2010 2011 BMW 5 Series Forum F10 Brand New FTP Motorsports Intake Pipe - F07/10 F01/02 N55 Intake Pipe |
09-26-2021, 08:32 PM | #1 |
Rep 299
Drives: 2017 BMW X3 28i
Replaces BMW P/N 13717583727 This intake pipe from FTP motorsports will not only improve flow over stock but also make a big improvement in the reliability column. The factory intake pipe is made from plastic to reduce weight and manufacturing costs. While this is great for the production line and the sticker price, it doesn't hold up well as the engine ages or in the case of increased power. Replacing the weak plastic stock part with a solid aluminum one like this will ensure proper functionality under higher levels of boost and eliminate wear caused by the heating and cooling of plastic pipes. Features: Smooth bends for unobstructed flow Direct OEM replacement Larger than stock diameter for increased air volume Part was found on the following vehicles N55 engine: 5' F07 GT (09/2008 — 06/2013) 5' F07 GT LCI (08/2012 — 02/2017) 5' F10 (01/2009 — 06/2013) 5' F10 LCI (08/2012 — 10/2016) 5' F11 (02/2009 — 06/2013) 5' F11 LCI (10/2012 — 02/2017) 5' F18 (08/2009 — 07/2013) 5' F18 LCI (11/2012 — 12/2016) 7' F01 LCI (05/2011 — 05/2015) 7' F02 LCI (06/2011 — 05/2015)
2017 X3 28i
09-26-2021, 10:39 PM | #2 |
Rep 2,590
New or used? Also, what happened? It looks like you're selling off an entire PS2 upgrade, based on your prior listings. Just curious
2015 BMW 535xi
09-27-2021, 06:27 AM | #3 |
Rep 299
This is a new part, never installed. Selling car, selling parts...
2017 X3 28i
10-02-2021, 10:04 PM | #4 |
Rep 299
Bump
2017 X3 28i
10-07-2021, 08:45 PM | #5 |
Rep 299
Bump
2017 X3 28i
10-15-2021, 06:23 PM | #6 |
Rep 299
Bump
2017 X3 28i
10-21-2021, 06:49 PM | #8 |
Rep 299
Yes, it is an inlet pipe to the turbo.
Don't have time to do the upgrades myself, so lost interest in putting them on.
2017 X3 28i
