2010 2011 BMW 5 Series Forum F10 MST Performance BMW F10 N55 (3.0L) 535i Cold Air Intake System **NEW PRODUCT** |
08-25-2021, 09:33 AM | #67 |
Joint Chiefs of Staff
24326
Rep 191,065
no worries , my pleasure
11-02-2021, 04:07 PM | #69 |
24326
Rep 191,065
not sure what update you are expecting? The intake has been listed on the website since the thread was created. Customers that are interested in this intake can go to the website and place their orders.
11-02-2021, 04:52 PM | #70 | |
Rep 1,442
Drives: 2011 535i 6MT
11-02-2021, 09:55 PM | #72 |
Rep 4
11-03-2021, 09:00 AM | #73 | |
24326
Rep 191,065
We have sold 25 units since the start of this thread, with no complaints.
11-04-2021, 01:59 AM | #74 |
Rep 16
this is the most accurate sound to date, signature MST butterfly flutter most prominent on the N20...
sound clip |
11-04-2021, 09:30 AM | #75 | |
24326
Rep 191,065
10-04-2022, 09:00 PM | #76 |
Rep 1
I just installed this on my car I shined a light where the cone is and looked for the light outside the car. I can't see anything. How does air get into that box?
ctcarbonari295.00 |
10-04-2022, 09:18 PM | #77 |
Rep 1,442
I have always wondered the same thing!
burro_blasta131.50 |
10-10-2022, 01:23 PM | #78 |
Rep 2,591
You need to remove the cover for the air intake on the passenger side of the car. You can then install the air channel that the N63 uses for that side to help direct airflow a bit better.
2015 BMW 535xi
10-11-2022, 07:54 AM | #79 | |
Rep 639
10-11-2022, 12:00 PM | #80 | |
Rep 2,591
https://f10.5post.com/forums/showpos...postcount=2674 I'll post pictures later of the ducting for the front grille, but relevant part numbers: 13717577468 (grille/velocity stack like thing that helps air get in to duct) 13717577470 (the actual duct) 11617535849 (screw securing duct, I just transferred the screw that was on the driver side over to the passenger side, but your call) There is a blanking cover that you remove for the passenger side. I then used that to blank out the intake on the driver side (and secured it with duct tape, since it's not actually meant to fit that hole). You don't have to do this, and can leave the OEM intake as a way to cool the turbo/manifold area, but I am unsure how this changes the fluid dynamics of air in the area (since you have a higher pressure zone of air BEHIND the intake now), so I didn't risk it. Additionally, I chopped the OEM intake duct that included that accordion-like section and used it to direct the air upwards slightly and more directly at the cone. Pretty optional and idk how much a difference it makes.
2015 BMW 535xi
EV8634.00 |
10-11-2022, 02:21 PM | #81 | ||
Rep 639
02-23-2023, 04:28 PM | #82 | |
Rep 192
Any pics of the duct you made? Thinking about doing the same thing when the intake arrives. Thanks |
02-23-2023, 10:01 PM | #83 |
Rep 2,591
Sure, I'll take some in the afternoon tomorrow.
2015 BMW 535xi
Dtex535101.00 |
02-25-2023, 09:28 AM | #84 |
24326
Rep 191,065
Looking forward for the pics
Double Nickel168.00 |
02-28-2023, 11:32 PM | #85 |
Rep 2,591
Pictures of the duct, using part numbers as noted above
Pic 1: Showing how the duct roughly runs Pic 2: The original opening that has now been blanked off Pic 3: The new opening. I added a scoop - not necessary, but also probably doesn't hurt Pic 4: The exit Install is easy-ish. Just take your front left grille off, and reach inside to position the various things. Duct goes in first, kind of need to force it but eventually it kind of just falls into place and can jangle around. Then, you put the velocity-stack-thing in via the grille and need to clip the two together. This is probably the most annoying part. There's a little tab on the duct that needs to go into a hole on the "wall", and then the velocity-stack-thing clips into the duct, holding both pieces together and still. Then you tighten down the screw (you can see said screw in pic 1 - it's the pan head looking one directly under the silver metal bar) and viola, ducting. The upward turning bit is the original airbox's connector that was chopped off and forced onto the duct and secured in place by some crafty duct taping. Hope this is helpful
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 02-28-2023 at 11:38 PM.. |
03-01-2023, 08:40 AM | #86 | |
24326
Rep 191,065
03-19-2023, 04:08 PM | #87 | |
Rep 192
03-20-2023, 10:17 AM | #88 |
Rep 2,591
2015 BMW 535xi
Dtex535101.00 mashpotato28.50 |
