hole in the world, but once the switch is installed it looks pretty OEM.
Also added a USB C PD port with data pass through, replacing the 12v socket under the glovebox. Allows me to still have wired android auto to my carlinkit MMI box, but also have USB C PD fast charging. Pretty trick, huge shout out to breakitout for the parts.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 08-16-2021 at 08:12 AM.. |
cdmulders326.50 |
08-14-2021, 07:05 PM | #2401 | |
Rep 277
I wish AA was wireless.. would push me to get something/install my headunit sooner |
08-15-2021, 10:35 AM | #2402 |
Rep 2,590
At least for the MMI unit, there is wireless android auto for my unit. It's just that it's kind of laggy and feels like it operates at 15fps while wired is at 30fps.
2015 BMW 535xi
08-15-2021, 08:45 PM | #2403 |
Petrolhead
440
Rep 806
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
My customized steering wheel from Coby Wheel arrived and installed. I'm so happy with it and breaths a new life into the car. Highly recommend these guys.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
08-15-2021, 10:43 PM | #2404 |
Rep 639
Got a chance to replace my engine and transmission mounts. It took most of the day, but after learning from my mistakes, I am confident I could do it in just a few hours now, if I ever have a need to do it again in the future.
08-19-2021, 07:27 AM | #2405 |
Petrolhead
440
Rep 806
Absolutely last mod on the car for the forceable feature. G11 caliper upgrade. Will post installed pics on the weekend once wheels are washed. Color (Sky Blue) is coming across a bit off in the photos, but it's a 100% match to the light blue in the BMW emblem. I wanted the calipers to be powder coated blue, but not anywhere close to Estoril blue.
Still going back and forth on decal (BMW vs Brembo vs nada). Not considering "M" for the same reason I stayed away from Estoril blue. Can't thank Unspec enough for all his support on this mod. If anyone is in the DMV, NV Coatings is the place to go for powder coating. They also did the 343m wheels I have and their work and customer service are tops.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) Last edited by spielnicht; 08-19-2021 at 07:39 AM.. |
Unspec1299.50 OnlyGerman362.00 |
08-19-2021, 07:50 AM | #2406 |
Rep 423
Nice find on the G30 calipers. I've been keeping my eyes open for a set, but they have been hard to find for a good price.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
08-19-2021, 01:47 PM | #2407 |
Rep 639
I've been staying busy upgrading/performing maintenance before I start traveling again for the fall work season. Still have more I want to do, but I don't know if I'll have time before I have to head out of town again. Here's what I've now gotten accomplished:
Front struts/spring pads/bump stops Front sway bar links Front upper control arms upgraded to negative camber version (cheaper than Dinan, but supposedly the same spec) Vanos solenoids Spark plugs/coils Cleaned MAF sensor Cleaned afe dry air filter |
08-19-2021, 07:43 PM | #2408 |
Rep 30
Installed B pillar ambient light:
08-19-2021, 07:47 PM | #2409 |
Rep 30
I have done a lot work for my EU spec F10 535d, I am thinking starting dedicated thread for my car. So, if I get some likes for this post, I will start my own thread, if not, there is no intrest, so I will not bother. But I will be warning You, there will be a lot pictures (maintenance, mods, repairs) in my thread, if You like this post
ezaircon4jc4473.00 BNHUSLNF100.00 |
08-20-2021, 12:59 AM | #2410 | |
Rep 277
08-22-2021, 12:55 AM | #2411 |
Rep 262
Digging the new roundels, forged carbon and no it's not an overlay or vinyl. Took a minute to get made but totally worth it to me
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
08-28-2021, 03:57 PM | #2412 |
Rep 20
Drives: 2012 535i xDrive M-Sport
Carbon fiber trim upgrade
ezaircon4jc4473.00 jayster0966209.00 |
08-30-2021, 04:22 AM | #2413 |
Rep 156
Hit 40k miles on the F10 today, idk why it’s so depressing watching the odometer go up lol
2014 BMW 550i M Sport- Tuned by Matt @Cedar Performance-Daily Driver
2016 Audi Q5 3.0T Prestige-Weekend Warrior 2008 Infiniti G37S Coupe 6MT-RIP 2015 Lexus RC350 FS-SOLD |
OnlyGerman362.00 |
08-30-2021, 09:17 AM | #2415 | |
Rep 538
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
OnlyGerman362.00 TuckerE3649.50 |
08-30-2021, 11:43 AM | #2417 | |
Rep 1,261
I went from the base cluster to the 6WA, it was pretty cheap and looks much nicer. 6WB would be nice but still so $$$. |
08-31-2021, 02:06 PM | #2419 |
Petrolhead
440
Rep 806
If you're interested TuckerE36, I have a 6WA that I'll sell for $150 but it does need to be virginized.
OnlyGerman362.00 |
08-31-2021, 02:55 PM | #2420 |
Rep 949
I can virginize that cluster as long as its 2015 or older or I can recommend a really good retrofitter based out of LA who can do so on basically all Fxx cars no matter the year.
OnlyGerman362.00 spielnicht439.50 |
