2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY brake flush/bleed - comments and feedback
      05-18-2020, 01:31 AM   #23
dvaz
Drives: 2015 E84 X1
Originally Posted by Surly73 View Post
The simplified process:
1/ bleed a little through all four corners
2/ open LR - ISTA will pre-bleed (large quantity, fast)
3/ open LF - ISTA will pre-bleed (large quantity, fast)
4/ open all four in sequence - ISTA will bleed each one in turn (90s each, modest quantity of fluid)
I am to do this soon.
So basically attach the motif, pressure it, load up ISTA, go to the brake bleeding procedure, start - and just follow instructions on screen - clicking next continue as you go along?
On the part 4, where you say open all four in sequence, do you not close the valve before going to the next one? or they all left open at this point?
      05-18-2020, 09:00 AM   #24
Surly73
Yes - just follow instructions. Only one bleeder is ever open at a time.
      06-02-2020, 10:35 PM   #25
ckaul
Drives: 2012 BMW 528i xDrive
Can someone explain how you connect ISTA to an F10? Do you use a DCAN cable, an ENET cable or the ICOM device thing? I really cant figure this out and I have been all over the internet trying to get my car to connect to this damn software..
      06-02-2020, 10:44 PM   #26
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
ENET. ICOM is really only used for programming the car.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      06-02-2020, 10:44 PM   #27
Pick one or there are instructions here somewhere on how to make your own.
https://www.ebay.com/sch/i.html?_fro...cable&_sacat=0
      06-02-2020, 10:55 PM   #28
ckaul
https://www.ebay.com/sch/i.html?_fro...e&_sacat=0
So I already have an ENET cable and some old version of ISTA. Now when I tried to connect the car it just doesnt recognize anything and I cant figure out why..
      12-15-2020, 02:43 PM   #29
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Some of the specialty BMW shops around my area don't even do the full ISTA process. Has anyone not done that that and still have successful results?
      12-16-2020, 08:09 PM   #30
nedmon
Drives: 1998 528i
I changed the fluid in the F10 last Summer just using a Motive pressure Bleeder and did one corner at a time just like in the good old days.
The only exciting part of the job was the fear that I might let the fluid level drop too low in the master cylinder in which case I might need dealership help.
The brakes were fine before and after I changed the fluid.
Nedmon
2015 535ix
2016 X3
      01-26-2021, 06:32 AM   #31
MrGreenPump
Drives: 14 535d (N57T)
I just had a Brake Fluid service performed at Carbahn Autoworks (Steve Dinan's new shop in the Bay Area). I paid $167.00 out the door with no coupons, discounts or referrals.
2014 545d w/ 115,000mi
      02-02-2021, 05:20 PM   #32
omgwtf
Drives: 2016 535i
thanks for the info. do they do the full ISTA process?
      02-16-2021, 09:54 AM   #33
Unspec
Unspec's Avatar
1300
Do you guys bleed the brakes with the parking brake on or off? Does it even matter?
2015 BMW 535xi
      02-16-2021, 03:07 PM   #34
Sylverlee
I did it with it off this weekend. Pedal feels like new. Did not do whole ista process..
Although on my 911 I accidentally got air in it. Pedal fell to the floor. Had to do the ABS bleeding using a Foxwell. Back to new.
      02-16-2021, 09:48 PM   #35
Unspec
Unspec's Avatar
1300
I took my calipers off to paint them, so right now I have the squish pedal problem even after 2 ISTA bleeds. Probably just need to bleed it one more time. Sigh.
2015 BMW 535xi
      02-16-2021, 10:57 PM   #36
Sylverlee
Yeah took me two ABS bleeds. It took a while, I noticed the pedal getting firmer as I was going on/off the brakes during the bleed. I had to use the wet process (filling up my bleeder), because each side was pumping out a massive amount. 400-500ml.
      02-28-2021, 02:12 AM   #37
Unspec
Unspec's Avatar
1300
I just realized I was bleeding my brakes kind of wrong. My first time really bleeding them, so learning curve! I was closing the bleeder (with the brake held down to prevent sucking back old fluid) as soon as the 90s timer in ISTA ran down. Turns out, the last line says something along the lines of "close bleeder after fluid is bubble free". I realized that it probably meant to keep pumping the brakes every 5 second until it runs free of air after the 90s timer. I noticed that even after the timer and all the DSC pump action, it was still pumping out a ton of air afterwards, probably took another 60s of pumping to fully clear it out. Now, my pedal is rock solid.
2015 BMW 535xi
      02-28-2021, 10:52 AM   #38
Sylverlee
Awesome! Yeah was my first time too. Lots of fluid coming out while pumping those 90+ seconds.
      06-18-2021, 05:26 PM   #39
ramman434
Drives: F30 335i
Hey guys, sorry to bump a slightly older thread.
Just finished changing out pads/rotors on my ‘16 F10. My buddy and I bled the brakes twice (old way) and there’s no pressure in the brake pedal. To stop the car, driving around the neighborhood the pedal is almost to the floor. We bled them twice, bc we hoped the 1st time this happened when driving around, we’d accidentally got some air in the lines.
I’ve never heard of this ISTA thing before. Could that be why I have no pressure?
Please let me know!! Right now my cars stuck at my buddy’s, 25 min down the hwy, bc it’s not safe to drive.
      06-18-2021, 06:35 PM   #40
Did you bleed the brakes with the engine running? Seems to be a requirement with ABS using the old way.
      06-19-2021, 02:01 AM   #41
ramman434
Drives: F30 335i
That’s a negative. We only had the engine running once we got air out of the lines, and we’re trying to pump the brakes.
So you’re suggesting that the engine must be running, while bleeding all air bubbles out?
      06-19-2021, 12:20 PM   #42
Yup. The ABS pump needs to be "energized" to get out the air when manually bleeding.
      06-19-2021, 10:51 PM   #43
Unspec
Unspec's Avatar
1300
Only if you're bleeding the ABS unit due to introducing air. If you're doing a routine brake bleed, there's no need to do that.
2015 BMW 535xi
      06-20-2021, 07:09 AM   #44
ramman434
Drives: F30 335i
We're thinking that there could have been air introduced into the ABS unit.
So just to clarify, y'all are saying to turn the car on (engine running) and re-bleed all 4 calipers?
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
