2010 2011 BMW 5 Series Forum F10 Bent metal sheet in wheel causing lots of noise |
05-12-2024, 06:27 AM | #1 |
Rep 4
Sorry lads, I don’t know really anything about cars, I always wanted a BMW and have saved up for 8 years to finally buy a used F10.
The car was driving perfectly for the last 2 months, last week it started making some screeching sound sometimes but would go away. Recently the sound has changed to a more whooshing sound when driving slow and scratching too. When I hit a bumpy surface the metal rattles like it’s loose. Is this a threat to the road safety of the car? And is it possible to remove this thing temporarily and still drive safely? It’s a thin piece of metal seems to be for catching debris or something, doesn’t look super complex. Thanks very much, apologies for the lack of knowledge |
05-12-2024, 12:06 PM | #2 |
Rep 2,637
That's your brake dust shield. It's scratching your wheel. It should not be contacting anything.
2015 BMW 535xi
05-12-2024, 05:44 PM | #3 |
Rep 4
Thanks for the info, would it be okay to remove this until I can replace it? I’m a little worried about it breaking and a sharp piece taking out my tires on the motorway
05-12-2024, 06:44 PM | #4 |
Rep 2,637
Just figure out why it's contacting the wheel. If you get a replacement one, and the underlying issue isn't fixed, you're back at square one.
2015 BMW 535xi
idontknowmuch0.00 |
05-12-2024, 07:28 PM | #5 | |
Rep 979
If you jump to the following link, you'll see the front dust shield as item #3. If your dust shield is touching your wheel, it's probably missing at least 3 of the 4 bolts (Item 4). https://www.realoem.com/bmw/enUS/sho...diagId=34_1823 The following link is for the rear brake dust shield and rotor: https://www.realoem.com/bmw/enUS/sho...diagId=34_1824 Access to either the front or rear dust shield requires, removal of your wheel, removal of your brake caliper carrier, and removal of your brake rotor. IMHO, if you are going to go this far, you might as well put the bolts back in...rather than remove the plate. |
05-12-2024, 11:13 PM | #6 | |
Rep 4
The specifics for the wheel is: Front Driver Side (right). The specifics for the car is: BMW 5 Series 520D F10 SE 4DR, 2011, 2.0. I will check out those links thank you! |
