2010 2011 BMW 5 Series Forum F10 G Plus Intercooler Install DIY |
06-20-2019, 09:49 PM | #23 |
Rep 2
Wagner Intercooler Install
After upgrading to wagner intercooler, huge power losses to below 200 in hp and torque. Didnt have this issue with stock intercooler on stage 1 bootmod3.
07-02-2019, 05:26 PM | #25 |
V.I.P.
40
Rep 250
Drives: F10 535i 2011, F10 550i 2015
@Bullitts5
Thank you for the write up it helped a lot! I just installed my Gplus FMIC today. Man, what a tight fit, took me longer than expected and I’m typically good we these things. For future buyers: The installation is very straight forward but BEWARE if you’re not use to working on your car I would recommend taking it to a shop. Not sure the cost at a shop but I don’t think I would want to install this same FMIC again. Haha. |
trialmountain53.50 |
07-02-2019, 05:34 PM | #26 |
Rep 151
Mine should be here in a couple weeks!
obiltagi3 Was there an "aha" moment when you found what was making it such a tight fit and moved it out of the way? The electric fan? The cooler hoses? |
07-02-2019, 06:04 PM | #27 | |
Rep 590
07-03-2019, 03:21 PM | #28 |
V.I.P.
40
Rep 250
No aha moment for me... just alot of persuasion. I also used ramps and the FMIC isnt super light so working underneath the car and holding it for long periods of time can be tiring.
I ended up using a jack to give support which helped a lot. The oil cooler line is no problem, i was able to keep it aside while i got one side in. The most difficult part for me was getting the FMIC in smoothly. Once it was in place the hoses were a bit tough.(Just a tip, the driver side hose is a plastic tubing while the passenger is some kind of a silicone flex hose). I rested all day yesterday because of how exhausted i was. Today i gave my car a nice drive on the freeway, streets. Everything seems to be fine. Also I would HIGHLY recommend as mentioned in the DIY to wear some kind of clear goggles, a face mask covering nose and mouth and have a bright flashlight handy!
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1 F10 535i Alpine White/Oyster BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC Last edited by obiltagi3; 07-03-2019 at 03:23 PM.. Reason: Added Safety! |
InHousePerformance113.50 |
07-03-2019, 04:00 PM | #29 |
Rep 161
Drives: 2015 535i
Yeah its so tight I threw the stock one away cause I dont care who you are that thing isnt ever coming out lol. Its a pain in the butt to get up in there. Its been a while but I feel like the frame was a big pain to get the connectors of the intercooler past.
2015 F10 535i
FBO BM3 Pure Stage 2 Dorch Stage 2 HPFP E50 tune by Cary Jordan EOS EkP Module Walbro 525 LPFP Variant Argon 20? Wheels E60 M550i Sold “Im a crazy car guy” If it has a motor, it has my attention |
07-07-2019, 12:12 AM | #30 |
Rep 60
Yes, I second that, it was a TIGHT fit, had to cut the back of the shroud to get the MF in there, but it work and mine came with the brackets, so all good, overall, I can feel the performance difference, I havent dynoed but IATs are way lower from hooking up my laptop to the JB4, also fuel economy, I gained about 6 MPGs. If you dont have the G-Plus yet, get it, it is totally identical to the Wagner for $600 bucks less
2014 535i M Sport Mods: BMS Intake, FTP Charge Pipe, FTP Boost Pipe, G-Plus FMIC, JB4, Remus Sport Exhaust with 84mm Black Carbon Tips
InHousePerformance113.50 EV8634.00 |
07-14-2019, 05:42 PM | #31 |
Rep 117
Drives: 2021 G05, 2014 F10, 2009 E90
Installed it 7/14/2019 (about 3.5 hours with two hands, one a former BMW master tech), some notes below.
Notes so far (for a 14' F10): - Removing the top-side radiator fan helps with lighting for you to see stuff + getting the G-Plus up. - C-clips were a bit annoying. Had trouble with passenger side one. Might be just me. *****Driver side nozzle/coupler on the G-Plus should be milled 5mm-8mm shorter, else you can't get it up or need a lot of pushing on that side. This tied us up the most today. Thread starter had an easier time with driver side than passenger side. Was reverse for me today. - Driver side coolant hose that runs by the stock IC can be zip tied, but it doesn't really help as the restriction is the metal piece on car (can't take out) rubbing against coupler. Easier to just bleed the coolant/antifreeze and re-attach the hose after you install the G-Plus. Remember to refill the coolant tank and pump into the system before driving. - Brackets fit fine, stock IC plate is removed with the stock IC, bottom floor plate under IC can be reattached just fine. You can do this at home if you have two floor jacks for each of the jack points behind front wheels. Gotta get it high enough to put your head under and all. Make sure to put jack stands behind them as a safety precaution. Be safe! Last edited by Duckysaurus; 07-15-2019 at 03:52 PM.. Reason: Updates |
07-14-2019, 08:30 PM | #32 | |
Rep 590
07-15-2019, 12:15 AM | #34 |
Rep 117
Will have to see.
BTW, will need a flathead, a longer pick, a pry bar, and I think I used a 3/4", 3/8" and 5/16" size since I took off the radiator from the top also. To confirm, just look under the front bumper where it meets the two plates, and also open up the hood and the top screws by the rubber insulator will confirm it. Look @ my notes 2 posts before for my additions to the thread starter's notes. Good luck! |
07-21-2019, 09:58 PM | #35 | |
Rep 23
07-22-2019, 07:11 PM | #36 |
Rep 117
No problems, stays on extremely secure with the hose C-clips + the brackets. Not worried about it falling out at all. It's really tight!
I'd probably lose my spoiler or diffuser before the FMIC drops out, lol. Last edited by Duckysaurus; 07-22-2019 at 07:59 PM.. |
07-22-2019, 09:32 PM | #37 |
Rep 23
that good to know!! hope you had more fun with it!
07-29-2019, 04:40 PM | #38 |
Rep 221
Any updates on it's performance vs stock? Did you notice any loss in boost pressure?
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
07-29-2019, 04:56 PM | #39 | |
Rep 151
Works as advertised. Install was a pain, like everyone said it is a very tight fit. Took me about 1.5 hours to install with the help of a friend. http://www.bootmod3.net/www/index.ht...9#/drawer/logs
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
07-31-2019, 12:09 AM | #40 |
Rep 14,521
are you guys removing the front bumper when doing this? if not do you think removing the bumper will actually make it easier to get to things?
07-31-2019, 12:54 AM | #41 |
Rep 716
lsturbointeg9166.50 |
08-04-2019, 03:36 PM | #42 | |
Rep 58
thanks for all the friendly tips. I instantly moved to mhd 93 oct 2+ and I'm very pleased. I let it run in the driveway till I got ait to 120 and within 200yds of my driveway I was down to 100 ait. drove about 35 miles and temps stayed between 90 and 100 the entire time with multiple pulls.. |
08-05-2019, 11:44 AM | #43 | |
Rep 14,521
08-06-2019, 08:17 AM | #44 | |
Rep 2,595
In the end, the driver's side was just too tight and the lower part of the exit tube couldn't move past an aluminum strut or whatever it was. I got a file and filed the spot back a little (made probably a 1/8" divot) and it finally went in without a hitch. The end of the exit tube doesn't interact with the airflow, so it's not going to affect anything, just looks a little funky, but it's not like you can even see that part when it's installed. As others said, it's super tight and no way am I ever going to try to take this thing out. I don't foresee needing to take it out/swap it either, so not a problem for me. |
