09-04-2023, 01:30 PM | #1 |
Builder of Special Cars
224
Rep 517
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
new CCV setup for N63
Built this with a friend, he machined all the fittings and connections, then used AN lines for it. We installed the vacuum valve lower on the engine crank case side, so its out of the way.
This is a direct bolt on for the N63, uses the brass filter catch can setup, so it actually works unlike others ones, this looks OEM hence why we put so much time into it. We're selling them for our cost, so that we can recoup the aluminum stock we bought and also to share the love, it was a project to learn the use of the CNC Mill, as you can see, it went well. ha We did this to pass along the savings, not to make money, as you can see, we build cool projects and pay it forward. PM me if you want to learn more. |
